Pole Barn or Metal building?
/ Pole Barn or Metal building? #1
BMan2005
GA
17' New Holland Workmaster 60 & 02' Kubota L3000F
We are getting our land closer to being ready to move onto and build. I want a big Shop/Barn to store our LQ horse trailer with my truck left hooked up, tractor, ranger, and other things needing stored out of the elements. I willl have a lean to built off each side for additional shelter and one side I will build stalls under for our horses. So I am getting into the planning stage of things. This lead me to my question, I need a big shelter without breaking myself but still like durable and long lasting keeping cost down as much as possible. I have stumbled onto these metal barns and was curious if anyone has gotten one and how do you like it? Here is an example of one I looked at for an idea. 36x71 Enclosed Building with Lean-to | 36’ Wide Building
/ Pole Barn or Metal building? #2
Boy these discussions are tough. Soooo many variables and exceptions.
Are you building it? Do you have the equipment to do all the prep work? How bout utilities? Gonna insulate and heat it? Indoor plumbing? Lights? Finished interior walls?
Reason I ask these questions is if you simply want a metal skinned "pop can" to park under it doesn't matter which you choose. Do the one that easily serves your need.
If you intend to build a "modern" building with immenities then the choice becomes more complicated.
So for me, I'd need more information before offering an opinion.
I had a "pole barn" finished. Have an all steel now that's finished. Building a studded building on concrete pad that's finished now. I can offer my opinions in regards to these three varieties if it helps you.
/ Pole Barn or Metal building? #3
My personal preference is a pole building.
/ Pole Barn or Metal building? #4
I have one of the metal buildings similar but smaller than yours. I put it on a gravel floor base and did the land prep myself. I like it and it is very utilitarian and looks good. We致e had some storms come through with 60 mph+ Winds with no issue whatsoever. Needless to say I知 a fan. Do not put any fill in if you have to level a spot. Dig down to the low point.
Here is mine for reference.
[QUOTE=ovrszd;5236485]Boy these discussions are tough. Soooo many variables and exceptions.
Are you building it? Not if I bought a metal building. Cost to put it up is much cheaper than a pole barn. . Do you have the equipment to do all the prep work? Yes How bout utilities? Gonna insulate heat it? Not at the moment. Eventually I may add a small insulated workshop inside heat & cooled Indoor plumbing? Most likely no, just a water line or two Lights? Yes. Finished interior walls? No
I had a "pole barn" finished. Have an all steel now that's finished. Building a studded building on concrete pad that's finished now. I can offer my opinions in regards to these three varieties if it helps you.[/QUOTE]
Aesthetically I love a pole barn and it would have more of the look to go with our place. Cost to put it up is just steep compared to the metal ones.
Explain more please
/ Pole Barn or Metal building? #6
Just an example- I had this building put up 3 years ago for $38 K complete , it is 40' X 60' X 14'.
I bought it from a dealer in Jacksonville Fl and it was made in Adel Ga.
One big concern is do you have to permit it? Then costs/options go up.
Pole barns tend to be cheaper.
/ Pole Barn or Metal building? #7
I disagree. I would always use fill to level to the highest point or even just a bit higher. Compacted, of course. That way there is no issues with rain water running towards any side of the building.
/ Pole Barn or Metal building? #8
Just had a Morton 30x50x16 pole barn constructed ....I did not build it myself. I did look at the metal buildings but just didn't like it. The pole barn cost $43,000...that included a concrete floor but no electric. The metal building was the going to be $41,000. Metal buildings require a much more detailed concrete construction. Are you going to build this yourself ? Are you talking about a metal skin with metal stud like wall framing, or the 'Red Iron' type which uses heavy duty framing with metal purlins ? If you go with a metal skin with metal stud type wall framing then you just need to pour a concrete slab. If it is Red Iron you have to have a engineered concrete slab. IMO a pole barn is more flexible in building what you want on the interior. Plus you don't have to pour a slab until you are ready. All in all don't short change yourself or cut corners with a building that size you are wanting to build. Its not going to be cheap !!!
/ Pole Barn or Metal building? #9
Explain more please[/QUOTE]
My spot was about 20 inches higher on the back left than the front left. To put in the metal building you cannot have more than 6 inches of variation across your 70 foot building. So if you like me have any slope, you have to dig down the high spot and not fill the low spot. You can’t a have it settle down later. I had to dig down starting at the right front across the full width of mine until I was digging down about 20 inches on the right rear. I only made it about 18 inches due to rock, but that got me to within my 6 inch variation.
/ Pole Barn or Metal building? #10
Explain more please
My spot was about 20 inches higher on the back left than the front left. To put in the metal building you cannot have more than 6 inches of variation across your 70 foot building. So if you like me have any slope, you have to dig down the high spot and not fill the low spot. You can’t a have it settle down later. I had to dig down starting at the right front across the full width of mine until I was digging down about 20 inches on the right rear. I only made it about 18 inches due to rock, but that got me to within my 6 inch variation.[/QUOTE]
Not sure why you say do not fill - if it is a pole barn the posts will be down below what you filled and if it is a steel building the concrete columns will be down below the fill level - neither should sink. As someone said - the important thing is drainage.
Having said that I put my steel building 24" into the dirt on one side with a stub concrete wall just so the building did not stick up so high and overpower the house for aesthetic reasons.
/ Pole Barn or Metal building? #11
Mine is a metal building also not a pole barn. With a pole barn, fill would be much less of an issue than the metal framed that sits on top of the ground.
To answer about the floor I will concrete a section in it for my work shop area, the rest would be gravel.
/ Pole Barn or Metal building? #13
Check out some of the pole barn threads here. I think you can get a sturdier pole barn built for similar $$$.
/ Pole Barn or Metal building? #14
Just went to DIYpolebarns dot com,
Similar size with lean to is $15,800, didnt enter doors and windows. Thats material delivered.
/ Pole Barn or Metal building? #15
Yeah, there's gobs of choices. Will give you brain freeze if you let it. Very hard to not miss something. I'd recomend hand drawing a blueprint of sorts on paper with all the dimensions proportionate including door/window sizes and accurate locations. Colors, wainscoat or not, roof overhangs or not, distance between poles, trusses, beams, purlins, etc. Many, many variables to consider and compare to fully understand how good a price quote is.
/ Pole Barn or Metal building? #16
Fill material settles 1" per year per foot of fill, or something along those lines. Unless you properly compact it in 6" lifts. Running a tractor over it doesn't come close to proper compaction.
I've got a pile of trenches I've dug then filled in over the past few years. I keep running over them with my box blade or LPGS. The divot keeps showing back up as it keeps settling. Granted I didnt do a great job back filling, but it's still surprising. I had the tractor & impliments so I didnt wory about it when putting them in. I knew it was going to some degree & didnt care. It's one thing when it's the middle of a field or gravel driveway. By far another when it's under your foundation.
Even if the poles for a pole barn will be in undisturbed ground it's still a pain. Have to deal with grading to make sure water & what not still flows away as required as the ground settles.
/ Pole Barn or Metal building? #17
I have a 36 x 28 pole barn that I built myself and a 40 x 60 metal building that I paid someone to build.
Materials for the pole barn was around $8K, took me 6 months to complete working half the weekends
Metal building was $56K, with $24K for the slab, $18K for steel materials, & $14 for erection labor (our black clay is difficult to build on)
I have a 36 x 28 pole barn that I build myself and a 40 x 60 metal building that I paid someone to build.
What is your opinion of the two?
/ Pole Barn or Metal building? #19
My pole barn is a true barn with a gravel floor and used mostly for storing hay. I can't imagine paying for a concrete slab for an ag barn. $500 of gravel vs $20K in concrete. The metal building is great as a shop and for equipment storage.
RR Buildings on YouTube makes some amazing post frame buildings that would be similar to my metal building but I wouldn't call them a pole barn.
/ Pole Barn or Metal building? #20
OUCH!! My concrete was $12,000. and assembly crew was $7500. on my 40' X 60' in 2015.
BUSH HOG 4R48" ROLLING CULTIVATOR (A64278)
BUSH HOG 4R48"...
2024 Texoma 16ft. T/A Equipment Trailer (A64194)
2024 Texoma 16ft...
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
(2) COLE FERTILIZER DISTRIBUTORS (A64278)
(2) COLE...
