Vdog
I would like the get a hydraulic top link for my box blade. Any recommendations where to get one and any brands to stay away from?
Thanks... just shot him an email.This is good if you can wait 18 weeks, if it wasn't good the lead time wouldn't be that long: Fit Rite Hydraulics - fitritehydraulics.com
It is owned by a TBN member, MtnViewRanch.
I've been very happy with the Cat.1 from Surpluscenter, also comes with a lock valve.
I've had mine for 8years, very happy with the quality.
Can't comment on the cat 2 versions.
Good to know... hope it makes sense on a SCUT.I just got my Top and Tilt in from Fit Rite. Hooked it up and attached an implement today. Played with it a little but didn't have time to do anything.
The limited time I had with it told me it was a good decision.
It will if you do a lot of blade work, I love mine and wouldn't be without hyd. side link again.Good to know... hope it makes sense on a SCUT.
Got a auto gen reply from Brian saying he will get back to me shortly. Indeed he seems busy. Now wondering if I should invest in a top and tilt or just a top link for my Box blade?
I am carving tractor trails across my steep sloped property and having a tilt feature I think could be a huge time saver. I have found it very hard to change the 'roll' (downhill pitch) when cutting across the hillside.
Do they make electric top links now? We have a 12v powered gate on our driveway. The way it's made, you'd think it was be very easy to do a top link in electric using that type of design.
Be so much simpler than hydraulic.
Ralph
Same. I've used linear actuators for a few projects. The cheap $50-70 ones rated for 100-200lbs & the $200+ ones rated for 1,000lbs. They work fine for actuating SSQA levers or rotating snowblower chutes. But they aren't beefy enough for most tractor use you'd use hydraulics for. Especially if shock loads are involved. Vibration tends to wear linear actuators out faster than other components as they have a decent number of small parts.I've never saw an electric actuator on a snowplow. All I've saw are hydraulic cylinders powered by self contained electrical pump units.
I don't think the linear actuator in your pic will stand the loads applied to a top link.
