New Snow Blade
/ New Snow Blade #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
Just picked up a front blade for my 4520:
This one is manual angling since my rear remote is used for the snow blower chute rotation. It's 84" wide so when I angle it (it goes 15 and 30 degrees both left and right), it'll still cover the rear tires width.
A blade is a bit quicker for light snows...say, 6" or so. Also, I think the rubber wear bar will clean right down to the drive and road surfaces. The steel wear bar came with the blade...rubber being optional. Rubber will be easier on the asphalt drive.
I did talk to the dealer about adding another hydraulic remote for the blade angling. If I go that direction, it'll be next year before I do it.
If we have snows like we've had over the last few years, this set up will pay for itself easily....and, if we don't get any snow...well, that's fine too! The last few years' winters have been pretty tough...
/ New Snow Blade #2
That ought to do the job Roy. Nice looking set up. Does the blade float? My road is undulating so would need some flotation.
/ New Snow Blade #3
I have a snow blade...you'll really like it. I've been wanting a rubber strip as well. I think I'll get one now that I see yours.
/ New Snow Blade
Not sure...I think I'll have to use the loader's float, but using that puts the carrier frame (the part that mounts to the loader) on the ground. I'd like to use float and might have to figure out some way to prevent the carrier frame from dragging. I have thoughts on that...
The blade does have skid shoes.
/ New Snow Blade #5
I had to lower the shoes on my blade 2", I can't use the loader float, I have to carry the loader and let the play in the blade act as it's float.
IF you place your bucket flat or curled back slightly on the ground and push does it slid nicely or grab and lift the front wheels in the air.
/ New Snow Blade #6
Blade blower best setup meet old man winter head on. :thumbsup:
12" fluff snow blade will still perform well just the wet snow you'll have to make sure you push back far enough..
/ New Snow Blade
Hi Thomas...if it's more than 6", I'll use the blower first...then the blade to clean to the drive and road surface.
I'd been thinking about a front blade for years...finally got off my butt and did something about it...
/ New Snow Blade #8
For deeper snows that’s my go-to setup. I added a 1.5” thick polyurethane edge on my rear blade last year, and may put one on the front this year. Poly or rubber is soooo much easier on the pavement, quiet, and they glide over stuff that a steel edge will tear up.
I am curious to see how your rubber edge wears... it looks substantial.
I don’t float my fel mounted blade either, but feather the stick to keep most of the weight on the front wheels after the blade touches down. It’s easy enough on relatively level ground, but gets challenging on driveways that go downhill to the roadway edge.
/ New Snow Blade #9
RoyJackson
I thing I found out..learn the hard way...if plowing at night while snowing mailbox fair game. :eek::eek:
/ New Snow Blade #11
Nice set-up;I think you will find that the "solid" set-up works fine for a paved drive;mine floats but I am plowing gravel drives for the most part.
/ New Snow Blade
I'm very careful around mine and my neighbors' mailboxes...haven't nailed one (yet). We leave that destruction to the township plow guy (when he does plow). Two reasons I started plowing or snow blowing the road...plow guy doesn't show up half the time...and when he does, he makes a beeline for the mailboxes (mine was nailed last winter)
I've always done my drive and my neighbor's drive...the neighbor's because they're New Yorkers and only come to Bethel occasionally. I started doing the road (about an eighth of a mile) two winters back.
/ New Snow Blade #13
Great looking blade Roy, now your all set for ole man winter, I use the same set up also but usually have front and rear blades on in the beginning of the season then if reports of 12" or better I'll put on the snow blower. Hey did you happen to see the Old Farmers Almanc? I believe they are predicting cold and heaver then normal snow falls for the New England States.
DevilDog
/ New Snow Blade #14
Not sure if you can do it with your setup, but I see lots of people have it so the plow can freely pivot up or down (in relation to the loader & mounting plate), but the plow is lifted by a chain from the top of mounting plate, thus the "float" (in the up direction) is built into the action of the chain. Thus the loader arms don't need to float.
/ New Snow Blade
I've seen posts with set ups as you describe. Most of them have been home built or modified truck plows mounted on the loader bucket. The one I have doesn't allow or that kind of float. I do see the advantages though.
I figure I'll try it by controlling the loader. If that doesn't work like I hope it does, I'll rig some wear plates to the bottom of the carrier (part that mounts to the loader frame) and use the loader's float.
/ New Snow Blade #16
Roy,
Nice plow but read the post by Lou. I have a pusher, and in float, the rubber edge tends to "dig in " and raise the front wheels slightly.
The result is it defeats the advantage of front wheel drive assist. Better to keep minor tension on loader arms.
Another caution. Not a fan of the bolts and washers that retain the rubber cutting edge. It is possible for washer to pull through. A continuous metal band across the entire length offers better protection. I will post a photo.
/ New Snow Blade
Roy,
I'm not just going to drop the blade and go. I'll rig the skid shoes so the rubber is just touching the drive and road. The shoes will take the brunt.
Two big advantages of the rubber...three, actually....more of a squeegee effect when plowing...better back dragging (only do that by the garage doors) and, unlike the bucket, this blade trips (that's not really a rubber advantage, but you know what I mean)
/ New Snow Blade #19
Hope you will report back after you have tried it in a few storms. Looks like a great set up.
/ New Snow Blade #20
Roy, I have a tractor similar to yours, a 4320 with the factory FEL. I also have a rear snow blower. I use my front bucket to clean some of the snow by back dragging and also forward cutting. The back dragging is easy but the front cutting is difficult. My trick is to hold the joy stick in the float position but then do rapid moves to the right to roll my bucket down to a approx. cut angle of lets say 5%. The bucket is riding on it's backside per se. If you come out of float during this rapid movement to the right you loose the attach angle and you need to start over again. Now if I get the attach angle to steep and it digs in, it will pick the tractor up and roll the bucket down as you also know. I do not have a front blade like yours but I think this method should work for your front blade since it does have skid shoes. It generally takes me a couple of try's to get the angle of the bucket correct. I will over curl the bucket back, hold the joy stick in float position and right stab the joy stick, generally several times, until I have what I think is the correct angle to cut thru the snow without digging in. I set the angle referencing the bucket level indicator. I keep the joy stick in float until I have finished the pass. Part of the reason I am suggesting this is I have fabricated a similar type of set for a friend of mine using a factory blade and mounting. He brought the snow plow back this spring and I put even larger skid shoes on the blade. Factory skids were about 8 inches in diameter and replaced with if I remember with 10" wide 15" long shoes. He complained about not being able to keep the carrier from dragging. He has a New Holland tractor with a Woods FEl. I suggested this methods and also showed him this spring but on gravel ground with my tractor. Just as a reference the float only affects the vertical position of the snow plow. This is how I set up my bucket and maybe it would work for your snow plow. It's worth a try. Later.
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
2012 T/A Frac Blender Trailer (A64194)
2012 T/A Frac...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
2020 Freightliner M2 106 Johnston VT652 Sweeper Truck (A64556)
2020 Freightliner...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
Jack Daniels Metal Sign (A65583)
Jack Daniels Metal...
