Rounded off drain plug
/ Rounded off drain plug #181
I have to wonder how many people still have 8 point sockets?
They are handy for the random old square nut and pipe plugs.
I try and keep a hand full of hex headed pipe plugs around to replace the old square ones.
/ Rounded off drain plug #182
I still struggle to understand how an oil drain plug seized absent dissimilar metals. It should have went in with plenty of lube on the threads. Unless the oil has never been changed or someone hammered it home as has been described. But on a tractor who takes them to a shop for oil changes to subject them to being hammered...... :confused:
/ Rounded off drain plug #185
They always told me to tighten it up until it snaps, then back it off a quarter turn.
You were not told correctly. You are spoused to tighten it up until it breaks AND STOP JUST BEFORE.
/ Rounded off drain plug #186
I knew a maintenance mechanic at a plastics factory. He said their rule was:
Whatever it is, run it wide open until it breaks.
/ Rounded off drain plug #187
I think that is a transmission drain plug, so 14" crescent tighten till the second squeak.
/ Rounded off drain plug #188
I always start the engine up after the oil stops dripping and let it run for 30 seconds, to make sure that all of the old oil is out so that I don't contaminate the new lube.
/ Rounded off drain plug #189
Guess I'll poke the bear. Took longer to drag the welder over and set it up, then it did to get this one out. Total time for removal was 5 minutes. With impact and socket. Easy breezy. Even got some special effects in the last picture :cool2:
Now you have a proper drain plug made and tested to not to round off even with an impact wrench. Great job.
/ Rounded off drain plug #190
Not really. That is what a Crescent Wrench was made for!
/ Rounded off drain plug #191
That repair shouldn't count, the OP does not have a welder.
/ Rounded off drain plug #193
Some wonder how plugs get so tight. Read some of the comments on here, and I'm sure some of the posters have some sarcastic humor in their statements...but there are folks who come to the internet looking for "how to" advise. They come to a tractor forum thinking "those guys" know mechanical things.
Then they read something stated as humor and believe it. Maybe posters who post BS should at least have a funny face by it!
/ Rounded off drain plug #194
the /s tag is rarely used but most should pick up on it seems you missed it.../s
see it works!
Hey I'm just trying to win that free toaster for the 6th brahzzillian post!
/ Rounded off drain plug #195
I hope you are joking.
/ Rounded off drain plug #196
I have been known to disable the start and crank an engine till it has oil pressure after a change.
And if an engine has sat for the winter or summer I will usually crank them before I will start them.
/ Rounded off drain plug #197
Many don't realize that an engine will run for quite a time with no oil. For those that go back aways and into drag racing: I remember a race between Grumpy Jenkins and Don Nicholson. These were called "Grudge Races".Grumpy had a 10 second 67 Camaro and Don was driving a 65 Comet . For the last race, Jenkins drained all the fluids out of his car as he thought "Dyno Don was sandbagging as he kept beating him two to three cars before the "money race". Grumpy beat him by half a car for the last race and ran the fastest ET of the two cars that afternoon. Of course lunched he the engine but didn't care.
/ Rounded off drain plug #198
Many don't realize that an engine will run for quite a time with no oil. For those that go back aways and into drag racing: I remember a race between Grumpy Jenkins and Don Nicholson. These were called "Grudge Races".Grumpy had a 10 second 67 Camaro and Don was driving a 65 Comet . For the last race, he drained all the fluids out of his car as he thought "Dyno Don was sandbagging as he kept beating him two to three cars before the "money race". Grumpy beat him by half a car for the last race and of course lunched the engine.
I meant that as a tongue in cheek comment, of course. I have heard of Yamaha MC's which have intentionally been run without oil and suffered other abuses at Harley parties though, and they apparently will go for quite a while. One party that I know of they actually burned it to kill it, then somehow got it up on top of a utility pole where it stayed until the next party.
/ Rounded off drain plug #199
Why stop at 30 seconds. The more the better, take it out and get some work done while you are at it. :shocked: :knockout: :shocked:
(I know you were joking but could not resist)
/ Rounded off drain plug #200
Over the years I have seen a number of people that have aftermarket added "oil pressure pre-start" pumps. Before you start the vehicle, an electric pump pre-pressures the engine with oil so you never have a so-called dry start.
UNUSED KJ 20' BI PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20' BI...
UNUSED KJ 23'X22' DBL GARAGE METAL SHED (A62131)
UNUSED KJ 23'X22'...
2018 International DuraStar 4300 26ft. Box Truck (A61568)
2018 International...
2018 Dodge 5500 Bucket Truck 4WD (A63118)
2018 Dodge 5500...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
2009 Ford E-350 Cargo Van (A61568)
2009 Ford E-350...
