Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #5,141
So, I’ve read this thread several times over the last few years every time I think I’m going to buy myself a flail, but now I think I’m really ready.
I know I’m going 60” for use on my B2620, but can’t decide, Caroni , Woodmax or Titan. It will be used for pasture/ field mowing a couple or 3 acres and I only cut it 5-6 times a year. I think any of the 3 are up to the task just can’t decide to have one shipped or I can pick up the TM1500 local.
If you can wait a bit I would order a TM from the factory with the hydraulic shift kit installed at the factory. It will help you a huge amount when mowing you can get close to trees and fence lines.
/ Let's talk flail mowers #5,142
I'd like to know if any of you guys with flail mowers are using yours with one of the various Quick Hitches on the market. I have one from HF but so far, have not messed with it. From what I read anything with a PTO shaft creates some issues so like to hear from those using them with a flail and if its worth the trouble.
Ricn
I have an Agri-Supply QH. I use an adapter (also Agri-Supply) which replaces the upper hook on the QH. If you read through the thread (which is pretty lengthy), you'll read of some folks whose QH will hit the PTO drive shaft when the 3PH is full down. I have that problem...easy fix though. If your 3PH (Rockshaft) lever has an adjustable stop (like my 4520 and other Deeres have) just use that stop to prevent full down travel of the 3PH.
Now, that works fine for me with a pretty level mowing area. If you have to cross a ditch or something similar, it may not work for you.
/ Let's talk flail mowers #5,143
Well, I have some rough and bumpy terrian. No ditches just dips and such. If the 3 point is held up from its float position then the mower weight in on the 3 point and not on the rear roller like its supposed to be, right? Maybe this QH is not for me with the mower on.
Ricn
/ Let's talk flail mowers #5,144
I don't believe the Caroni hydraulic side shift doesn't travel any further out then then the fixed side shift (the Caroni TM1 1900 mounting assembly (for the PTO and 3PH) can be positioned either at the centerline, or offset to the right around 15" or so as shown in the picture attached
I was thinking about the side shift kit...but it's a bit pricey ($800) and wasn't in stock when I bought the flail mower. Since using the mower, I've found mounting assembly fixed offset works fine for all my mowing.
There was a TBNer who did get the hydraulic kit and has a number of posts describing the assembly. Those posts are in this thread, if you've got time to go through 129(!!!) pages of posts!
/ Let's talk flail mowers #5,145
Fallon. I have top and tilt on my 2501; extending the top hook on my HF unit is easily done, just so my top cylinder has enough length to reach out the extra 4 inches was one concern, the other being the PTO shaft hitting the crossbar as some have mentioned. When mowing, I drop the 3 point all the way down putting all the weight on the rear roller and right now the cylinder is not an issue length wise so the mower floats across the field. One concern I have is hitting the PTO shaft against the QH crossbar but having yet to mount my QH that remains to be seen. Maybe won't be able to raise the mower to full height meaning I need to be very careful or put a stop bolt on the lifting mechanism? I could remove the cylinder and use the manual top link for a little more clearance if needed but really like having the cylinder for everything; works very well with the Land Plane and Box blade.
Ricn
I had a QH & TnT on my L3200, basically the exact same machine. I didnt have any issues I worried about. My standard process has always been set mowing height with the 3pt & leave the toplink in float. My 917 had some float in the lift links, but the roller height adjustment had been welded in place years or decades ago.
My Peruzzo has a slot in the top for float action. But the QH prep kit kind of mounts solid. I might be able to loosen up one of the bolts to let it pivot for float. But I just set the toplink in float & dont wory about it.
The QH extends the lift & top hooks back by about 4". So there is no need to worry about needing a longer toplink.
My fix for the tophook was the same as 94bullet http://www.tractorbynet.com/forums/attachments/252974-quick-hitch-problems.html#post2944942. You can see photos of bolts on the impliment hitting on the back of the QH, making for the need. 2" of extension never caused me any problems.
My only PTO shaft length issues except on my new to me trencher. The shaft ends wouldnt even touch when hooked up, so would have been to short even without the QH. All my gear immediately gets setup to be QH compatible before use. I still haven't got the CAT 3 bushings on some of my impliments, but they still fit on the QH, if a bit sloppily.
/ Let's talk flail mowers #5,146
There is an 8' Ford flail mower on Craigslist. They did not know the model number.
From what I have gathered stay away from the Models 907 and 918. Model 917 is ok
They said was a Ford Series 22-I85 flail mower
if anybody has any input, I'd appreciate it. it doesn't look to be in bad shape
Does anybody have any ideas on what model Ford flail mower this is? Or if it looks worth buying?
They had more pictures in their Facebook ad.
8 ft ford brand flail mower. Hooks to tractor 3 point - farm & garden - by owner - sale
/ Let's talk flail mowers #5,147
The Ford/New Holland 918H's are great flail mowers. I ran one for 16 years with zero problems and sold it in very good condition. Don't know where you picked up the idea of staying away from them. In fact I liked it a little better than the Land Pride FM 2584 that replaced the 918H. Vic
/ Let's talk flail mowers #5,148
Somewhere on this forum. The tiny bit of knowledge I have on Flail mowers came from here.
Do you have any thoughts on the mower I might look at? I would get it tomorrow if somebody said it was a decent deal.
/ Let's talk flail mowers #5,149
It offsets more by several inches, and centers more as well when drawn in. You can get an idea from this picture:
http://www.tractorbynet.com/forums/...1523156106-lets-talk-flail-mowers-nv7webi-jpg
My setup process is here: Caroni Flail Mower with Hydraulic Side Shift kit - Album on Imgur
Unfortunately the shift rails restrict how high you can lift the mower without binding against the PTO shaft. For road travel and going up/down steep inclines (trailer ramps) the PTO shaft needs to be unhooked.
/ Let's talk flail mowers #5,150
Can you attach two pictures to a response?
First...centered behind the tractor
Second...maximum offset
Take the pictures like I did...directly behind the tractor's centerline
/ Let's talk flail mowers #5,151
That one in the Craigslist link is a 917.
/ Let's talk flail mowers #5,152
/ Let's talk flail mowers #5,153
I couldn't tell you if it's a 917 or al older one, despite owning a 917. I hadn't heard the old ones being any less reliable than the 917s, other than just being older & generally more worn out.
I paid $100 for mine in way worse shape than what's in the photos. Have $600 into it with new knives, PTO shaft & rotor bearings. It was worth every penny no matter how you do the accounting. It's now retired, but gonna keep it around as a spare if my new Peruzzo fails me as it worked when I parked it.
/ Let's talk flail mowers #5,154
Thank you much. I may have missed it. There is a guy looking at it now.
I waited until somebody told me it did not look like a bad deal before calling. I can't afford to make mistakes
You never know for sure until you actually look at something, But somebody that knows can often tell if something is to be walked away from by a picture
/ Let's talk flail mowers #5,156
/ Let's talk flail mowers #5,157
You need to put the top link ball and pin into the SLOTTED hole on the headstock . You then need to shorten your top link by winding it in . This will pull the top of the mower forward and aim the gearbox spline down . This will give you clearance between the PTO shaft and slide bar .
When you then put the mower down, the ball and pin will slide back in the SLOTTED hole and make the mower level again .
As I said in the start of this thread , people should be using the slotted hole so the mower can ride over undulating terrain . If you use the single hole in undulating ground, damage will result as the mower will try and lift the back wheels of the tractor off the ground . Bent slide bars are common because of this . The end of the shift ram can also break off due to the strain .
/ Let's talk flail mowers #5,158
I went and talked to the seller. He may have talked me out of buying the flail mower.
He said that he did not think it would work well in tall grass. I was planning to use it to mow the CRP and 3/8 mile of road ditch once or twice a year/ The grass will be tall.
I have another 10 acres that I will need to mow sometime
What is everybody's opinions on this?
Would that Flail mower work for me or would I be looking to sell it in short order?
I don't think I would get hurt at the price. I've already got 2 hours into going to look at it.
Do they make a 7 to 10' mower that would be kind of like batwing for mowing ditches?
/ Let's talk flail mowers #5,159
Very tall grass may be an issue. The grass can get wrapped around the shaft. My wife just burned up the belt on my JD 25A by doing yhe same thing. Grass is on order of 3 feet higj. Flailmaster folks recommend 18" max. My opinion is that it will do OK if you go slow.
I just found a 2016 JD 390 with 10 hrs on it for $3500. Stored inside and paint looks like new. Web the paint on the spirit looks good. If i can get my wife to meet me at seller with a trailer, it will be mine.
/ Let's talk flail mowers #5,160
Sense I a disturbance in the Flail Mower Force!!!
Good it is that you will have a new to you flail mower for your kingdom very soon.
Please keep us updated with your journey.
(2) UNUSED 320/70R24 TIRES W/8 LUG RIMS (A62130)
(2) UNUSED...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
New/Unused Landhonor 8ft X 10ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
Jeep Tailgate Theme Wall Decoration (A61569)
Jeep Tailgate...
