Tow Behind Leaf Mulcher/Vacumm
   / Tow Behind Leaf Mulcher/Vacumm #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
I'm thinking about buying a tow-behind leaf vacumm mulcher.
I'd be rigging this to a Z920 Deere Zero-Turn mower.
I've looked into the DR and Cyclone brands...any body have real world experience they'd care to share?
   / Tow Behind Leaf Mulcher/Vacumm #2
I don't have first hand experience but just my .02 cents worth. The Cyclone with swivel wheels may work much better on a zero turn.
   / Tow Behind Leaf Mulcher/Vacumm #3
I can’t imagine either works well for a ZTR. I haven’t had a chance to use it yet, but I recently bought this unit. I think it’ll work much better then my old cyclone. I hated that thing. IMG_0095.JPG
   / Tow Behind Leaf Mulcher/Vacumm #4
Hi Roy,
It's been a long time since reading a post from you. Cheers....
Maybe the size of the vacuum unit would have something to do with using it on a zero turn. I really like my Z-10 Cyclone Rake, but pull it with a Kubot B2620. Customer service and advice at CR is really good in my experience.
Mike
   / Tow Behind Leaf Mulcher/Vacumm #5
I have the cyclone rake commander xl behind a Husqvarna riding mower. 44 bushel bag. Works great has saved me a lot of effort with leaves and clippings.
   / Tow Behind Leaf Mulcher/Vacumm #6
I have a Cyclone Rake that I used on my Husqvarna zero turn - works very well. I have found that you want to pick up leaves multiple times. Do not wait for all the leaves to be down - that method was a real pain. I do my leaves about 4 times in the fall and trust me I have a lot of them:thumbdown:
   / Tow Behind Leaf Mulcher/Vacumm #7
I've used both castor type vacs and a trailer unit. I prefer the trailer unit because when the catch box is full of leaves, nuts and twigs, its very heavy. This adds a LOT of rotating inertia to the combined unit and that takes a lot of steering force to maneuver. This means large loads on a front steered lawn tractor (because of the inertia, and likely a lot of torn up grass from the Z-turn method of steering. The only advantage I found was the length of hose from the deck to the vac is a fixed constant.
For the trailer unit, I like a long hitch on the mower so I can make very sharp turns. Yes, the hose length changes as you turn left and right. My trailer vac also holds quite a bit more content than the canvas bag units. Since it has a separate motor, I have all the power it takes to suck, shred and blast the clippings, leaves and nuts that I want removed from my lawn. I have a 72" deck on my F-935 and it takes a 10" hose to handle the volume per second that the mower can produce.
   / Tow Behind Leaf Mulcher/Vacumm #8
I have a DR that I have had for about 4 years. I bought it for use at my last house with a lot of trees.
It worked great and even picked up leaves from the year before that I blew into a pile with mower!
I used it with my 52" Grasshopper ZRT. I didn't buy the hose extension so I could only make right turns.
It has the 8 hp engine and with walk around hose I paid $1800.
I have tried to sell it for $1200. on CL but the low ballers wanted me to give it away.
I have kept it under cover and only used it for about 4 hours.
Now they have the 6 hp engine and the price came down. :(
I guess I will get tired of looking at it and cut it up for scrap someday. ??
   / Tow Behind Leaf Mulcher/Vacumm #9
   / Tow Behind Leaf Mulcher/Vacumm #10
I've had a Cyclone Rake for about 8 years. Use it with my JD 2320 with 62D MMM.
Works very good for me. Sure saves a lot of time getting up the fall leaves.
CR has great customer service.
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
2011 Peterbilt 365 Altec AC38-127S 5-Mast 127ft. 38 Ton Tri-Axle Hydraulic Telescopic Crane Truck (A56858)
2011 Peterbilt 365...
2014 GMC Terrain SUV (A56859)
2014 GMC Terrain...
TANK MANIFOLD (A58214)
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
