Off-set Brush Cutting
   / Off-set Brush Cutting #1
JeffroL
Sperryville
Deutz D4006; Kubota M7060; John Deere 500C
I have a Kubota M7060 tractor with a 5' bushhog that I use for clearing brush. It works very well, but there are many areas of my property where I need something offset from the tractor that can clear the brush. Example, fence lines where there is a lot of overhanging brush. I also have buried creeks, in the fields, which are a major hazard. Huge sinkholes can open up so I just can't drive a tractor in those areas. I'm considering a sickle bar, but wanted to see if more experienced folks had any recommendations. Help!
   / Off-set Brush Cutting #3
That's a crap ton of tractor for a 5' bush hog :)
I like your sickle bar idea to really reach out for the areas you don't want to be driving on.
   / Off-set Brush Cutting #4
Hardee makes a good side brush hog, our hunting club has one for cutting canal banks and cutting back limbs
   / Off-set Brush Cutting #5
   / Off-set Brush Cutting #6
Kind of an odd picture in the winter, but I had just got this and wanted to try it.
It has heavy hammers and will pulverize 3" brush but also cut grass amazingly well. Stones lay a real hurtin on the knives
It's a PERFECT by Van Wammel in Holland, but there is an almost identical machine out there
A hydro would be much nicer to maneuver it.
Oh, then there's this hydraulic sickle, I got last year. First time out, fifteen minutes later all the knives were badly damaged!
   / Off-set Brush Cutting #8
Okay, what damaged the knives? I am in the market for small tractor ditch bank cutter and this is one I thought on. Have about same size and heavier tractor then the OP is using to use full size boom mower but need small tractor for use in normal trim type work. Too old for hand held trimmer.
   / Off-set Brush Cutting #9
I have a 3pt sickle bar belt drive mower. I had big visions of it's use. It beats nothing. But as I.T. mentioned maintenance is an issue. If mowing a "clean" area it wouldn't be. Problem being you'll want to mow all those areas you couldn't reach before. :)
   / Off-set Brush Cutting #10
I grew up in the '50s mowing hayfields with a sickle bar mower in Pennsylvania. Any rocks/pebbles/dirt mounds will tear up or damage the knives. The knives are riveted on the bar so it takes time to change them once they are messed up, and constantly need to be sharpened anyway. They will not cut brush of any size without damage to the knives.
Now I live out in the Nevada desert and I'd dearly love to have a mower that mows my desert acres cleanly and not leave a ragged mess like the brush hog does. But when the ground is covered with ground squirrel mounds and the rocks they push up, a brush hog - heavy-duty brush hog at that - is the only option. In Pennsylvania I had to deal with the mounds that woodchucks left in the fields - but they were a minor problem compared to the mess ground squirrels leave.
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A53421)
2025 Single...
MISC CHAINS (A55745)
Lenovo Thinkpad T480S Laptop (A53425)
Lenovo Thinkpad...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
VOLVO SD75B SMOOTH DRUM ROLLER (A52706)
VOLVO SD75B SMOOTH...
1779 (A51248)
1779 (A51248)
