Question for those with Telescopic Stabilizers
/ Question for those with Telescopic Stabilizers #1
TheMadOne
USA
Kubota L3560HSTC-LE, formerly L3301
I just converted my L3301 to telescopic stabilizers. Honest question, does anyone actually use the cotter pins for the bottom of the adjustment pins? They're a bear to get to and I'm not sure what it would take for the adjustment pins to walk that far up to begin with.
Anyone have a pin work loose?
/ Question for those with Telescopic Stabilizers #2
Mine doesn't have any pins for the adjustment pins. Gravity keeps them in quite nicely. As well as the chain keeps them from getting away.
Yeah, they really seem like something the lawyers added, rather than an engineer, because the one time in a billion the thing slips loose and damages something they'll be able to point to it and say "Improper use".
/ Question for those with Telescopic Stabilizers #4
Yeah even if one pin "popped out" somehow, the implement still can't move side to side much because the link that still has a pin in it cannot be compressed or extended. It pretty well stays right where it is. But I have never had one pop out.
/ Question for those with Telescopic Stabilizers #5
Does anyone actually use the cotter pins for the bottom of the adjustment pins?
Someone may, but I do not.
No.
/ Question for those with Telescopic Stabilizers #6
My telescopic stabilizers came with this kind of pin.
Never lost one and are easy to work with.
/ Question for those with Telescopic Stabilizers #7
That's what mine have as well. It is surprising how one always (almost anyway) finds a properly aligned hole to drop the pin into when stabilizing the attachment. I can always get within 1/4 inch of dead tight. Neat.
/ Question for those with Telescopic Stabilizers #8
If I lost one of mine and couldn't find a replacement quickly, I would get the properly sized one of these for less than a buck.
/ Question for those with Telescopic Stabilizers #9
Over 1000 hours on two different tractors doing a bunch of brush cutting with out the safety pins with no issues.
/ Question for those with Telescopic Stabilizers #10
My 2016 Branson has drop-in pins, never falls out.
/ Question for those with Telescopic Stabilizers #11
The telescopic stabilizers on our current tractor and the one before it did not have a cotter pin on the bottom of the drop-in pin. Never have had one come out accidentally.
/ Question for those with Telescopic Stabilizers #12
1300 hours on my current tractor. I've lost one in all that time. My pins are just bolts. I welded a light chain to the head of the bolt, and the other end is attached to the bolt that holds the stabilizer to the lower 3 pt hitch arm. Of course, none have ever popped out since then, but the chain has saved me a hunt in the leaves on the ground a couple of times when I dropped the bolt while making a change.
/ Question for those with Telescopic Stabilizers #13
Well, I guess I’m just piling on, but plenty of bouncy work and never had one jump out.
/ Question for those with Telescopic Stabilizers #14
I've never lost one, and I don't use the cotter pins. Like the OP mentioned, they are a pain to put in once the implement is on.
/ Question for those with Telescopic Stabilizers #15
I have never lost one either. Sometimes a hairpin will hook a branch when logging and pull out but never have had a problem with anything on my TPH.
/ Question for those with Telescopic Stabilizers #18
My pins have a spring loaded ball bearing in the bottom of them. Just pop it down through the hole and the ball bearing keeps them from popping out.
My stabilizers came from stabilworks.
/ Question for those with Telescopic Stabilizers #19
No. Been using them on my 6530 since buying it new and chucked the cotter pin clip hootuses the first few times of usage. Don't need them and the pin is on a chain anyway so it isn't going to get lost even WHEN you forget to pin one side.
Utility Cart (A59231)
2022 Kubota MX5400HST (A64047)
2022 Kubota...
2008 DOOSAN G25 GENERATOR (A63569)
2008 DOOSAN G25...
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
20in Single Cylinder Grapple Bucket Skid Steer Attachment (A61572)
20in Single...
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
