Question for those with Telescopic Stabilizers
   / Question for those with Telescopic Stabilizers #11
The telescopic stabilizers on our current tractor and the one before it did not have a cotter pin on the bottom of the drop-in pin. Never have had one come out accidentally.
   / Question for those with Telescopic Stabilizers #12
1300 hours on my current tractor. I've lost one in all that time. My pins are just bolts. I welded a light chain to the head of the bolt, and the other end is attached to the bolt that holds the stabilizer to the lower 3 pt hitch arm. Of course, none have ever popped out since then, but the chain has saved me a hunt in the leaves on the ground a couple of times when I dropped the bolt while making a change.
   / Question for those with Telescopic Stabilizers #13
Well, I guess I’m just piling on, but plenty of bouncy work and never had one jump out.
   / Question for those with Telescopic Stabilizers #14
I've never lost one, and I don't use the cotter pins. Like the OP mentioned, they are a pain to put in once the implement is on.
   / Question for those with Telescopic Stabilizers #15
I have never lost one either. Sometimes a hairpin will hook a branch when logging and pull out but never have had a problem with anything on my TPH.
   / Question for those with Telescopic Stabilizers #17
I have lost one also.
   / Question for those with Telescopic Stabilizers #18
My pins have a spring loaded ball bearing in the bottom of them. Just pop it down through the hole and the ball bearing keeps them from popping out.
My stabilizers came from stabilworks.
   / Question for those with Telescopic Stabilizers #19
No. Been using them on my 6530 since buying it new and chucked the cotter pin clip hootuses the first few times of usage. Don't need them and the pin is on a chain anyway so it isn't going to get lost even WHEN you forget to pin one side.
Massey Ferguson 165 (A53317)
Massey Ferguson...
2017 Peterbilt 348 Truck (A55973)
2017 Peterbilt 348...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
2015 Autocar Xpeditor T/A E-Z Pack 40 Yard Front Loader Garbage Truck (A55852)
2015 Autocar...
TEST YOUR BID BUTTON! (A58375)
TEST YOUR BID...
2022 John Deere 1025R (A53317)
2022 John Deere...
