30x50 Pole Barn
/ 30x50 Pole Barn #21
Nice looking building.
$20k installed and including concrete? Sounds like a great price.
That is what I thought. I don’t think I could get that price where I live.
/ 30x50 Pole Barn #22
I was quoted 42k for a 36x42x14 morton pole barn, no floor
/ 30x50 Pole Barn #23
Seriously, $20k?!
:shocked:
/ 30x50 Pole Barn #24
Getting our Morton 30x50 built in June. 30x50x16. $38,000 Sure could have used it over the week-end working on the tractor...It was a rainy week-end !
/ 30x50 Pole Barn #25
Just dropped the check off for the deposit , looks like august for me...
/ 30x50 Pole Barn #26
Friend of mine got his 30x50x14 done just before winter set in. $22K. No roof overhang. Two 12x12 overheads, two windows, one walk-in, insulation wrapped.
There are a tremendous number of variables in this type of construction. Each of those variables can be hidden from the quick glance. Each can move the price considerably. Finish trim is another area that changes cost dramatically. As does dimension of framing lumber.
What materials are used and how they are constructed can vary with location. Wind load and heat/cold being the most considered.
/ 30x50 Pole Barn #27
Correct I have a 65psf snow load 1' overhang all around ,1 man door 4' x6'8'' ,1 16x14 double sliding door , 1 3'6'' cupola
/ 30x50 Pole Barn #28
That was a very thorough contract they give you !! I will pour a floor myself later on. I thought about a cupola but didn't get one.
/ 30x50 Pole Barn #29
I'm storing hay so I wanted it plus vented soffit and the fabric on the roof panels (formed dry panel )
/ 30x50 Pole Barn #33
/ 30x50 Pole Barn #34
Did you get sliding doors or roll up doors ?
2 doors. 1 is 14x14 and the other is 12x10. Both are Raynor hi-lift doors not roll up. The 12x10 goes straight up the other is a angle track. Are you getting the perma column setup for the posts ? Morton is now using this system instead of sinking wood post in the ground.
/ 30x50 Pole Barn #35
Galvanized support stilt system , treated columns
/ 30x50 Pole Barn #36
The Morton rep here said they are getting away from the in ground post, so I think he gave me a discount on going with the perma column, for which I was very happy. I am getting beefier trusses as they are on 10' centers. Don't get much snow here.
/ 30x50 Pole Barn #37
The trusses are 7' spacing, 4/12 roof pitch, 306 style building
/ 30x50 Pole Barn #39
I didn't know Morton was up here. Thanks! Any person there you would particularly recommend to talk to?
/ 30x50 Pole Barn #40
They have sales reps , But Mark is mine I don't know if his territory is up there . I will PM you ...
ATS Mini Excavator (A66408)
ATS Mini Excavator...
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
JOHN DEERE 1705 - 6R30" VACUUM PLANTER (A64277)
JOHN DEERE 1705 -...
2016 Ford F-350 Pickup Truck (A61568)
2016 Ford F-350...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
