Flail Mower Cutting lawn with flail mower.
/ Cutting lawn with flail mower. #1
kkimura
Member
Montesano, WA
Kioti ck2610 hst
Last year I bought a CK2610 with EFGC 60 flail mower and posted a review of the EFGC after 15 hours. Since then, I followed reviews and comments on this site related to all flails. The collective wisdom has shortened my learning curve. I知 glad I bought the tractor and flail mower. I don稚 need either as my lawn is at .5 acre, slightly sloping to a 2 acre field of reed canary grass on wet ground. Prior to the tractor, I cut everything with a 21 Honda self propelled mower. Attached is a picture of the last mowing. In the distance is my field of reed canary grass. The flail roller is set one bolt hole lower than the lowest setting with the top link on the short side. The tips of the 添 blades are within a 1/4 of the ground. After a couple more mowings, I値l drop the roller a little more and lengthen the top link to increase the length of lawn grass but for now the blade tips do a good job of removing moss build up. For those of you wondering about the flail cut on a lawn, the picture will give you an idea. It痴 not the same as my push mower but it痴 passable and I get to do most of the mowing sitting down. If your just cutting lawn with occasional brush work, I wouldn稚 be too concerned about flail width and tractor hp. When I tried to cut the reed canary grass, I needed all the hp the tractor produced and still used the draft control to reduce cutting resistance.
/ Cutting lawn with flail mower. #2
Last year I bought a CK2610 with EFGC 60" flail mower, made in China, imported by Braber Equipment. I posted a review of the EFGC after 15 hours. Since then I followed reviews and comments on this site related to all flails. The collective wisdom has shortened my learning curve.
I'm glad I bought the tractor and flail mower. Prior to the tractor, I cut my 1/2 acre lawn with a 21(?) Honda self propelled mower. The flail cut does not equal the Honda mower cut but flail cut is passable and now I do most of the mowing sitting down. For those wondering about the flail cut on a lawn, study the picture. In the distance is my field of reed canary grass.
The flail roller is set one bolt hole lower than the lowest setting with the top link on the short side. The tips of the 添 blades are within a 1/4" of the ground. After a couple more mowings, I'lll drop the roller a little more and lengthen the top link to increase the length of lawn grass. The flail blade tips do a good job of removing moss build up.
If you are cutting lawn with just occasional brush work, do not be too concerned about flail width and tractor horsepower. The lawn slopes to a two acre field of reed canary grass on wet ground. When I cut fiberous reed canary grass I needed all the horsepower the tractor produced and additionally raised the (draft) (position?) control to reduce flail load.
/ Cutting lawn with flail mower. #3
Jeffy,
Wierd copy of OP post. Are you engaged in creative writing skills lessons? Felt the need to rewrite the post to your standards? Does seem creepy
Do you suggest all posts be submitted to you for editing, since we mere mortals may lack the ability for a coherent presentation of the facts? Arrogant and creepy.
EDIT: Consider English might not be first language of some posters, but they are trying.
/ Cutting lawn with flail mower. #4
I often don't bother reading posts where everything is run together. There are times I probably miss valuable information when I skip posts after running into multiple errors (their/there/they're, vice/vise, brake/break, etc. This is not due to an elitist attitude. It is because it is difficult for me to read easily.
At work I sometimes receive documents in which the sender doesn't bother with paragraphs. Since skipping over them isn't an option, I usually copy, paste and split them up into segments I can digest.
/ Cutting lawn with flail mower. #5
So maybe the problem is more in the reader's comprehension skills rather than the writer's skills?
I consider it arrogant and condescending to mention errors. To completely edit and repost is definitely creepy.
/ Cutting lawn with flail mower. #6
I'll bet it does take more HP to cut that low. But once you get it groomed to that level it should be easier to maintain with less power.
/ Cutting lawn with flail mower. #7
OVERSZD: I read your posts with attention.
It is pointless for some to post unintelligible mish-mashes of words.
The EDIT key is for everyone.
Paragraphing, or at least an effort to paragraph, is not difficult.
Definition of paragraph
1 a : a subdivision of a written composition that consists of one or more sentences, deals with one point or gives the words of one speaker, and begins on a new usually indented line
To convert an unparagrphed mish-mash of words into paragraphs, while maintaining the OP's sense, requires reading comprehension. I did not mention any errors, though the mish-mash includes some, as I comprehend the post. I merely edited the OP's mish-mash.
I speculate I spent more time with the EDIT than OP spent in the CREATION.
/ Cutting lawn with flail mower. #8
So maybe the problem is more in the reader's comprehension skills rather than the writer's skills?.........................
I did post:
"This is not due to an elitist attitude. It is because it is difficult for me to read easily."
There was no attempt to put anyone down, or criticize them.
I'm fairly certain that I have some sort of learning disability that wasn't diagnosed when I was in school. I can comprehend things when they are presented in an orderly fashion, and have aced courses in electrical theory. I have trouble sorting things out when the writer just runs everything together.
To give you an idea of how things can look to me, take a large paragraph and eliminate all the caps, punctuation and spaces between the words.
The second issue is the misuse of words. My understanding of what the writer is attempting to convey loses its momentum when I get sidetracked thinking "that should have been too, not to", or "he meant vise, not vice".
/ Cutting lawn with flail mower. #9
I enlisted in the U.S. Navy in 1965 at age seventeen. I started college with the University of Maryland military overseas program at age 19. My first prof was Ms. Joyce Felte, who taught English 101, The Sentence, and English 102, The Paragraph. She returned my papers brightened with red ink, indicating errors. Ms. Felte is one of the few college profs whose name I remember. I am grateful for Ms. Felte's corrections fifty years later.
/ Cutting lawn with flail mower. #10
Jeffy
You are very confused. T-B-N is NOT a University Envionment. Noted previously, this is just a recreational inclusive forum for imperfect tractor folks. Pretty sure Muhammad doesn't require being a literary scholar as a condition for membership.
Chim, explanation rings hollow, If you can rewrite the post, it means you actually understood in original text.
Jeffy, Infusing your own rules, just not your place.
EDIT: No one is forced to join, read, EDIT, or participate in forum posts. Some folks are less gifted in application of the Queen's English. Rather than mock or denigrate an OP, the preferable solution is to simply move on, w/o comment. I note errors, easily discernable the Poster's intent. An Elitist by any other name is still................
Remember the poster' first language might NOT be English!!!
I'm not offended that my post was edited. I'm not sure what happened as I wrote in Apple's pages and copied to this site's format. I noticed what I wrote was altered but figured it was good enough. My intent was to show those of you thinking of getting a flail mower what the cut on a lawn looks like at the lower roller settings. Also I thought it was cool that the "Y" knife could be set to de-thath. I hate that job.
/ Cutting lawn with flail mower. #12
Kkimura,
Thanks for posting your experience, When postings are written on alternative software and transferred to TBN, some characters Become distorted.
Many members are a fan of flail mowers as their popularity increases. They are believed to demand more hp than other mowing solutions. Hopefully you will ignore the "peanut gallery", and continue to post updates w/ your tractor and mower.
/ Cutting lawn with flail mower. #13
I'm positive you spent more time. That to me is the creepy part. The fact that you couldn't simply read the post and comment or not on the content. :)
/ Cutting lawn with flail mower. #14
I did post:
And I was not criticizing you. Just stating what you further explained. No worries.
/ Cutting lawn with flail mower. #15
People are too sensitive. I would appreciate such help.
On another matter, I do wish that the titles were better on some posts. Without that, the search function on this site will be forever useless and that's a real shame, given all the knowledge here.
As for the flail mower. I bought my first 917 Ford, to replace a landscape contractor that never cut my grass in a timely manner for my weekend visits. I too found it lacking quality of cut and eventually got my JD 770 with belly mower. Then a Gravely walk behind, and finally a Steiner REAR discharge.
Nothing however, beats a push mower for cut quality.
/ Cutting lawn with flail mower. #16
Sensitivity isn't the issue. The point is simply that one member determines that the post of another is inferior.
Industrial is free to route his post through jeffy for editing.
Others are free to feel insulted or intimidated from posting do to a lurking cyber critic. A member should not feel humiliated because their composition lacks a Pulitzer Nomination. It is merely the theme of the post that actually matters. Previously stated, if a member is offended by sentence structure or .misspellings, move on, it is an imperfect world. Some of us can accept this fact without belittling and embarrassing others.
Ok to challenge erroneous facts and claims, or the poster's position, just not the manner , language or text in which such facts are presented . Actually, a reel mower produces a fine result.
EDIT:
Industrial,
Consider this. There are competitive venues that exist. Perhaps TBN isn't such a place, just a casual, imperfect, relaxed gathering of folks w/ tractor and related interests. No pressure to "best" each other, feel comfortable, not self-conscious in your own skin. No cyber hammers waiting to pounce. It is not a race or contest for valedictorian. "The smartest kid in the class" reminds us as such, w/ each of his posts.
/ Cutting lawn with flail mower. #17
I do see the point.
But I guess a person has the right to edit someones material and the OP has the right to "respectfully" tell them to mind their own business.
Technical information is difficult to convey. Some don't care about post content but more just the jibber jabber. Like the old farts who have to be at Mac Donalds in the morning to talk about nothing.
So, isn't it a good thing if people push others to better, interesting and useful material?
I am quite amazed at the general quality of the posts on here. But things could be much better if people would just proof read what they wrote. If they are going to take the time at all, why wouldn't they?
/ Cutting lawn with flail mower. #18
Personally, I would say it if you don't like how somebody has their post formatted. You can just reply with a quote then edit they're post inside the quote and put your answer after it. That way it's not so much in your face and still attributes the words to the original poster.
Aaron Z
/ Cutting lawn with flail mower. #19
Aaron Z
Exactly! I got confused because there was no (note of) attribution indicating that it was in fact an edit. Anyone doing this should indicate up-front that they are providing an edited version (and why). I agree that the original posting was/is hard to read (and I too tend to just glaze over when faced with posts like it0.
/ Cutting lawn with flail mower. #20
Jeff, I don't doubt you remember Ms Felte's 50 years later, as you probably fantasize about her every time you SEE A RED PEN. That being said, you managed to turn this informational thread into a spelling and gRraMaticalized Edgification Epeeny'Ism, that I wasn't ready to be rationalizing @2am when I was searching for answers.
Thanks for ruining my 2minutes of clarity. :cool2:
