Driveway Gravel
/ Driveway Gravel #21
Gravels vary in name and type by region.
Gravel has a language all its own. Call the local quarry around here and you are suppose to know a mystery number that identifies the size of the stone. However, far as I know, the number isn't proportional to the size? :confused3: So you can order #11 and it's 1/2 the size of #13. :confused2: I just order a truck load (20 tons) of #9 (1 inch) every few years. Last load in 2016 was $17.70/ton (which included delivery) for 30 mile round trip.
/ Driveway Gravel #22
Forget gravel or crushed stone if you can get recycled asphalt. (for the top coat or finish)
Same price to haul but it refuses under heat(sun) and makes a great drive surface.
Generally a lot lower $$/ton than crushed stone
Flowing water damages much less than crushed stone.
/ Driveway Gravel #23
Tell me more about recycled asphalt .... I am currently (helping) maintaining a mile and a half 1 lane gravel road.
The previous guy kept it narrow with a high crown, We have been flattening and widening the road along with reworking the ditches on either side. I have been adding about 150 tons of road gravel (ABC modified) each year while getting the road in decent shape.
How well would the asphalt work for a private road with 10 houses and a fair bit of traffic. It's mostly flat but has a few steep grades here and there. 2/3 of the neighbors kick in for a 20 tom load of gravel each year so I'm limited on funds .....
/ Driveway Gravel #24
The local lawn tractor dealer used recycled asphalt for his parking lot. If you get it when it's hot and have it rolled, it's a pretty nice surface. I got a load or recycled concrete for in front of my garage, and it also sets up nice.
I'm curious how your 10 neighbors are with kicking in $$ for the gravel. I do the same for 10 neighbors on e a 1/2 mile private road. I ask them for $25 /year for gravel - I maintain it for free. At first it took a couple of passes to get it. Then I l got busy and it got a little rough, and after that, they all pay up promptly (except one who never pays). Some people figure out right away they are lucky someone takes care of the road. Some come to that conclusion a little later.
/ Driveway Gravel #25
Our road is pretty rugged in places so we ask for $20 a month which pays for a 20 ton load of gravel each year per lot.
The neighbor at the very end has 2 mobile homes they rent out and they pay Nothing.
Everybody else see's on of my neighbors with his old JD 50hp tractor and my 40hp out working the road and willingly help out.
We not only maintain the road, but plow it when it snows, otherwise it is impassable.
I try to set an example by providing my new tractor for the work, my time and effort, my fuel, as well as buying a load or 2 of gravel each year.
/ Driveway Gravel #26
I'm at the end of a fork... the other person at the end of the other fork owns the road... we all have easements from him.
Nice older couple been there for years...
I asked about the road and he said he takes care of it... said he only asks that people don't go out of their way to tear it up... refused to take money.
My way of paying back is to order a stock pile of rock and when I'm there I take care of all the pot holes... actually Mom met more people in short order when she was out tamping the rock down... she likes doing it.
If I ever get back full time my BX is perfect for the chore...
Some neighbors do nothing... so the owner just shrugs.
/ Driveway Gravel #27
Yep itç—´ the delivery! Material is what has already been stated and delivery is $65-$100/hr (round trip) depending on the truck and location.
Btw- you don稚 want gravel for a driveway. It痴 road base or whatever they call it there. It痴 a mix of rock and stone dust that packs well.
Yah, I was lazy- we say gravel, but what we mostly USE is what the quarry calls "Number 1 Crusher Run"- which is stones averaging 1" diameter, mixed with the fines from its trip thru the crusher.
Packs like concrete after being spread, rained and driven on a little.
Mostly because every once in a while, if'n we get too much dirt showing through, we'll get a load of #2-Crusher Run, instead
/ Driveway Gravel #28
I get 25 ton of crusher run for around $550 delivered. I'm about 40 minutes on a back road away from the quarry. They tailgate it up my 700 foot driveway very adequately. Never order less than a full truckload even if you have to stockpile some of it.
/ Driveway Gravel #29
The greater question is, how much gravel do you need? That dump truck load looks big until they spread it!
Ain't that the truth. I buy from a guy that hauls 7 ton with a single axle truck. and 0 to 3/4 "base" as they call it is $120 a load. Seems like a lot on the truck. Ain't much on the road. :)
/ Driveway Gravel #30
There is a steel smelter not too far from here. They sell steel slag road base for $3.50 a ton. They said it has lime in it. Weeds don’t grow in it at all. It looks and smells like quickcrete before you add the water. It packs down tight almost like concrete. It is a you-haul affair, but if you have your own dump trailer, you can’t beat the price.
/ Driveway Gravel #31
They call the kind of limestone gravel you use for a driveway (1 inch or so rocks with dust) cr610. Any y'all heard of that?
/ Driveway Gravel #32
I am sure others in TN have.
Seems every state or reigon has different lingo.
Up here.....lower numbers are bigger.
1's and 2's......good base. Fist and softball sized stuff.
#4's are golf ball sized
#57's (mix of 5-7) are 3/4" stuff. Good top coat material.
#8's...are the pea sized stuff. Another good top coat
All those are uniform size, screened material.
For the mix type stuff...of what some.places call crusher run, or bank run.......we have
304's.....that's basically #4's to dust. Good packing.
411's are 57's to dust. Same concept as 304's but nothing bigger than 3/4" or so. Better stuff if this is gonna be the top coat because you won't have the bigger stone work it's way to the surface
/ Driveway Gravel #33
We have some rather steep hills that always got washed out and rutted from heavy rains.
Also washboard developed rapidly on the hills.
We went to recycled asphalt and those problems no longer occurred as the sun makes it stick together to an almost hot paved like surface.
Overall maintenance is reduced to now only 2 grader pass per year.
By far the biggest win is the hills.
/ Driveway Gravel #34
Where I grew up, "pit run" was glacial till, basically everything from grapefruit sized rocks down to dust, all of it rounded much like river rock.
"Crusher run" was about 2" down, with sharp corners and edges, which packed better.
If mixing up your own concrete, it was pretty common to order "1 inch minus" or "3/4 minus" or "1/2 minus", basically everything from the callout size down.
Stone dust was basically everything smaller than about 1/8".
Where I am now, they start the process by blasting ledge, so there is no "pit run", it all starts with "crusher run" but otherwise seems the same. I know we can also get river rock and rip-rap (about 6" sharp chunks).
Since anything smaller than a full 20 yd. truck is hauled by a subcontractor (truck owner or landscaper), I am would not be surprised if there is a layer of translation between what the customers tell the subcontractor they want and what they then order from the pit, and some of these other numeric road base designations are being used here too, it is just that I don't usually hear them.
/ Driveway Gravel #35
Ld1for ohio
The smaller numbers are sieve size, the larger numbers are from state specifications.
57 is two sieve sizes
/ Driveway Gravel #36
I don't know who's names make more sense, just seems asinine that it is not the same everywhere.
I guess the gov't can't regulate everything! The people that want gravel buy it, the people that have gravel sell it. So why would they care what its called until they get on the internets and talk to other people that do the same.
/ Driveway Gravel #37
Would you really want the government to regulate everything? I sure wouldn't!
/ Driveway Gravel #40
Around here gravel, crushed asphalt, crushed concrete etc is sold by the ton. Ranges from 10-15$ per ton at the source. Figure about 1.2 tons per yard as a guesstimate as it will vary with the product.
Most hauling is done by belly dumps. Most of them charge $85 an hour and we can figure at least two hours per load as the quarries are far. The haul around 21 tons.
So roughly $400 a semi load.
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
10.5' Telescoping Ladder (A66408)
10.5' Telescoping...
First Choice 6' 3Pt Finish Mower (A66408)
First Choice 6'...
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
