Your towing rigs and trailers
   / Your towing rigs and trailers #3,021
It's weird to me that you folks have trailers that have issues when backing them up. I've used various 10K equipment trailers from places I've rented bobcats from in past years (4 or 5 in the past 10 years) and they all had surge brakes and I had zero problems backing them up anywhere. My dad also had a big old Larson inboard/outboard boat back in the 70's that had a trailer with surge brakes and he never did anything special to back it up. Admittedly I don't have tons of experience with trailers with surge brakes but given what I know I'm surprised.
Rob
The problem isn't backing them in general - it's backing them up a (steep) hill; the slope in that direction looks like enough deceleration for the surge brakes to engage.
   / Your towing rigs and trailers #3,022
Tractor Supply and Runnings both run specials on them in the $7-10 range from time to time.
Can you point me to the law saying that (or at least the town/city where it is illegal)? People have told me that, but I have never been able to track down a town that has that ordinance.
Aaron Z
No I can’t point you to the ordinance. But I will say there used to be signs at the city limits of Russellville, KY. I haven’t been down there in a few years but I presume they are still there. Seems like I’ve seen them other places also but I can’t put a name to it.
   / Your towing rigs and trailers #3,023
All mechanical. A lever + cables that will get the pressures even in each wheel and a strong over-center spring to keep it either locked or unlocked.
Here is an overview of the system:
I think my trailer does what you mentioned. I've backed up fully loaded onto a steep hill and after a bit of struggling to get it to start to move, the surge brake just fully retracted and after a slight bump the trailer just felt like it was not braking.
Some surge brake systems will fully release when they sense reverse. Problem is it takes some time. Others had a lever that you got out and pulled when backing. This released the pressure on the system. Only ever used surge brakes on anhydrous ammonia tanks and liquid nurse tanks. They all had the manual release. Never had one with a parking brake.
   / Your towing rigs and trailers #3,024
16' Ram 3500 Dre, Aisin transmission, 4.10 gears with a 35' + 5' dove tail, dual tandem trailer with triple ramps.
   / Your towing rigs and trailers #3,025
As of April 2007, surge breaks are legal anywhere in the US: http://www.rentalmanagementmag.com/Art/tabid/232/ArticleId/10591
Before that, it was legal some places, but not in others on the commercial side.
Aaron Z
   / Your towing rigs and trailers #3,027
What does that 40’ trailer weigh? If it has 12k axles, would you feel comfortable putting 20k lbs on it?
I want a 40’ gn, but as the length goes up, the weight capacity goes down.
   / Your towing rigs and trailers #3,028
Taking a quick look at the Big Tex website their trailer with 12k axels at 35+5 long can’t haul 20k. Its payload is 17k and weighs 8900 pounds.
   / Your towing rigs and trailers #3,029
Nice setup !
Rgds, D.
Thanks man, I hope to be driving the same rig 10-15 years from now. Figure buy once cry once. Lol
It's a PJ classic flat deck trailer and they don't list the weight with dove tail just straight deck. If I remember right they said about 8,500 lbs. So that's 16,500 lbs capacity left. The hitch is the limiting factor on mine at 25k lbs max rating.
But, I believe you can get an upgraded GN hitch rated for 30,000 lbs & twin 15k lbs axles which gives you a GVWR of 30k. That would leave you 21,500 of capacity on this specific trailer.
   / Your towing rigs and trailers #3,030
My rig 14 Ram Outdoorsman and a 20' Big tex/12k limit trailer. Tractor is a Ck3510SE (2734lbs) FEL (840lbs) with filled tires (235-250lbs/tire). The Bbull (604lbs), Bblade (514lbs) and I brought home a Lpride tiller (362lbs). This adds up to 5554+2800 for trailer is 8354lbs. I pulled her 200 miles each way at 55-60mph with no problems at all. It did squat down a bit and definitely more on the way home with tiller in the box. Im hoping my other tires and adding some airbags will help to mitigate that issue.
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
2020 MACK P164T (A58214)
2020 MACK P164T...
2015 Ford Transit Connect Passenger Van (A59230)
2015 Ford Transit...
VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
VOLVO ECR25...
200 Gallon Tank (A57148)
200 Gallon Tank...
John Deere TX Gator (A60462)
John Deere TX...
