Quick Hitch Adaptor
/ Quick Hitch Adaptor #1
ch47dpilot
Gold Member
Enterprise Alabama
09 Kubota L3400
I have the TS version of Pats Easy Change System. The adapter is designed for CAT 2 but my attachments are CAT1. I found these on Amazon. Amazon.com: RanchEx 1;)74 Quick Hitch Adapter Bushing Kit - Cat 1 For Quick Hitch (SKU 12851): Garden & Outdoor based on the description I figured they would work better than sleeves with washers and lynch pin. When I got them(and in description online) it says 1 1/8 OD. Well all 3 I ordered where 7/8" ID and 1 7/16" OD. Since all 3 where the same I figured its not a packaging error. My question is has anyone bought something similar that had the CAT 1 7/8" ID and 1 1/8" CAT 2 OD.
/ Quick Hitch Adaptor #2
I use those type for my QH-compatible implements that use the one-sided pin arrangement. Most of my implements have the clevis-type pins, which I like much better.
Having said that, those one-sided pin adapters work great, easy to install and ensure the implement doesn't slide off one side.
Good luck.
/ Quick Hitch Adaptor #3
It won't slide off one side with the simple bushings, either. The other side stops it. :)
Bruce
/ Quick Hitch Adaptor #4
Generally those knob style adapters are for the Quick Hitch standard. Which is Cat 3 diamater pins. So those adapters are for Cat1 to Cat3 lin diamaters. Cat 2 gear generally has the clevis style pin supports on the impliments as the clevis are a lot stronger.
/ Quick Hitch Adaptor #5
I have the TS version of Pats Easy Change System. The adapter is designed for CAT 2 but my attachments are CAT1. I found these on Amazon. Amazon.com: RanchEx 1274 Quick Hitch Adapter Bushing Kit - Cat 1 For Quick Hitch (SKU 12851): Garden & Outdoor based on the description I figured they would work better than sleeves with washers and lynch pin. When I got them(and in description online) it says 1 1/8 OD. Well all 3 I ordered where 7/8" ID and 1 7/16" OD. Since all 3 where the same I figured its not a packaging error. My question is has anyone bought something similar that had the CAT 1 7/8" ID and 1 1/8" CAT 2 OD.
I bought and returned that. It came w bushings. Tsc carries a bushing that should do what you want. As does rural king.
more info coming soon! (A61569)
more info coming...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2013 CATERPILLAR 305E CR EXCAVATOR (A64279)
2013 CATERPILLAR...
2012 Ford F-450 4x4 Altec AT200A 30ft Bucket Truck (A61573)
2012 Ford F-450...
Case IH Onland 3pt 6 Bottom Flip Plow (A64119)
Case IH Onland 3pt...
