Rounded off drain plug
/ Rounded off drain plug #201
Many don't realize that an engine will run for quite a time with no oil. For those that go back aways and into drag racing: I remember a race between Grumpy Jenkins and Don Nicholson. These were called "Grudge Races".Grumpy had a 10 second 67 Camaro and Don was driving a 65 Comet . For the last race, Jenkins drained all the fluids out of his car as he thought "Dyno Don was sandbagging as he kept beating him two to three cars before the "money race". Grumpy beat him by half a car for the last race and ran the fastest ET of the two cars that afternoon. Of course lunched he the engine but didn't care.
Had a friend the was flying cross country in an airplane with a 6 cylinder Continental. Lost oil pressure and was about 25 miles from the nearest airport. He didn't touch anything. About half way there he said he thought he couldn't wait to get back to tell his buddies how long one of those things will run without oil pressure. It eventually seized with such force he thought it might rip the engine from the airframe. He dead sticked into an airport without damage, except for the chunks that got thrown thru the cowling when the engine came apart!
/ Rounded off drain plug #202
Well, that plus the stains on the front seat cushions. :) That's a trip not many walked away from.
/ Rounded off drain plug #203
I also had a 6 cylinder Continental incident while flying.
My crankshaft actually broke in flight with engine parts flying about.
Other than flipping the bird over from landing in a freshly plowed farm field nobody was injured.
The poor aircraft however suffered considerably but after repairing was back in the air 6 months later.
/ Rounded off drain plug #204
Over the years I have seen a number of people that have aftermarket added "oil pressure pre-start" pumps. Before you start the vehicle, an electric pump pre-pressures the engine with oil so you never have a so-called dry start.
Pre and post lube cycles are pretty standard in commercial operation.
/ Rounded off drain plug #205
Why stop at 30 seconds. The more the better, take it out and get some work done while you are at it. :shocked: :knockout: :shocked:
(I know you were joking but could not resist)
When one makes an inane comment like mine he should expect to get poked in return. ;)
/ Rounded off drain plug #206
After a tour through memory lane on the ups and downs of lube related incidences did OP ever get that plug out?
Will check in bout three days gottah get this food plot bed cleaned up and seeded.....all w/o oil.......heh
Truck is still in the shop, everything is on hold for the time being.
/ Rounded off drain plug #208
alrighty well good luck will check in at end of week.
got food plot to put in.
and now that the weather manipulators have prognosticated 7 severe hurricanes out of 14; got grading to do from one creek to another...
so have a great week...I do love a good drama hey could be a series?:laughing::D
/ Rounded off drain plug #211
A couple guys at work have snapon "plier wrenches". Im not fond of them for pipes, but in this case I think they would work.
They are kinda like a cross between a pipe wrench and vice grips
12-5/8" Plier Wrench
/ Rounded off drain plug #212
Growing up, when I asked Pa how tight, he told me as tight as I could (and then would follow behind me and finish tightening), until one day when I broke a bolt. He told me that was too tight. Of course that broken bolt was in a starter on a 69 Pontiac Catalina station wagon that Pa had spend 2-3 hours wrestling a new starter into.
/ Rounded off drain plug #213
“Pa, you said as tight as I could and that is what I did”
/ Rounded off drain plug #214
I have the medium pair, and large pair. They work great as long as you have the room to get them to bite. They usually require about a 1/4 turn to lock in.
They are my go to for removing broken bolts where there is a bit still sticking out.
/ Rounded off drain plug #215
This thread makes me want to round off a drain plug just to see if I can get it out! :laughing:
/ Rounded off drain plug #216
Any news from the shop on the truck? Chewin our fingernails off over that drain plug..... :jaded: :jaded: :jaded:
/ Rounded off drain plug #217
I’m pretty sure it wouldn’t be as big of a problem if you welded it in.
/ Rounded off drain plug #219
I was told to tighten it up 'til you felt it start to strip. then back it off two flats. :mad:
And leave it for the next guy ..... :rotfl::rotfl:
At least if you break it you gotta deal with it.. :duh: :duh:
Truck is back home, head replacement, wiring repair, fuel filter, fun stuff. Took friday and the weekend off. Plan is to pull the tires off the tractor and get them settled, then talk to the shop down the road about welding a nut over the bolt and removing it that way.
207269 (A52708)
207269 (A52708)
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
New/Unused Quick Attach Hydraulic Rock Hammer (A61166)
New/Unused Quick...
2 1/2 ft x 2 1/2 ft Metal Cage (A61166)
2 1/2 ft x 2 1/2...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
UNUSED KJ 33'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 33'X25'...
