Filling tires with WW fluid
   / Filling tires with WW fluid #41
78 gallons Rimguard @ 3.25/gal=253.00
sales tax 17.49
service call 65.00
total cost 335.49
For a Boomer 40 with R4 rear tires total estimated weight 858 lb @ 11.0 lb/gal
   / Filling tires with WW fluid #42
For the difference in price and your location, I would get the RG and be happy. I wish I had a closer dealer. I filled my tires with WW fluid and it went quickly and well but I live in TN so I'm not terribly worried about -25 degree tractoring.
   / Filling tires with WW fluid #43
RG is more expensive, but does add more weight. But the main advantage to WW fluid to me would be the ability to drain and refill on my own in case of a punctured tire. I've had to plug my tires several times, and I can't imagine having to call a dealer or tire service every time that happens.
   / Filling tires with WW fluid #44
A MAJOR good point!
Nearest Rimguard dealer to me is over 100 miles away.
How many $ for a 200 mile round trip Rimguard service call?
   / Filling tires with WW fluid #45
Water, with a mixture of slime from being in south Texas helping a friend cut the devils voodoo tree mesquites down. If I ever have to remove the tire it痴 gonnnnnna be a slippery slimy stinky mess.
   / Filling tires with WW fluid #46
A MAJOR good point!
You can plug a punctured tire with RG just the same and WWF. Draining fluid not necessarily required.
   / Filling tires with WW fluid #47
Only patching works with tubes, and I use tubes.
I can drain/refill WW fluid.
I cannot drain/refill Rimguard.
   / Filling tires with WW fluid #48
am I stupid here or what? why not use wheel weights? then u don't have to worry about a mess, pumping/removing, plugging or any of that stuff. I could under stand not having a ballast because of wanting to use a rear implement but if you live in my area with locust/hedge you are going to have flats period
   / Filling tires with WW fluid #49
With any weight choice cost per pound is considered. Cast wheel weights are by far the most expensive. Usually around $1 per pound.
My WWF weight cost .11 cents per pound.
Many of us do not face the same terrain that you do. We would be stupid to use wheel weights when more cost effective alternatives are available. One size does not fit all.
Also, filled tires will have a slightly lower CG but for most of us (at least for me anyway) it is a cost issue.
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2021 JCB 1CXT Skidloader/Backhoe (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 JCB 1CXT...
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
Ih 4300 Field Cultivator (A50514)
Ih 4300 Field...
2003 PETERBILT PB 330 WATER TRUCK (A51243)
2003 PETERBILT PB...
