Lighting upgrade Kubota B7800
/ Lighting upgrade Kubota B7800 #1
rocco611
Madera Ca.
Kubota
I purchased some cheap LED work lights from Ebay. four of them cost $28 first one failed after ten minutes of use, then one by one all four of them failed within a matter of a few hours of use. they have a two year warranty, seller agreed to replace them providing I send pictures or a video showing them hooked up to visually verifiable 12v circuit. all four together with a working lamp in the circuit. I am sure buyers try to scam sellers now and then. After thinking about it I decided to just eat the cost and move on, I really dont want more of the same problem. the tractor vibrates some and I thought the vibration might have taken out the one of the connections , I busted the lenses out them traced the issue to the driver chip on the circuit board, kind of shame that the lenses are glued in, I could have probably repaired the circuit bypassing the driver chip and installing a resistor. the lamps were designed to work at a very wide voltage range. would have been a simple fix to just install a current limiting resistor for the voltage I am running. I looked for the best LED lamps I could find from reputable companies. they cost ten times as much or more than the cheap imports. I am surprised I wasn't able to find more negative comments online about these super cheap led lamps. I am now considering upgrading the generator to an alternator and going with incandescent work lamps, there is a lot to be said for just changing a bulb rather than replacing a whole lamp. I dont use the tractor often at night , maybe only 10 hours a year at the most. anybody have any luck with a brand of moderately priced LED work Lamps?
/ Lighting upgrade Kubota B7800 #2
I have a number of LEDs on mine and have had no problems to date.
Some I did pay a bit for and some are 'bargain basement' variety.
My favorite is a 12 led unit that has 4 spots center with the two outers 4's being flood. Simply awesome!
To the rear I have 2 ea 3" floods for snow blowing and under the rear cab roof a string of yellow leds that I tied into my turn indicators.
Even my dome light is LED.
/ Lighting upgrade Kubota B7800 #3
/ Lighting upgrade Kubota B7800 #4
try off road led light bars. you can get them at walmart, or tsc for about 30 bucks
/ Lighting upgrade Kubota B7800 #5
Check out either Desert Rat off road or 4wheel Parts. They have a good selection of less expensive LED lights. I have bought the 4" cubes for about $70 /pair, and a 13" bar (that lights up like daytime) for $79.
/ Lighting upgrade Kubota B7800 #6
Google Superbright LEDs good price, good people, great warranty, no I don't work for them.
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A61307)
Hobart Champion 16...
Bobcat 763 (A60462)
Bobcat 763 (A60462)
Kubota M1048A Forks (A60462)
Kubota M1048A...
2013 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR2DJ296618 (A61165)
2013 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2024 MAC TNAR39FR540 40FT T/A  FRAMELESS END DUMP TRAILER (A59906)
2024 MAC...
