Oil & Fuel CK30 fuel gauge not working
/ CK30 fuel gauge not working #1
Sugar Creek Farm
Lovelaceville, Ky.
Case IH JX80
Before I start tearing into anything, thought I’d ask here first to see if you guys might have had this small problem before. It was working fine then when I filled the tractor up the other day it never moved off of E. Possible wire off? What might be the problem?
/ CK30 fuel gauge not working #2
Maybe just stuck in the down position. I used to own a Ford pickup that did that every time it got to empty. Driving over a few bumps would get it working again.
/ CK30 fuel gauge not working #3
What year tractor because of two different styles? As mentioned, it could be stuck, the float hitting the side of the tank, possible wire off, I've seen mice chew on wires, or the float gauge itself went bad. I'd start with checking the wires and go from there.
It’s a 2013 CK30
