Gas cans - really
/ Gas cans - really #143
I’ve got an new old school jerry can and I don’t like it for fueling the tractor since it’s metal and scratches the hood. I much prefer my VP cans. I’ve also got a VP knockoff can that I paid $25 for.
/ Gas cans - really #144
/ Gas cans - really #145
The no spill can spout works great but you can speed up the flow quite a bit by adding a vent cap on the top back side by the handle. I put one on both my diesel and gas can, saved one and gave a couple to buddies. I think it almost doubles the flow as it doesn't have to take a break to breathe.
Amazon.com: 5 Yellow Fuel Gas Can Jug Vent Cap: Garden & Outdoor
Only issue with these vents as it negates auto shut off feature of "No Spill" can/nozzle I believe...
Dale
/ Gas cans - really #146
I have about a dozen NATO or GI jerry 5 gal cans I use with super-siphon hoses, but the easiest I've found to fill my Yanmar is the 2.5 gal "No Spill" cans.
The fill for the LX 4500 is high behind the operator seat. 5 gal cans are too heavy, but two 2.5 gal containers are just right.
/ Gas cans - really #147
Dale
Nope! Not mine. You must continually hold the 'fill' button down on the spigot to empty. As soon at you let go, it shuts off. No Spill... and has nothing to do with adding a vent. No vent means the air has to come through the fill spigot to replenish the emptied volume thus slowing down the rate of pour. An auxiliary vent solves that problem.
/ Gas cans - really #148
I like the no spill cans for filling my small engines. Emptying a 5 gallon no spill takes forever.
/ Gas cans - really #150
One of the features of a No-Spill can is that the fuel flow stops shortly after the fuel level reaches the spout, stopping more air from going into the can. This lowers the chance of overflow. A vent will de-activate this feature.
Bruce
/ Gas cans - really #151
I fuel my tractors with a transfer pump, but for the small equipment I use No Spill cans. They are hands down the best can I have ever used.
/ Gas cans - really #152
You're describing the manual shut-off. The No-Spill cans will automatically stop flowing when the tank level has reached the No-Spill nozzle, even with the button pressed. Dale is saying your auxiliary vent breaks the auto shut-off feature.
/ Gas cans - really #153
Now that makes sense. However I have never had a problem overfilling even the smallest tank I was refueling even with my old vented containers which I still use.
Common sense and paying attention goes a long way.;)
/ Gas cans - really #154
I’ve never had good luck with the auto shutoff. They pull enough vacuum on the van to let out fuel to overflow the tank.
/ Gas cans - really #155
Well over the years I tried many solutions with a small hand crank pump winning for a while.
Last winter I found a small 12VDC powered pump that fitted into my 5 gal fuel can that came compete with an inline switch and debris screen, all that for about $10.00 on a web site.
Not super fast but just nice for my CUT.
And no more scratched hood or sore shoulders and better still no spills.
One nice feature is that the hose self drains back into the fuel can so no spills.
The warning label says "for fuel only", not for gasoline, makes sense as the little brushed motor actually sits in the fuel as it drives a small impellor to push the fuel uphill.
They ship without a fuel hose but that is easily found locally. Takes 5/8" hose and I found coolant hose* to be the best as poly hardens when exposed to fuel.
* coolant hose is designed for engine compartments that are subject to oils, heat and fuel spillage that made sense to me.
I found silicone based coolant hose to be the best and most supple to use.
Neat advantage is 5/8 hose neatly fits 1/2" copper pipe for splicing or fitting a nozzle etc. (I made a nozzle using pipe bits and a 90 deg fitting)
/ Gas cans - really #156
NOt sure of your response, my NO SPILL quits filling once the level of fuel reached end of spigot even if you keep button pushed down, like automatic shut off on gas pump nozzle... Sure saves a on a lot of run over and wasted fuel as long as auto shut off is functioning... Believe it has to do with the small tube in spigot being able to draw in air to vent tank... Maybe I am mistaken, but don't find need for extra vent for increased speed, beside the extra moments of quiet time are welcome...
Wife loves her "No Spill" for "her " mower saves her from flooding area with fuel... They come is one gallon sizes too...
Dale
/ Gas cans - really #157
Dale
I have a 5 gallon, 2.5 gallon and two 1 gallons. They’ll all overflow a little bit unless you manually shut it off.
/ Gas cans - really #159
I have spouts on my racing jugs. It doesn’t flow as fast as s high flow funnel, but there’s no funnel to keep up with.
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
NEW Wolverine PD-12-08D Skid Steer Post Pounder (A62679)
NEW Wolverine...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
Merritt Headache Rack (A64127)
Merritt Headache...
Mayrath 10 x 30' Truck Auger (A66285)
Mayrath 10 x 30'...
