Pole Barn or Metal building?
   / Pole Barn or Metal building? #11
Mine is a metal building also not a pole barn. With a pole barn, fill would be much less of an issue than the metal framed that sits on top of the ground.
To answer about the floor I will concrete a section in it for my work shop area, the rest would be gravel.
   / Pole Barn or Metal building? #13
Check out some of the pole barn threads here. I think you can get a sturdier pole barn built for similar $$$.
   / Pole Barn or Metal building? #14
Just went to DIYpolebarns dot com,
Similar size with lean to is $15,800, didnt enter doors and windows. Thats material delivered.
   / Pole Barn or Metal building? #15
Yeah, there's gobs of choices. Will give you brain freeze if you let it. Very hard to not miss something. I'd recomend hand drawing a blueprint of sorts on paper with all the dimensions proportionate including door/window sizes and accurate locations. Colors, wainscoat or not, roof overhangs or not, distance between poles, trusses, beams, purlins, etc. Many, many variables to consider and compare to fully understand how good a price quote is.
   / Pole Barn or Metal building? #16
Fill material settles 1" per year per foot of fill, or something along those lines. Unless you properly compact it in 6" lifts. Running a tractor over it doesn't come close to proper compaction.
I've got a pile of trenches I've dug then filled in over the past few years. I keep running over them with my box blade or LPGS. The divot keeps showing back up as it keeps settling. Granted I didnt do a great job back filling, but it's still surprising. I had the tractor & impliments so I didnt wory about it when putting them in. I knew it was going to some degree & didnt care. It's one thing when it's the middle of a field or gravel driveway. By far another when it's under your foundation.
Even if the poles for a pole barn will be in undisturbed ground it's still a pain. Have to deal with grading to make sure water & what not still flows away as required as the ground settles.
   / Pole Barn or Metal building? #17
I have a 36 x 28 pole barn that I built myself and a 40 x 60 metal building that I paid someone to build.
Materials for the pole barn was around $8K, took me 6 months to complete working half the weekends
Metal building was $56K, with $24K for the slab, $18K for steel materials, & $14 for erection labor (our black clay is difficult to build on)
I have a 36 x 28 pole barn that I build myself and a 40 x 60 metal building that I paid someone to build.
What is your opinion of the two?
   / Pole Barn or Metal building? #19
My pole barn is a true barn with a gravel floor and used mostly for storing hay. I can't imagine paying for a concrete slab for an ag barn. $500 of gravel vs $20K in concrete. The metal building is great as a shop and for equipment storage.
RR Buildings on YouTube makes some amazing post frame buildings that would be similar to my metal building but I wouldn't call them a pole barn.
   / Pole Barn or Metal building? #20
OUCH!! My concrete was $12,000. and assembly crew was $7500. on my 40' X 60' in 2015.
1973 FORD 9000 TANDEM AXLE DUMP TRUCK (A52576)
1973 FORD 9000...
2024 John Deere 6120E MFWD Tractor (A53342)
2024 John Deere...
JOHN DEERE LOT NUMBER 123 (A53084)
JOHN DEERE LOT...
2016 JOHN DEERE R4038 LOT NUMBER 195 (A53084)
2016 JOHN DEERE...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
