Replacement for my JD 318
/ Replacement for my JD 318 #1
EdB3
east coast FL
1987 J Deere 318, 2020 x380
I have a 1987 JD 318 46" deck which I love, I'm moving to FL and will not have enough space to store her inside, there are community restrictions as to storage shed size and best I can do is a small shed with a 46" wide opening, naturally my 46 deck is 53" wide. I did see (or thought I did) a 36" deck for the 318 but can't find it anywhere.
As a replacement, I was looking at a used x310 with a 42" deck and comparing with a new x370, same deck. While the x370 is the replacement for the x310 I noticed the x310 was 90 pounds heavier that the x370.
I'd appreciate any suggestions re finding a 36" deck for my 318 and/or comments on the used x310 vs new x370.
Thanks, Ed
/ Replacement for my JD 318 #2
Cut the shed opening wider.
/ Replacement for my JD 318 #4
I would suggest finding a X310 or X370 and measuring the width with chute tilted up. No experience with the X3** series so I can't help you with there performance although I 99.99% sure that they are not built as heavy as the 318 is.
Around here The "D" series are at every box store but again not sure of your needs.
2009 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
Polaris Ranger 4x4 Gas Utility Cart (A66734)
Polaris Ranger 4x4...
2025 20in. Rotary Brush Cutter Mini Excavator Attachment (A66734)
2025 20in. Rotary...
525 GAL WATER TANK (A68842)
525 GAL WATER TANK...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
2008 X534 AWS For Sale
