07 CRAFTSMAN 22 HP
/ 07 CRAFTSMAN 22 HP #1
dougbthom
Member
Anola,MB
Sears Craftsman
A friend that has a 07 Craftsman 22 HP has a hydrostatic trans that is done. He is wondering if there is a way of servicing it as it is sealed or look for one that he can purchase. Any ideas would be appreciated. Thanks
/ 07 CRAFTSMAN 22 HP #2
I was told by a repairman that they aren't field fixable.
/ 07 CRAFTSMAN 22 HP #4
What are the symptoms and history?
From what I know of it, it has done a fair bit of work (grass cutting). It has about 450 hours on it. When you first start it up, the hydrostatic works for less than 5 minutes and then nothing.
/ 07 CRAFTSMAN 22 HP #6
That's typical in my experience of a worn out HST, as soon as the oil gets warm it stops producing motion, or stops producing enough motion to be useful. You can look under the back at the able and you'll see a white sticker that will tell you what it is, like on my Craftsman it has G730 on that part number sequence, telling me that I have the Hydro Gear G730.
Once you know what you have (it's obviously not a G730, as it has a spin on filter and is serviceable) you can Google that axle model and see what price hangs from it.
Thanks so much for your reply and we'll certainly look into what you have recommended.
iDrive TDS-2010H...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
159119 (A60430)
159119 (A60430)
Vermeer 604 XL-Series (A62177)
Vermeer 604...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
