Tow Behind Leaf Mulcher/Vacumm
   / Tow Behind Leaf Mulcher/Vacumm #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
I'm thinking about buying a tow-behind leaf vacumm mulcher.
I'd be rigging this to a Z920 Deere Zero-Turn mower.
I've looked into the DR and Cyclone brands...any body have real world experience they'd care to share?
   / Tow Behind Leaf Mulcher/Vacumm #2
I don't have first hand experience but just my .02 cents worth. The Cyclone with swivel wheels may work much better on a zero turn.
   / Tow Behind Leaf Mulcher/Vacumm #3
I can’t imagine either works well for a ZTR. I haven’t had a chance to use it yet, but I recently bought this unit. I think it’ll work much better then my old cyclone. I hated that thing. IMG_0095.JPG
   / Tow Behind Leaf Mulcher/Vacumm #4
Hi Roy,
It's been a long time since reading a post from you. Cheers....
Maybe the size of the vacuum unit would have something to do with using it on a zero turn. I really like my Z-10 Cyclone Rake, but pull it with a Kubot B2620. Customer service and advice at CR is really good in my experience.
Mike
   / Tow Behind Leaf Mulcher/Vacumm #5
I have the cyclone rake commander xl behind a Husqvarna riding mower. 44 bushel bag. Works great has saved me a lot of effort with leaves and clippings.
   / Tow Behind Leaf Mulcher/Vacumm #6
I have a Cyclone Rake that I used on my Husqvarna zero turn - works very well. I have found that you want to pick up leaves multiple times. Do not wait for all the leaves to be down - that method was a real pain. I do my leaves about 4 times in the fall and trust me I have a lot of them:thumbdown:
   / Tow Behind Leaf Mulcher/Vacumm #7
I've used both castor type vacs and a trailer unit. I prefer the trailer unit because when the catch box is full of leaves, nuts and twigs, its very heavy. This adds a LOT of rotating inertia to the combined unit and that takes a lot of steering force to maneuver. This means large loads on a front steered lawn tractor (because of the inertia, and likely a lot of torn up grass from the Z-turn method of steering. The only advantage I found was the length of hose from the deck to the vac is a fixed constant.
For the trailer unit, I like a long hitch on the mower so I can make very sharp turns. Yes, the hose length changes as you turn left and right. My trailer vac also holds quite a bit more content than the canvas bag units. Since it has a separate motor, I have all the power it takes to suck, shred and blast the clippings, leaves and nuts that I want removed from my lawn. I have a 72" deck on my F-935 and it takes a 10" hose to handle the volume per second that the mower can produce.
   / Tow Behind Leaf Mulcher/Vacumm #8
I have a DR that I have had for about 4 years. I bought it for use at my last house with a lot of trees.
It worked great and even picked up leaves from the year before that I blew into a pile with mower!
I used it with my 52" Grasshopper ZRT. I didn't buy the hose extension so I could only make right turns.
It has the 8 hp engine and with walk around hose I paid $1800.
I have tried to sell it for $1200. on CL but the low ballers wanted me to give it away.
I have kept it under cover and only used it for about 4 hours.
Now they have the 6 hp engine and the price came down. :(
I guess I will get tired of looking at it and cut it up for scrap someday. ??
   / Tow Behind Leaf Mulcher/Vacumm #9
   / Tow Behind Leaf Mulcher/Vacumm #10
I've had a Cyclone Rake for about 8 years. Use it with my JD 2320 with 62D MMM.
Works very good for me. Sure saves a lot of time getting up the fall leaves.
CR has great customer service.
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56436)
2021 Unverferth...
2015 Freightliner Squirt Bucket Truck (A55973)
2015 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 International 7500 T/A Altec A77T 76ft. Bucket Truck (A55973)
2008 International...
INTERNATIONAL S/A GRAIN TRUCK (A52708)
INTERNATIONAL S/A...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A55973)
