4300 Range Shift Fork Replacement
/ 4300 Range Shift Fork Replacement #1
jlgurr
Bostic, NC
Massey Ferguson GC1705, John Deere STX46
Dad and I working on a 4300 with Collar Shift that needs a broken fork replaced on the range shifter. We've drained the oil in the case and removed the top cover to find the problem. Service manual indicates the next step is to split the tractor at the rear of the tunnel.
Hoping there might be someone here that has come across this in the past and found a shortcut to avoid the case splitting.
Thank you,
Jeff
/ 4300 Range Shift Fork Replacement #2
Nope, it has to come apart
/ 4300 Range Shift Fork Replacement #3
jl
Hope you will take pics and document they job of doing this repair.
If questions arise, should be some good assistance from your TBN friends.
jl
If we do the repair I will definitely document for posterity.
Jeff
2015 Dodge Grand Caravan Van (A61569)
2015 Dodge Grand...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
Vertical Steel Well Tank (A61570)
Vertical Steel...
Tire Balancer (A61570)
MULTIQUIP LIGHT TOWER (A60736)
MULTIQUIP LIGHT...
Zero Turn Mower (A59231)
Zero Turn Mower...
