Filling tires with WW fluid
   / Filling tires with WW fluid #51
Boomer 40 rear wheels are not configured for any added wheel weights. No holes in wheels. For snowplowing I wanted to have added weight besides rear back blade to compensate for a loader full of wet snow. That's why I needed tire ballast...it was my only option.
   / Filling tires with WW fluid #52
Just wanted to add a note: You can buy WW fluid concentrate much cheaper than buying the premixed stuff. A quart will make 55 gallons and should cost you $20-25. You will need to add enough antifreeze to get to where you need to be for your winter. Most "winter" WW fluid mixes use simple alcohol as their antifreeze agent. You could also go with non-toxic propylene glycol.
   / Filling tires with WW fluid #53
I'm curious - why not just use water + antifreeze instead of this? Is there an anti-corrosive agent in the WW concentrate?
   / Filling tires with WW fluid #54
It seems like a proprietary, maybe franchise thing. But hey, it's beat juice. Can't one get that elsewhere?
It's beet juice that's almost the consistency of molasses. Normal beet juice like what you can buy to drink is not going to stay liquid down to -35˚.
   / Filling tires with WW fluid #55
It is an anti-corrosive. Whether you would need it would depend on what you plan to use for antifreeze.
   / Filling tires with WW fluid #56
Hello and good afternoon RustyA,
Is this something you are contemplating doing or have you done this already?
Do you know how much torque your final drive will give you through the transmission to the axle shafts on the model 40 tractor? You have to be sure that the axles will slip enough to prevent any damage to the final drive.
using 2 or 4 link ladder chains it will give you the ability to slip to avoid causing possible damage to the the rear axle.
Do you have clearance on the front axle to install front snow chains as well as rear chains??
I have had windshield washer fluid in the JD LA115 lawn mower now for 6 years.
Before I loaded the rears I found it was worthless in snow even with my fat backside and two 42 pound wheel weights on it before I filled it with a tire filling valve and a funnel attached to a piece of garden hose.
The 4 link V bar chains are less expensive than the heavy European snow and ice chains.
Have you looked at the European snow an ice chains at all??? they are pricey but they are really effective in plowing snow and working on ice.
Even with 2 link ladder snow chains you will have plenty of traction.
   / Filling tires with WW fluid #57
Chains will stress the drivetrain ten times as much as fluid in the tires.
   / Filling tires with WW fluid #59
Especially if they slip and then catch traction...
Aaron Z
Personally, I would never chain the front tires on a 4wd tractor either. But that's just me..... :)
   / Filling tires with WW fluid #60
Interesting that this board only talks about filling through the valve stem and other boards talk about laying the tire on the side then breaking the bead to simply pour the stuff in. Maybe the size of tire matters.
2014 CATERPILLAR 259D SKID STEER (A51242)
2014 CATERPILLAR...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
DEERE 250 SKID STEER (A51242)
DEERE 250 SKID...
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
2010 POLARIS RANGER 4X4 4 SEATER UTV (A51222)
2010 POLARIS...
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2008 STEPHENS...
