Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #5,121
Hello Jthibideau89,
I see that your flail mower is one of the units made in Mexico. My fathers 25A was made in Moline, Illinois.
The image with the V belt pulley that walked out you were so kind to provide is very detailed. It appears to me that there is a grease fitting that may be broken at the top of the bearing flange.
I would talk to the flail master folks and or the JD Deere dealer and ask them about this as you must find out if it has a sealed bearing set or not.
I would also check to see how much it would cost for replacement bearing mounting flanges with grease fittings installed in the machined part as you have a 7 foot wide cut flail mower that if purchased new it would cost $8,000.00+- plus freight and sales tax if purchased new.
/ Let's talk flail mowers #5,122
Hello Jthibideau89,
the machined part.
/ Let's talk flail mowers #5,123
Thanks for your help. The grease fitting on the drive shaft is intact. I was able to grease that bearing. I will discuss the cutter shaft bearings with the folks at Flailmaster. I have machine tools in my shop and can add the grease fitting and distribution groove myself.
/ Let's talk flail mowers #5,124
Jthibideau89,
Did you try the scoop knives before installing the side slicers. I have side slicers on my MOTT 72 but I was wondering which style of knife is better for what jobs. The side slicers work fine for thick brush and weeds but I would thing the scoop knives would work better if you were looking for a nicer cut with more frequent cutting. I would also think the side slicers would have more of a mulching effect
/ Let's talk flail mowers #5,125
Duck foot blades for heavy brush and saplings, double side slicers as you call them are best for grasses and they are reversible when one side wears down to much.
ricn
/ Let's talk flail mowers #5,126
My 25A came with a set of worn out scoop blades. After reseaching the differences and considering my application, I decided on the side slicers. I never even tried the mower with scoop blades installed. You can see in my photos that I am cutting 5-6' briars and field weeds. There is an occaisional privette bush or sapling, but nothing much heavier than that. I think the side slicers are the correct choice for my application. Once the pastures are back in control I plan to bale them 2-3 times/year. I plan to cut with the 25A 6-8 times this year and hope that the grass thickens up once given a chance. 2-4-D is not an option for us as we are going organic.
/ Let's talk flail mowers #5,127
The side cutters work pretty well for me on light brush and very well for grasses even our tall rye and what I mow most of the time.
sounds like a good choice for you too.
Ricn
/ Let's talk flail mowers #5,128
From what I read, the scoop blades don't mulch as well in tall grasses as compared to the side slicers. When used on shorter, finer grass the scoops are supposed to give a better finished appearance. When i went across my dam, i could see the sawtooth appearance of the slicer blades in the previously mowed grass. This is fine for a pasture, maybe not so good for a lawn.
/ Let's talk flail mowers #5,129
The hockey game was a bust so I am back visiting the forum.
Nope the scoop knives do not mulch. You need to mow at a 90 degree angle to counter the waffling pattern created by the scoop knife.
/ Let's talk flail mowers #5,130
jthibodeau89, I think you can get a replacement bearing at just about any farm supply store. Those bearing are very common. Bolted between two metal plates that you can reuse. The bearing has a locking collar that is the part that is driven on tight with a punch (in the hole that does not have the set screw) and then set the set screw to hold in place.
/ Let's talk flail mowers #5,131
I am familiar with camloc bearings. I just don't understand why this one keeps coming loose. I can get replacement bearings through my day job.
/ Let's talk flail mowers #5,132
/ Let's talk flail mowers #5,133
Not that type. IIRC, bearing is Fafnir or maybe NSK eccentric lock collar type bearing
/ Let's talk flail mowers #5,134
S/N tag is preseng and legible. I already picked up the operator manual. The drve shaft bearing is a cam lock type with a single set screw on the collar. The set screw is tight to the shaft. The collar came loose from the cam on the bearing. Perhaps I secured the cam in the wrong direction. Will resecure so that the forward rotation tightens it. I didnt think that the bearing drag would be enough to loosen the cam. May just need a new bearing.
Will pick up new hangers today from Flailmaster. I work a few miles from thier shop.View attachment 557098
I think the space between shaft and bearing is too big, you can feel if it is too easy to install the bearing onto the shaft, it is a question related to production processing accuracy. Mostly this Mexico factory ignore something details when they produce it.
To avoid it slip, I suggest you to drill a small hole(no need too deep) on the shaft end, then the set screw of the bearing could go a little into this hole on the shaft.
And there are some different type of set screw, I don't know what type your set screw is, you can check some other type. timg.jpg
/ Let's talk flail mowers #5,135
Thanks for the suggestion, but the setscrew and collar is not coming loose from the shaft. The eccentric end of the beariing is uncoupling from the collar.
/ Let's talk flail mowers #5,136
Sounds like the shaft is moving side to side, or the end plates are moving. Good luck and hope you figure it out.
/ Let's talk flail mowers #5,137
So, I’ve read this thread several times over the last few years every time I think I’m going to buy myself a flail, but now I think I’m really ready.
I know I’m going 60” for use on my B2620, but can’t decide, Caroni , Woodmax or Titan. It will be used for pasture/ field mowing a couple or 3 acres and I only cut it 5-6 times a year. I think any of the 3 are up to the task just can’t decide to have one shipped or I can pick up the TM1500 local.
/ Let's talk flail mowers #5,138
I'd like to know if any of you guys with flail mowers are using yours with one of the various Quick Hitches on the market. I have one from HF but so far, have not messed with it. From what I read anything with a PTO shaft creates some issues so like to hear from those using them with a flail and if its worth the trouble.
Ricn
/ Let's talk flail mowers #5,139
Ricn
I ran my old Ford 917 & new Peruzzo SuperBull with various QHes. I've had Northern Tool, Harbor Freight & at least 1 other make of QH. They are all cheap in most meanings of the word, but hold up fine & are more or less the same quality. I have yet to break one, even with the 1,800lbs Peruzzo shifted all the way out & catching on 2" brush. A couple needed grinding on the hooks to loosen them up enough to properly fit. All needed an extension on the back of the top hook to fit some gear.
I rebuilt my PHD to fit a QH (requires a hydraulic toplink) & that had PTO issues unless you did the toplink extension before dropping the 3pt. I've cut a couple plastic PTO shaft guards on other impliment catching them on the QH. But I can't remember which offhand. Generally I think that happened when the hydraulic toplink was fully retracted. Not as likely to happen if you use the stock toplink & dont have it at extreme ends of its length.
/ Let's talk flail mowers #5,140
Fallon. I have top and tilt on my 2501; extending the top hook on my HF unit is easily done, just so my top cylinder has enough length to reach out the extra 4 inches was one concern, the other being the PTO shaft hitting the crossbar as some have mentioned. When mowing, I drop the 3 point all the way down putting all the weight on the rear roller and right now the cylinder is not an issue length wise so the mower floats across the field. One concern I have is hitting the PTO shaft against the QH crossbar but having yet to mount my QH that remains to be seen. Maybe won't be able to raise the mower to full height meaning I need to be very careful or put a stop bolt on the lifting mechanism? I could remove the cylinder and use the manual top link for a little more clearance if needed but really like having the cylinder for everything; works very well with the Land Plane and Box blade.
Ricn
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63118)
2023 Kubota...
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
2001 John Deere 6210 (A60462)
2001 John Deere...
John Deere TX Gator (A60462)
John Deere TX...
