Best UTV?
/ Best UTV? #1
Dan Harris
Big Bear Ca
Kubota RTV x1140
We are looking for advice on the purchase of a utility vehicle. We have a remote cabin 7,000 ft elevation, with a 500 ft driveway on a 22% grade. We need the UTV to be at least a 4 seater to occasionally transport guests, as well as haul heavy loads of building materials up, and down the steep grade. The UTV will only be used for these purposes up, and down the steep drive path. We also will need a snow removal attachment. We are in the process of researching the best UTV for our specific needs. We are strongly considering the Kubota X 1140, but are a little overwhelmed with the vast amount of choices available, and need to narrow it down. We would be grateful for input from experienced UTV owners.
Thank you in advance for your advice,
Dan
/ Best UTV? #2
I like the Deere UTVs (I own an 855D)...my second choice would be Kubota...especially the RTV 1140 which converts from 2 seats with a long bed to a 4 seater with a short bed. I priced both a new Deere 865D and the RTV 1140...both in the $20K-$25K range with some options...bit too rich for my blood (especially since my 855D only has just over 100 hours on it). Getting a machine with a factory cab will add more $$$.
Adding a snow plow with integral hydraulics is going to add another $2400 or more...
I do suggest getting a windshield if you don't go for a full cab.
When one gets into the price range of these UTVs....you have to consider going for a used (beater) pick up with an extended cab (for those occasional visitors). You could probably pick up a used Toyota Tacoma for considerably less then a dressed UTV and would have more creature comforts.
/ Best UTV? #3
how mechanically inclined are you? Roy makes a good point about spending 20K on a UTV vs buying a used 4x4 vehicle.
is this a place you live at or visit? when it comes to snow removal can you start at the top? or do you have to start at the bottom? have you dealt with snow here in the past?
/ Best UTV? #4
If you want it strictly as a work vehicle you're right on the mark with the Kubota. If you have any recreational uses planned also, you might want to look at some of the competition for a smoother ride and higher than 24 mph top speed. I got a Honda Pioneer 1000-5 because it has an automotive style gear transmission rather than the belt driven CVT type that most UTV's use. I've had it for a couple of years now and have worked it hard with no issues.
I've had several recalls on mine for clutch and cabin heat issues which I didn't actually have a problem with, but mine was a first year model. I will say mine shifts smoother since they did the update on the clutch.
/ Best UTV? #5
I bought a 2018 Kawasaki Mule last year. Sits six people easily. In fact, I have hauled 7 adults (six in the seats and one in the bed), a toddler and 2 dogs in it with no problem. The bench seats look plain, but they are comfortable and very versatile. Everyone that gets in it remarks how smooth it is. I looked a little at the Kubota but my Kawasaki dealer is right down the street and the price was right at just over $14k. I like the half doors, they keep rocks, mud and brush out. I really have no complaints so far. Everything on the engine looks like it will be easy to access with the bed tilted up. Like lots of things, it could use more storage. There can be bins under the front seat, but that isn't very practical as the seat just pops off, it is not on hinges. Those who say it isn't fast enough at 45 mph top end are crazy. No way I would drive one of these utility vehicles at that speed. Fastest I have had it is a little over 30 mph.
I looked at the specs for the diesel mule. I think it had less torque than the gasser and couldn't pull any heavier of a load. I got over wanting a diesel. Kawasaki has gas mules down oat and have for decades.
The diesel Kubotas are rated for 1300 lbs towing while the gas mule is rated for 2000.
/ Best UTV?
Dan
Thank you all for your input. Unfortunately our drive path is not wide enough for a conventional vehicle. It is 6 ft wide at the pinch points, with loose/soft decomposed granite as the terrain with the 22 % grade.
/ Best UTV? #7
Transmission and altitude should be important considerations.
HST in utility vehicles has the same advantages has HST in tractors. Kubota diesel RTVs use the same engines and HST transmissions as Kubota tractors. HST develops max torque as the vehicle begins to move. For a work vehicle, Kubota is a top choice. If you want to go FAST, HST is not your best choice.
Keep in mind that at 7,000 feet normally aspirated engines, diesel or gas, will be down about 20% in engine power output, so you should probably consider only 24.8 horsepower models.
Add your location to your T-B-N PROFILE.
/ Best UTV? #9
Be sure to check out the Mahindra mPact, too. Built in the US by Intimidator.
You can buy an Intimidator, but they don't have any local (in California) dealers.
Very impressive machines, but more $ than I can justify.
/ Best UTV? #10
We are located in Big bear Lake, Ca
Wonderful.
Put Big Bear Lake, California, in your T-B-N PROFILE, like every single on of your respondents, so BBL, California shows with every post you make.
/ Best UTV? #11
1. Kubota RTV
2. Honda Pioneer
Might swap those depending on specific tastes.
/ Best UTV? #12
Just buy two Mahindra Roxor’s and be done with it lol.
My only experience with UTV’s is what we have at work JD 4x6 gator, Polaris 4x4 and a new 4x4 cub cadet. Polaris and cub are 500-700cc or around there.
Of those three the Polaris and cub are sitting outside and the Gator is sitting in the garage because it’s been the least problematic and actually runs, it wasn’t used for 2 years, just sat around, threw a charger on it and fired right up, purrs like a kitten. The cub has been the worst, nothing but problems.
/ Best UTV? #13
Consider the Yamaha Viking...........has a good dump bed, seats 6, 1200# towing capacity, and can be used as a recreation and utility vehicle.
/ Best UTV? #14
Anyone looked close at the Mahindra Roxor Jeep knock offs yet? Interesting product. Reachable prices. Not exactly what this OP is looking for I don't think but it crossed my mind when he asked. Seen a couple from across a parking lot.
This place is close to me... where I saw them. This is the deluxe loaded one... 218 Mahindra Roxor Limited Edition // LE R181 | Performance Powersports
/ Best UTV? #15
/ Best UTV? #16
I reserve an opinion on the Roxor til I get to touch one.
/ Best UTV? #17
Yeah...doubt if they're road legal...but, highly competitive prices!
/ Best UTV? #18
They aren't road legal. They are essentially a UTV in that respect. Considered a "side by side"
And they are governed to 45mph.
Diesel though. Turbo diesels. Manual only. Id like to know the specifics and source of the motor... knowing Mahindra it could be about anything or any one.
Trail riding for someone who wants that sort of jeep trail ride feel.
Id take one if someone gave me one. Id like to try riding one. One positive I can see from reading is the towing capacity. Far more than any regular UTV. But... a very unique product.
/ Best UTV? #19
I believe they already are saying not road legal. There are some logistical questions I have about them. Particularly the top speed. No mechanical reason for it to be that slow other than poor design.
/ Best UTV? #20
Its reported that its electronically limited. Probably capable of closer to 55 if not so. A review I read says there was little speed difference from 4th to 5th so the suspicion is they are hitting a limiter.
2012 Kubota RTV 1140 4x4 Diesel Utility Cart (A61567)
2012 Kubota RTV...
1987 INGERSOLL RAND PT-125R PNEUMATIC ROLLER (A62129)
1987 INGERSOLL...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
2015 Hyundai Santa Fe XL Multipurpose Vehicle (MPV), VIN # KM8SNDHF2FU114492 (A61165)
2015 Hyundai Santa...
