Designing a bin tipper, sizing hydraulics.
   / Designing a bin tipper, sizing hydraulics.
Also, Seeing that it has dual cylinders, would I need to worry about balancing the two of them so they extend at the same rate?
   / Designing a bin tipper, sizing hydraulics. #22
The dumper frame would keep the cylinders in phase, and as for the pivots, either would work fine. The bearings will require a lot less maintenance , were the pin bushing set up will require a lot more greasing and be a bit messy.
   / Designing a bin tipper, sizing hydraulics. #23
Good advice. . Plus depending on where you are a food safe grade grease would prob need to be used.
Oenophile's shun greasy wines. Probably why wines are rarely paired with french fries.
   / Designing a bin tipper, sizing hydraulics. #24
Food safe grease and hydraulic fluid would probably be a good choice...
Aaron Z
Yeah good point on the messy / mantinence factor on the pin bushings. Pillow block for the win. I do feel like I might stick with the single cylinder in the middle. Feels like less overall complication of the design for me. That is unless anyone has a good reason to go double. I see both ways in the commercial versions. Those reference pics also feel like they are a good reference for burly factor / metal sizing / probably a bit more burly than I need to go.
   / Designing a bin tipper, sizing hydraulics. #26
As a point of reference the dumper I sent photos of would be typically used for a bin gross weight of 1000 pounds.
Depending on moisture content of your grapes (or how deep you load your bin) I suppose you could use a central mounted single cylinder. Personally I would use two for the greater lift capacity for possible different applications and (or) resale.
   / Designing a bin tipper, sizing hydraulics. #27
He doesn’t want to use forklift to lift it.
The ones I'm talking about are not for a forklift. Pretty hard to get a forklift into a 36in door in construction sites. Something like this and maybe raise it up higher Screenshot_20180720-195238_Google.jpeg
   / Designing a bin tipper, sizing hydraulics. #28
Those can only dump on the ground or over a ledge.
yeah i definitely need the lift height so the auto tippers like that wont work form me. I guess for the single i need to calculate how big a cylinder i need. Typically a bin will weight 800-1100 pounds. so that lift you referenced is right in my range.
   / Designing a bin tipper, sizing hydraulics. #30
Are you guys not reading my posts much? Like my last one said (#27) last sentence. Lift it up higher.
2014 Ford E-450 Super Duty Shuttle Bus (A56858)
2014 Ford E-450...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2014 Ford Explorer SUV (A56859)
2014 Ford Explorer...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A55973)
2022 Power Screen...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
