Small tractors doing big work.
/ Small tractors doing big work. #101
BCP,
Have you realized yet that you need to add some weight to the front of your tractor?
I have been pulling a partially loaded dump trailer with my BX2200, which when half loaded the trailer is about 4,000 pounds, and simply keeping the mower deck on made a world of difference up slope. I still sometimes think I should add weight to the front also.
Add a couple hundred pounds to the front of your tractor and enjoy your work more!
Bill
/ Small tractors doing big work. #102
/ Small tractors doing big work. #103
Fixing the well.
/ Small tractors doing big work. #105
Setting some trusses with a boom pole that I made
/ Small tractors doing big work. #108
Nice.
Did you lift them to the roof with the boom pole?
I use it in conjunction with a winch. I keep the boom mostly vertical with the load close to the ground as I transport the trusses to the wall. Then I use the winch mostly to lift up in to position.
Flat level ground is a must! It can be sketchy if you are off level or lifting much weight. It’s very handy but I’m very cautious. A lot can go wrong quickly with that much leverage.
/ Small tractors doing big work. #109
attachment.php
/ Small tractors doing big work. #110
Got the job done.. very nice.
/ Small tractors doing big work. #112
Found this going through some pictures on my phone. A professional excavator that I know was telling me a technique he used to take down trees so I gave it a try.
I Dig around three sides of tree. Then I pile dirt on top of the fourth side. Then I push the tree over on top of the pile of dirt and it pops the stump out.
It kind of works but my machine is kind of small for that.
/ Small tractors doing big work. #113
It takes a big machine to just push trees over but with techniques like the one above a small machine can get the job done on a very small scale.
/ Small tractors doing big work. #114
I have a 20 hp Jenma (Nortrac) that I bought in 2006 to cut, rake and bale hay 10 acres using a rebuilt JD-9 sickle bar, a 70's era side discharge rake and an international 47 baler. I use a home made spray rig made with a roller pump, 55 gallon drum and what's left of an international spray boom. I brushhog another 10 acres that isn't hayed with it. All of my equipment cost less than $1000 because nobody else wanted it.
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
2 Rolls of Screen (A62613)
2 Rolls of Screen...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2025 28in Forks and Frame Mini Skid Steer Attachment (A61572)
2025 28in Forks...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
2018 Bobcat S-570 (A63689)
2018 Bobcat S-570...
