JD 955 Died in Field
/ JD 955 Died in Field #1
Jjrpoplar
John Deere 955
My John Deere 955 just died in the field. I finished bush hogging, turned if off to blow off the dust. I went to start it. It fired right up and died in about a second. I get no dash lights at all, though the battery tests fine. It is like there is no battery in it. the key will not even allow the lights to be turned on. Any help would be appreciated.
/ JD 955 Died in Field #2
:welcome: to TBN
Maybe corroded connection on battery cables? check both ends of each cable.
What tests were showing the battery is fine?
Possible mouse nest destroying a critical wire?
Wish you good luck finding the problem.
/ JD 955 Died in Field #3
check the frame end of the ground cable, their famous for having trouble there, don't just look at it, take it loose and clean it
/ JD 955 Died in Field #5
What did you find out?
/ JD 955 Died in Field #6
Check Main Fuse. Should be 40Amp if it's got one and beside the engine. Check fuses in fuse box. Check safety switches. Seat, Clutch and Neutral ones.
/ JD 955 Died in Field #7
Check your seat and PTO safety switches. Exact same situation happened to me on the 770 a few years ago and I found it was the PTO switch. Wiggling it on and off a few times solved the problem. Never had the issue again.
Thanks for the responses everyone! I did not realize I got them. I went out the next morning and it started! However, yesterday, I put it in the barn and as I walked away, I heard something like a fuse go. Now, I have nothing again! Where is the main fuse? I can't find a 40 amp fuse on the tractor. The battery will not take a charge. I had a business trip but am going out to work on it now. Any advice would be appreciated!
UPDATE: I went out to start working on the 955. I disconnected the Neg, and when I went to disconnect the POS, I found it was warm to the touch. Not hot, but just warm. Does that indicate a short somewhere?
/ JD 955 Died in Field #10
that would make me think that current has been flowing. disconnect the battery and charge then reconnect. If you get a spark when reconnecting the battery then I would look into what is drawing the current.
/ JD 955 Died in Field #11
If you had tried to crank the engine before taking off the POS terminal, then the warm terminal says that you have a poor connection. That may be your issue right there. Clean the terminal and put it back on.
/ JD 955 Died in Field #12
I had a similar problem on my 955. Will it run if you put the key to the on position and jump the starter solenoid? Mine was back feeding power through the relay for the glow plugs. I had the whole wire harness apart to try to find the short. I ended up just taking the relay out. I had to do something to the fuel shut off, but I can't remember exactly what I did. It had a dull illumination of the glow plug light in the dash with the key off. It was hard to see with the lights on in the barn. My problem became apparent when I needed a new battery. I put a new battery in and the next day, the new battery was junk. I cant remember exactly what I did, but it had to do with how the fuel shut off gets power. I sold the tractor, so I cant go look at it to refresh my memory.
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
2020 ASV RT65 (A60462)
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
iDrive TDS-2010H...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
