Another John Deere 1050 hydraulic problem.
/ Another John Deere 1050 hydraulic problem.
Pm sent
/ Another John Deere 1050 hydraulic problem. #22
My 2240 already had a loader when I bought it but, the old 2 lever valve was bad. I replaced it with a joystick type. It does not use the power beyond port and is setup closed center. The pressure line is teed into the hard line going to the lift box and rear remote. The out line is plumbed into the filter housing. I think it's a kit that be bought from JD.
That's correct for closed center hydraulics, but NOT for open center hydraulics. 1050 is open center
/ Another John Deere 1050 hydraulic problem. #23
Your loader valve should have three ports in addition to the four for the loader cylinders. In, Out, Beyond.
Going from your rockshaft control valve it should have two ports marked Aux In, and Aux Out.
A plug is installed inside (internal) in the Aux Out port. This prevent flow to the rockshaft.
From rockshaft Aux Out port go to loader valve IN port.
From loader valve Beyond port go to rockshaft Aux In port.
From loader valve Out port go to Sump (a return to the transmission sump)
so the rock shaft control valve will be labeled as such?
FDA09734-B212-4244-B330-87EC438012B7.jpeg9F1486AC-2CDE-4E30-A065-90757C865F80.jpeg78C0C513-BD5D-4990-8396-4261BB474721.jpeg58A38E37-136E-4B45-A945-BC97DBC8A42E.png
This is how it’s hooked up right now.
That one that has a plug that says transmission tank has a line to it now that’s just the pic I have on my phone at the moment
/ Another John Deere 1050 hydraulic problem. #29
Quote: A plug is installed inside (internal) in the Aux Out port. This prevent flow to the rockshaft.
I have heard on here that plug can come loose and give you the trouble you are having. I had a 950 but don't remember what plug it is under. All I can remember it was a 3/8" pipe plug.
Ok so I went out this evening again to bush hog once again from the start up the front end loader worked and so did the 3 point hitch. It was jerky but it went up and down I set the depth and began bush hogging when I felt the lines they are not hit now they don’t even seem to have pressure what it seems like. And I also forgot to mention earlier as I’ve been trying to think of everything under the sun of what could be wrong. But when I first had the tractor and was working on the fel I was swapping hoses around and thought I had it fixed the first time I busted the main pressure line at the hydraulic pump. The big hoses. The brazing from the factory busted. And I took it off and had it re brazed and when I put it back on and corrected the hoses everything was working but only for the first cut and I bush hogged and pushed limbs and dug holes with the loader. Used it for about 8 hours continuous. Could it be the hydraulic pump?
/ Another John Deere 1050 hydraulic problem. #31
Hope you get it figured out.
But so far, you have me real confused as to just what is going on, what has gone on in the past, and where you may be going in the near future.
Wish you well...
Hope you get a pressure gauge and figure out your system. Good luck.
I bought the tractor from a friend of mine. He hired someone to add a joystick controller because he didn’t like the dual lever. When I got the tractor the loader would work and 3 point hitch would work the front end loader would work with a load but when I bought a bush hog to go behind the tractor it wouldn’t pick the bush hog but the loader would still go up and down and pick up a load. Well then I asked on this forum and got some help on how to hook up the lines. But before I came here to ask I swapped hoses around not the ones that go to the cylinders just the ones that hook up to the tractor and by doing so I busted brazing on the big line coming out of the hydraulic pump on the front of the tractor (it’s located on the bottom side of the pump). Well I took the line out and got it repaired. Reinstalled the line and hooked the lines up like folks had adviced me to do and the tractor worked fine for its first time bush hogging. It sat for a few weeks and came back to use the tractor and it worked at first and quit working. Today as I was bush hogging I touched the lines again and they were not as warm as I thought. And when it works at the initial start up of the tractor(when it’s sat for a day) it’s real jerky I can hear the pump running when I’m pulling the levers (either one of them fel or 3 pt hitch) but later on as I’m using it and try to pull levers I get or Hear nothing. I’m sorry if I’m confusing y’all but I’m not great at explaining things as you can tell.
/ Another John Deere 1050 hydraulic problem. #33
Hopefully this helps.
Looking at your photo in post (#4) of this thread, I thought something was in error. The hydraulic tube that is capped should definitely be in use. If you look at my supplied photograph, you will see a hydraulic module hard piped in the right of the photo (drivers left). In your tractor I assume that the hard pipes coming off this module are still in existance in their original location. I removed mine when I relocated the valve in 1991.
But anyway.
(1) The physically forward of these tubing fitting is the power beyond port from the remote loader valve block.
(2) The rearward fitting out of the module block is the high pressure outlet of the tractor and should be piped directly to the inlet of the loader control.
(3) The hose to the photo left of the rock shaft lock valve is the return to tank from the loader control valve
For proper operation you must have a total of seven hoses going to the loader control valve. PB must be used and used properly. I did exactly what the previous owner was attempting to do my self in 1991, and everything has been flawless.
About that other thing.
Mailed half of it today, other half tomorrow.
/ Another John Deere 1050 hydraulic problem. #34
Wait a second.
Are you also missing the three-point (rock shaft ) control lever and stand alone valve?
63140B3D-C4CA-475F-BF92-330C43797E3F.jpeg1DED9CC1-D9C2-44A9-AC84-D2ABAD8F9C7D.jpeg 75F1CEA9-1503-4301-B38E-0C42C74CA360.jpeg
I don’t have that box that’s on the right of the picture you just posted.
/ Another John Deere 1050 hydraulic problem. #36
Is the three point draft control present? Is the handle there?
Secondly. Does the joy stick have a power beyond fitting and is the hose hooked up?
I’ll get better pictures in the morning
/ Another John Deere 1050 hydraulic problem. #38
I've annoted one of your photographs with how I think you need to run the hoses. If you'll notice, you will need to use power beyond. I base my theory on your needed hydraulic circuit by this photograph on page 70-20-8 of the Technical manual
This is how my tractor is set up right which looks exactly how the manual says.
/ Another John Deere 1050 hydraulic problem. #40
It looks like you have all three joy stick hoses hooked up, and the draft control lever is there. How's it working?
2018 Case 580N EP 4x4 Loader Backhoe (A64553)
2018 Case 580N EP...
2022 EZ-GO ELITE...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
John Deere 2840 Tractor (A64047)
John Deere 2840...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
New/Unused 20ft X 20ft Steel Carport (A65583)
New/Unused 20ft X...
