Buying Advice need grapple..
/ need grapple.. #1
gravelman
NH
Kubota 2650
gravelman here... what manufacturer makes the smallest tractor that can handle a grapple... with quick attach front?? thanks. I know some of the smaller ones are not rugged enough to handle the torque etc but if used carefully... will work.
/ need grapple.. #2
One could probably put a grapple on anything you can put a QA.
Fo a long time smaller tractors were ignored, probably because moving small buckets is not to difficult and few wanted grapples.
For example my B7610 wasn't offered with a QA front. There are now 3rd party QA fronts for it. And manufacturers are now making lighter grapples with stronger steel.
I'm pretty sure Everything Attachments has one that will fit well with the 2650.
They make a 150lb 48" grapple for the BX.
/ need grapple..
ok, thanks..i guess i have not researched enough yet. i see Mahindra came out with a Max tractor that is not too expensive but it may be too light for a grapple...will look into it...thanks for the reply
/ need grapple.. #4
It all depends on what loads you are trying to lift. Attachments of all sizes are available.
A lot of work can be done with subcompact tractors and mini (micro) excavators.
For the EA example above, "grapple" to them means some kind of modified loader bucket
with independent hydraulic jaw (or 2) mounted above and acting downward. "Grapple"
can also mean a device with integrated jaw movement for lifting logs or rocks with FEL or
backhoe. (See Valby or Hud-Son.)
/ need grapple.. #5
/ need grapple.. #6
i've used a 74" 700 lbs grapple on my b series. i want a smaller 48" single lid, but have yet to find one in a price rangei'm willing to pay
/ need grapple..
well i know im NOT like all the others out there that try to do more than what is designed for....ha believe that and i will sell you the Brooklyn bridge.
/ need grapple..
thanks for all the above info...very helpful
/ need grapple.. #9
EA also does true grapples, not just bucket attachments. Here's one specifically for a BX: Root Rake Grapple For Kubota BX
Here's another slightly bigger one on a small CUT (mine).
/ need grapple.. #10
Our Wicked Grapple lineup has grown to allow me to recommend the MOST IDEAL grapple for so many tractor sizes, unlike any other manufacturer in existence..
The 200 pound Wicked 55 root rake grapple allows small tractors to do BIG things. Here are some examples.
Travis
Kubota BX23S
Kubota B26
Kubota B2650
Kubota B2920
John Deere 1025R
John Deere 1025R
John Deere 3032E
Video of a John Deere 2038R. VERY impressive! John Deere 2038R with 55" Wicked Root Grapple Tackling Big Log - YouTube
Mahindra Max 26
/ need grapple..
this is excellent..thanks very much
/ need grapple.. #13
I am 100% getting a Wicked 55" to share between my new BX2380 and my Branson.
/ need grapple.. #14
FWIW...Almost all the loads (including the brush) depicted in the images could be done with just a thumb type grapple on a regular FEL bucket...
/ need grapple.. #15
I've used just the bucket and a HF ratchet strap, so even a thumb grapple is a luxury.
My tractor was the biggest I could handle on my property, and the FEL is a small step above a BX. Weight was a consideration when I was thinking about a grapple, which led me to the Wicked 55. It weighs less than my bucket, and when I have the bucket on I'm not carrying the weight of a grapple. As an added bonus, I can see through the grapple, which is a great help for a newbie like me.
/ need grapple.. #16
Even without a QA...
Most thumbs are easily removable...
What advantage is it being able to "see through" a grapple that can't be seen any better than a FEL bucket?
/ need grapple.. #17
When positioning to pick up single items (like a rock or railroad tie) I can see what I'm doing better than looking at the back of the bucket. The grapple also digs rocks out much better than the bucket. It also rakes a whole lot better than a bucket.
I felled a dead pine the other day and limbed it where it fell. Grabbed the trunk with the grapple and raised it up to section it. Transported the trunk sections to keep as bonfire wood, then raked the branches and took them up the hill to the trailer. I've done similar without a grapple, and this was much easier and a whole lot faster. A thumb would have worked the trunk OK (as did the strap on the bucket), but the branches were easier with the grapple rake.
/ need grapple.. #18
You cant "root rake" with a bucket.
/ need grapple.. #19
Great points!
Oh...pics or it didn't happen! :laughing::laughing:
Travis
/ need grapple.. #20
I never said anything about root grapples being totally unneeded...I just pointed out that all the tasks pictured (including large brush piles) in the thread could be accomplished with a much less expensive alternative...a thumb grapple...
...When positioning to pick up single items (like a rock or railroad tie) I can see what I'm doing better than looking at the back of the bucket.
What type of tractor allows you to see through the hood/engine/radiator etc. and see the back of the bucket? or are you referring to a skid steer ?
2026 SG45 Hydraulic Stump Grinder Skid Steer Attachment (A66734)
2026 SG45...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
2019 ALLMAND LIGHT PLANT (A67714)
2019 ALLMAND LIGHT...
2014 Ford F-350 Altec Service Truck (A66736)
2014 Ford F-350...
****Power to dash w/jump pack. Does NOT start**** Year: 2012 Make: Ford Model: Transit Connect (A66738)
****Power to dash...
