Considering a Mahindra 25Max HST
   / Considering a Mahindra 25Max HST #1
pmeyers
Kennedy Meadows, CA
Mahindra
My first post on this forum, just joined today. I have 20 acres of mountain property in the Sierras that we lost to a forest fire about 20 years ago, including all of the structures and every single tree. My wife and I want to resurrect the property for our grandkids including planting a lot of trees, install irrigation and some out buildings. Recently a 2013 Mahindra 25 Max Hst tractor was posted for sale locally and I would appreciate some help in determining if it a good value. Never have owned a tractor. It is very clean and well cared for. It is original owner, has 280 hours, a backhoe attachment, an unused 12" post hole digger, and an unused box scraper. It also appears to have a small hydraulic leak on the right side rear that is related to the backhoe attachment. Owner claims it loses very little fluid and is likely a leaking seal. Owner is firm at $15,000 Any help is greatly appreciated. pmeyers
   / Considering a Mahindra 25Max HST #2
Mahindra Max 25
2012 - 2014 Max Series
Manufacturer: Mahindra
Original price (USD)
$13,440 (2012 ) ((base tractor, no Backhoe))
$17,500 with FEL + Backhoe ((??))
PLUS SALES TAX FOR ORIGINAL BUYER.
Mahindra Max 25 Engine:
Mitsubishi 1.3L 3-cyl diesel
Mahindra Max 25 Power:
Engine: 25 hp [18.6 kW]
PTO (claimed): 20 hp [14.9 kW]
Capacity:
Fuel: 6.1 gal [23.1 L]
3-Point Hitch:
Rear Type: 1
Control: position control
Rear lift: 1,400 lbs [635 kg]
Power Take-off (PTO):
Rear PTO: live
Rear RPM: 540
Engine RPM: 540@2376
Mid PTO: optional
Mid RPM: 2000
Engine RPM: 2000@2556
Dimensions & Tires:
Weight: 1,693 lbs [767 kg]
Front tire: 6x12
Rear tire: 9.5x16
Length: 104.1 inches [264 cm]
Width: 50.7 inches [128 cm]
4WD turn radius: 7.2 feet [2.2 m]
Mechanical:
Chassis: 4x4 MFWD 4WD
Steering: power
Brakes: wet disc
Cab: Two-post foldable ROPS.
Hydraulics:
Type: open center
Rear valves: 1*
Pump flow: 4.6 gpm [17.4 lpm]
Steering flow: 2.7 gpm [10.2 lpm]
Electrical:
Ground: negative
Charging system: alternator
Charging amps: 50
Page information:
Last update: April 20, 2016
Copyright: Copyright 2016 TractorData LLC
Contact: Peter@TractorData.com
   / Considering a Mahindra 25Max HST #3
I have 20 acres of mountain property in the Sierras.
Mahindra Max 25 is a subcompact tractor, the lightest category of authentic tractor.
Subcompact tractors are mostly used in low stress residential landscaping applications.
With a front tire sized 6 X 12 Max has minimal ground clearance to cross rough ground and downed tree debris. Expect to "high-center" regularly working uneven land.
Altitude reduces engine power output.
This would be an excellent tractor to use as a homeowner learning tool on flat terrain at moderate altitude. Too light for the tasks you list, which indicate a multi-year project requiring stability challenging tasks. It is easy to injure yourself learning to operate any tractor on other than flat ground. Tractor rollover is a life threatening event.
MORE: tractor stability on slopes - Google Search
Mitsubishi produced tractors badged for Mahindra are high quality.
VIDEO: mahindra max 25 - YouTube
I recommend a tractor with at least 3,000 pounds bare tractor weight. Four thousand pounds bare tractor weight better.
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Heavier tractor weight is more important for most tractor operations than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used. The most efficient way to shop for tractors is to list tractor applications first, then determine bare tractor weight needed to safely accomplish your tasks.
Within subcompact and compact tractor categories, bare tractor weight must increase 50% before you notice a significant tractor capability increase. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
Most tractors under 3,000 pounds bare weight operate in residential or hobby farm applications on one to ten flat acres. Subcompact and compact tractors under 3,000 pounds will enter a residential garage with typical 84" door height.
Selling a used tractor is easy. Selling multiple light implements in order to buy heavier, wider implements for a heavier tractor requires a lot of time. Depreciation on implements is generally greater than depreciation on a tractor.
Heavier tractors are built on larger frames with larger wheels/tires. A heavier tractor with large diameter tires has more tractive power pulling ground contact implements, pushing a loader bucket into dirt and pushing snow. Large wheels and tires increase ground clearance, enabling a heavier tractor to bridge holes, ruts and downed tree limbs with less bucking and disturbance operating over rough pasture and woodland.
Safe hillside operation demands more tractor weight than level land operation. Heavier tractors have adjustable rear wheel spreads; wide rear wheel spreads hugely improve tractor stability. Four wheel drive is essential on hillsides. Four wheel drive supplies increased traction. When descending slopes 4-WD augments rear brakes as tractor weight shifts forward, decreasing rear tire grip.
Compact tractors optimized for hill work have liquid installed in the rear tires rather than air. "Loaded" tires are filled 50% to 75% with liquid, which lowers the tractor's center-of-gravity, increasing rollover resistance. "Loading" two compact tractor rear tires will increase tractor weight 300 pounds to 800 pounds over weight of identical two tires inflated with air.
   / Considering a Mahindra 25Max HST #4
If you enter your location in your T-B-N PROFILE members will inform you of used tractors for sale near you. Perhaps the majority of used tractors are offered via internet listing.
Location would permit us to research your altitude.
PARAGRAPH your posts.
Good Luck in your worthy project.
   / Considering a Mahindra 25Max HST #5
Jeffy gets carried away w/ the instructional tutorial . You can design your own post format, sentence structure is NOT dictated in the rules. The location was noted in OP post, more than adequate. Not necessary to reformat avatar.
Jeffy's mantra never changes, buy too much tractor, the price for the mahindra seems a little high but not a pricing expert. Suggest you visit this forum post under mahindra forum. See screenshot. This is an excellent owner's journal, very informative. See mahindra owner/operating, scroll down to title in screenshot.
Jeff9366, Thank you for the information above. Added to the profile. A lot to chew on. The altitude of the property is 6,000'. We don't winter up there, so all of the work we will do does not consider snow. We have recently had a lot of road work and grading done. The tractor would be primarily used for planting trees and shallow irrigation lines. Would be interested in thoughts about whether the price seems fair as well. In the description forgot to mention that the tractor has a 5' bucket for the loader and has 4 wheel drive .
   / Considering a Mahindra 25Max HST #7
$15,000 with low hours, well cared for, two implements, no sales tax in California, an expensive market for tractors ~~~ seems like a buy to me.
VIDEO: How To Evaluate A Used Tractor - YouTube
Used tractors on eBay, near Zip Code 93527: tractor -truck -tug -aircraft in Business and Industrial Supplies | eBay
Tractors and altitude: tractor horsepower vs altitude - Google Search
Max 25 with 25-horsepower at sea level will produce around 21-horsepower at 6,000' altitude.
Turbo-charged tractors, which are offered around 50-horsepower, do not lose engine power with altitude.
Owning/operating a tractor will inspire you to additional projects almost immediately.
   / Considering a Mahindra 25Max HST #8
Jeff9366,
Great information for a first time tractor owner.
Bob
   / Considering a Mahindra 25Max HST #9
My son owns a Mahindra 26 shuttle. A very nice tractor for its size. We like it due to its size to go between the trees. But limited ground clearance. It will not pull a box blade or work the FEL without weighted tires. For clearing trees, look for forks or a grapple and a good chain saw. Forks are cheaper and you can do a good job. Keep the ROPS up and the seat belt on. Hills are another reason to weight the tires. As I have not driven the HST, I would like to hear from owners with small HST for hill sides. The dealer my son got his from, did not think the HST would pull the hills at our place. Good luck with your project.
Great information Jeff3966. Helpful video on what to look for when evaluating a tractor. Good link to that journal post Majorwager. mred2, I was surprised by this: " It will not pull a box blade or work the FEL without weighted tires." Is that on the flat? Maybe I am expecting way too much from this tractor?
2016 Ford Expedition SUV (A55853)
2016 Ford...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
UNUSED FUTURE 10' SLIP ON FORK EXTENSIONS (A57193)
UNUSED FUTURE 10'...
Bomag BW213D Smooth Drum Vibratory Soil Compactor (A55851)
Bomag BW213D...
2022 Caterpillar 259D3 (A53317)
2022 Caterpillar...
