Tow Behind Leaf Mulcher/Vacumm
/ Tow Behind Leaf Mulcher/Vacumm #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
I'm thinking about buying a tow-behind leaf vacumm mulcher.
I'd be rigging this to a Z920 Deere Zero-Turn mower.
I've looked into the DR and Cyclone brands...any body have real world experience they'd care to share?
/ Tow Behind Leaf Mulcher/Vacumm #2
I don't have first hand experience but just my .02 cents worth. The Cyclone with swivel wheels may work much better on a zero turn.
/ Tow Behind Leaf Mulcher/Vacumm #3
I can’t imagine either works well for a ZTR. I haven’t had a chance to use it yet, but I recently bought this unit. I think it’ll work much better then my old cyclone. I hated that thing. IMG_0095.JPG
/ Tow Behind Leaf Mulcher/Vacumm #4
Hi Roy,
It's been a long time since reading a post from you. Cheers....
Maybe the size of the vacuum unit would have something to do with using it on a zero turn. I really like my Z-10 Cyclone Rake, but pull it with a Kubot B2620. Customer service and advice at CR is really good in my experience.
Mike
/ Tow Behind Leaf Mulcher/Vacumm #5
I have the cyclone rake commander xl behind a Husqvarna riding mower. 44 bushel bag. Works great has saved me a lot of effort with leaves and clippings.
/ Tow Behind Leaf Mulcher/Vacumm #6
I have a Cyclone Rake that I used on my Husqvarna zero turn - works very well. I have found that you want to pick up leaves multiple times. Do not wait for all the leaves to be down - that method was a real pain. I do my leaves about 4 times in the fall and trust me I have a lot of them:thumbdown:
/ Tow Behind Leaf Mulcher/Vacumm #7
I've used both castor type vacs and a trailer unit. I prefer the trailer unit because when the catch box is full of leaves, nuts and twigs, its very heavy. This adds a LOT of rotating inertia to the combined unit and that takes a lot of steering force to maneuver. This means large loads on a front steered lawn tractor (because of the inertia, and likely a lot of torn up grass from the Z-turn method of steering. The only advantage I found was the length of hose from the deck to the vac is a fixed constant.
For the trailer unit, I like a long hitch on the mower so I can make very sharp turns. Yes, the hose length changes as you turn left and right. My trailer vac also holds quite a bit more content than the canvas bag units. Since it has a separate motor, I have all the power it takes to suck, shred and blast the clippings, leaves and nuts that I want removed from my lawn. I have a 72" deck on my F-935 and it takes a 10" hose to handle the volume per second that the mower can produce.
/ Tow Behind Leaf Mulcher/Vacumm #8
I have a DR that I have had for about 4 years. I bought it for use at my last house with a lot of trees.
It worked great and even picked up leaves from the year before that I blew into a pile with mower!
I used it with my 52" Grasshopper ZRT. I didn't buy the hose extension so I could only make right turns.
It has the 8 hp engine and with walk around hose I paid $1800.
I have tried to sell it for $1200. on CL but the low ballers wanted me to give it away.
I have kept it under cover and only used it for about 4 hours.
Now they have the 6 hp engine and the price came down. :(
I guess I will get tired of looking at it and cut it up for scrap someday. ??
/ Tow Behind Leaf Mulcher/Vacumm #9
/ Tow Behind Leaf Mulcher/Vacumm #10
I've had a Cyclone Rake for about 8 years. Use it with my JD 2320 with 62D MMM.
Works very good for me. Sure saves a lot of time getting up the fall leaves.
CR has great customer service.
/ Tow Behind Leaf Mulcher/Vacumm #12
I have the middle model DR and I use it behind my John Deere 2520 with the 62D mid mount mower. I love the thing. Some days it can be a pain to use and I still love it. I bought it for sucking up grass as I mow because I am kinda in a swamp and the thick grass never dries out so I have to pick it up. I will regularly mow seven acres of lawn with it attached to pick up the grass. I also use it to remove leaves on my parents five acre yard in the fall.
It is trailer style. I will probably convert it to be carried on the 3pt hitch in the future. My biggest issue with it is the hose. To have the hose long enough to turn left it is way to long to turn right. I eventually after two summers of use have worn through the hose for the amount of flexing it does between left and right turns. That is the only reason I want to 3pt it. To get rid of the hose flex in turning.
Other things to note:
The engine is super easy to start, I have the pull start version. A single half hearted pull will get it going even after sitting over winter.
It burns lots of gas, but it works hard. When it is grunting and sucking leaves and grass full bore I think it is close to a gallon an hour.
Sticks get stuck in the hose. Usually not an issue, but a couple poplar trees at my parents have tons of short sticks that always jam it.
It is very loud, I wear double hearing protege using it. Can’t even hear the mower I am riding on when it is running
Can be hard to dump if overfilled.
Very easy to back up and tracks around trees well due to its fairly long wheelbase.
You have to pull out one engine mounting bolt to drain the oil. Was annoying the first time.
Over all the thing is annoying to use, has its quirks with the hose, likes to fall off etc. (but wrapping the connection with duct tape on top of the hose clamp helped a ton)
But I love love love the thing and would never consider being without it for my yard.
/ Tow Behind Leaf Mulcher/Vacumm #13
Kevinwak Would you be able to remount the motor 90 degrees so that the hose goes into the center of the motor instead of one side. It would also let you remodel the oil change bolt problems.
/ Tow Behind Leaf Mulcher/Vacumm #14
I don’t think so, but I should look. Part of me wants to 3pt Mount it, but another part doesn’t because then I have to worry about tail swing. Right now it follows so nice behind the tractor... if I add four feet fixed to the back of the tractor i will really have to watch the tail swing.
/ Tow Behind Leaf Mulcher/Vacumm #15
Since I just purchased one of these about 2 years ago, in case it's helpful, here's why I chose the DR over the Cyclone Rake.
1. DR has a toothed metal impeller that also mulches. So if you're using it with your mower, everything gets mulched twice. However, I also need to remove leaves in many areas where you can't really mow, like from landscaped beds, from under bushes, from ditches, or on rough trails. With the Cyclone you can vacuum them up, but they won't be mulched. This was probably the biggest and most important factor for me.
2. I liked that the path from the mower discharge to the impeller was level, whereas the CR it curves up. Figured less chance for clogs.
3. Overall sturdiness, the DR seems miles above the CR. Size of wheels, the construction of the collector, ease of dumping, etc.
4. Price is about the same.
5. Cyclone had a rigid hitch that won't articulate. Eliminates jackknifing but increases the turning radius.
Pics below show DR on the left; Cyclone on the right.
I wouldn't use a DR with a z-turn. It is HEAVY when full of mulched leaves or grass. The lighter Cyclone might be okay. Either way, much better than not having one.
/ Tow Behind Leaf Mulcher/Vacumm #16
I agree, much better than not having one.
I think lots of my hose issues come from using it during my weeklymowing. If I was just doing it for falls leaves I would probably not have worn through the hose already.
/ Tow Behind Leaf Mulcher/Vacumm #17
We just bought a used cyclone to use on the B7500, we use it to knock down the hayfield and feed it as "green-chop" this time of year. So far, we have been happy with it (other than some issues with it clogging, need to work on that).
Aaron Z
The DR is my preference for couple reasons,,,
They're local, in Vermont...about 50 miles from home. They have "scratch and dent" sales as well as refurbished equipment. They also have (or had) pretty decent post season sales.
For my purposes, the unit wouldn't be used much, except for leaf removal and the occasional time I miss mowing weekly.
/ Tow Behind Leaf Mulcher/Vacumm #19
I never have understood the need for such unless you want to collect the stuff for your compost. I ran a zero turn mower on 5 acres of church property with lots of trees in Whippany, NJ. It wasn't even a mulcher (a Scag). I'd just run it around and discharge inward until it almost choked up. Then I'd turn around and run it the other way for another round or two before discharging back inward again.
If you had a good mulching zero turn, you wouldn't need to do this. My walkbehind self propel mowers are good mulchers and chop the leaves up great. Better to put the leaves back where there were created from. Good for the grass and the trees.
On my own property, I don't get enough leaves to save them for compost. I go collect about 100 bags of leaves that the silly town people collect and just leave at the curb (A local outfit called Panorama Paydirt collects them and then sells it as mulch, compost or soil.)
Ralph
/ Tow Behind Leaf Mulcher/Vacumm #20
Ralph
I find this approach works good if you keep up with the leaves. If you want to do it once at the end of the year the mower can’t mulch heavy oak leafs very well. Maple leafs are delicate and mulch much better.
2014 KUBOTA SVL75-2 SKID STEER (INOPERABLE) (A63569)
2014 KUBOTA...
2021 Chevrolet Equinox SUV (A61574)
2021 Chevrolet...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63118)
2024 Kubota...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
2024 John Deere 8R 370 Tractor (A63109)
2024 John Deere 8R...
