Standby Generator
/ Standby Generator #1
jaydee325
Casco, Mi
John Deere X584 Garden Tractor & LS R3039H
We finally bit the bullet and installed a standby whole house generator last Friday. Interestingly, we had a power outage the following Monday!
My wife said, "worth every penny". I agree.:thumbsup:
/ Standby Generator #2
Ours was installed the next spring after Isabel (2004). We haven’t been without power for more than 20 hours since. A great insurance policy!
/ Standby Generator
When the crew showed up to install the generator, I jokingly said to them that now that I spent all of this money, the power would never go off again. The reply was, "you are paying to never be without power again. You will either have it from the utility or the generator! And, for sure, that is the goal.
/ Standby Generator #4
I know a few people who have non functioning standby systems. Murphy loves to hear things about never being without power. A challenge for him I guess.
/ Standby Generator #5
Similar happened to me. I bought a Honda powered 6Kw really inexpensive, kept it for 10 years. Never had to use it, just start it occasionally. Then Sodo posted about a VERY INEXPENSIVE Duromax 10KW so I bought one, didn't need it, but loaned it to my son. The house where it's at is in dense suburbs of Alexandria, Va, I've owned the house since 1978 and the power had never gone out for more than a few hours.
THEN about 2 weeks after he got it the power went out for a week just on his street because someone cut a line. Needless to say he broke in the generator.
Talk about timing.
/ Standby Generator #6
What kind did you end up getting?
I've been eyeing a propane powered Generac, but I haven't gotten to it. We already have a 1000 gallon propane tank for the furnace and water heater.
/ Standby Generator #7
We had a 22kw generac put in about 3 years ago. It runs off of propane. One purchase the wife and I agreed upon very easily. Has saved us a bunch of times.
/ Standby Generator #8
We had a 17kw generac installed 8 years ago.No regrets yet.
/ Standby Generator #9
Got a 17kw Kohler about 10 years ago, for our 4-season cottage. Sleep well knowing that it will fire up and keep the furnace running if we lose power in the dead of winter when we are 2 1/2 hrs. away.
/ Standby Generator
22 kW Generac on propane. Needed the extra kW since we have a geothermal heat pump.
/ Standby Generator #11
I have never heard anyone say they regret having a generator installed. We only have a portable unit but I sleep well knowing I can fire it up and have the basic necessities met.
/ Standby Generator #12
Last winter i installed a 22 kw for a customer and their power failed that evening for 3-4 hours due to a fire at the sub station. They called me the next day and asked me how i did that..:).
So far ive never had anyone tell me that wish they hadn't install one.
/ Standby Generator #13
While my house was being built we were in a rental nearby. The power went out for 4 days. No backup in rental. I called the builder and told him to have the electrician install a transfer switch and the plumber to plumb the propane to a quick disconnect near the generator plug. Bought a 7.5 KW generator. Runs everything in the house except the electric hot water.
We have 2 x 100 Gal house propane tanks so can run gen for about 6-8 days. I have no other fuel-powered equipment so it would be a pain dealing with keeping Gas fresh for a standby generator.
/ Standby Generator #14
What size propane tanks are you using for your standby generators in colder climates. Trying to figure what I would need.
/ Standby Generator #15
We installed a 22KW last spring. I told my neighbors as a result, we would never lose power again . I asked for contribution for our shared expense :laughing:
It's come on 3 times for a total of 2.5 hours or so.
We buried a 500 gallon tank since central Georgia does not get too cold, not for long anyway. It runs the genny and the kitchen stove.
/ Standby Generator #16
We started off with a 4 kw generator and a small input box that was already there, as this house had a propane generator (removed by seller) when we bought it. This was just after Isabel in 2004. Had the input system improved a bit 2 or 3 years later. It operated the basics but required turning everything off to repressurize the water tank every so often. Operation on this small generator gave me lots of data to figure out how much we needed for a whole house unit.
About 7 years ago, we installed a 12.5 kw Isuzu diesel generator from the Maine diesel people. A friend of ours is a licenced electrician. My neighbor helped sit the generator in place with his bigger tractor and fork lift. My friend put in a completely new 200 amp panel to replace one of the 2 we had plus the little generator panel from Generac: ending up with 2 panels at 200 amps each, one on generator one off. The Generac has 4 or 6 (think it's 6) special circuit breakers that only allow themselves to be on if there's room on the generator. Well, we've NEVER had a problem running anything on the 200 amp panel, including the clothes dryer during a power failure (and quite a few of them lasting generally 4 to 8 hours). One of our electric water heaters is on it and about 3 or so Tiny Titan heaters at the use points.
The main 4 ton heat pump is not on the 200 amp Generac panel, but the 2 ton upstairs unit and the smaller ductless units for the basement are on the Generac. Our old 2.5 ton upstairs unit was put on it initially. My electrician friend put in a special circuit to take the backup heat coil out when the generator was on. The new 2 ton heat pump has its backup coil out via its thermostat. The ductless unit has no backup coil.
The Isuzu is about the sweetest, quietest diesel that I've experienced. Absolutely NO diesel clatter and usually no smoke on startup. Uses a whopping 0.2 gph of diesel. This is over at least 130 hours so far. I did the 50 hour oil change. Other than that, I just clean it up a couple times/yr and keep tabs on the diesel in its 60 gallon tank. Occasionally, I'll pump out of it for the tractor.
Ralph
/ Standby Generator #17
I’m glad to read the positive reviews on Generac. That’s the only brand I’ve seen advertised. I’ll try to get moving on that before winter.
/ Standby Generator #18
I tell he customers a 250 gal is minimum, but i generally install 22 kw units. My own generac 22 is fed from our 1000 gal buried tank. My entire house is propane.
A 22 runs in the 2.5-3.9 gal per hour depending on load.
Mine powers a 3900sf house and the barn, as i need the heated horse waterers protected. Also keeps hot tub hot if power is out in winter here in north idaho
/ Standby Generator
I upgraded from a 330 gallon to a 500 gallon at the recommendation of my installer/dealer.
/ Standby Generator #20
Interesting - - been out here in the pucker weeds 36+ years. I will get 1 or 2 announced outages a year. Local Co-Op utility upgrading their equipment - usually two hour outage. Otherwise its normal to go 6 to 8 even ten years with no outages. In all the years out here - one major outage and it lasted 27 hours.
Our Co-Op electric utility is recognized in the industry as one of the very best in the business and, also, with one of the lowest electric rates.
I spent my "allocated standby generator funds" on a new and bigger rear blade - thank you.
Depth Band wheel, Scapers (A68191)
Depth Band wheel...
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
2018 FORD F-150 (A67714)
2018 FORD F-150...
2012 RAM 4500 (INOPERABLE) (A67714)
2012 RAM 4500...
2016 PETERBILT 337 CAB AND CHASSIS (A65643)
2016 PETERBILT 337...
1990 Dorsey 42' Flatbed Trailer (A64912)
1990 Dorsey 42'...
