Rebuilding a retaining wall
   / Rebuilding a retaining wall
You need to get a copy of Stone Work by John Jerome. It is the month by month thoughts of a guy rebuilding a stone wall in New England. I'm sure you will find that it speaks to you as you undertake this project.
He built a property line wall that took a year. I don't expect mine will take much more than a couple of weeks, once I form a plan of attack and get started, during a dry spell.
   / Rebuilding a retaining wall #12
its hard to tell from that picture but it looks like the wall is ending under the deck and you may have a problem with the post there that is holding up the end of the deck.......I'd guess that the footing for that post does not go down to the bottom of the wall so when you remove the wall theres a good chance you will undermine the soil that the footing is bearing on.......general rule of thumb is if the soil within a 45 degree angle from the bottom of the footing is disturbed it has compromised its bearing capacity......if that is the case it's not a big deal you would just have to remove the footing thats there and install a new sonotube down to the level of the bottom of the wall and fill with concrete up to the post.......Jack
That post does not have a footing. It's a 4x4 in a hole in the ground that a contractor for the previous owner installed. I have already dealt with the other supports for that deck a couple of times and have fixed the problems there. I am planning to temporarily support it with a post on a spanner from the top of the wall to hard ground until I replace that support with a 4x6 ground contact treated support that goes onto a footing at the base level of the wall. The wall is barely leaning within 10 feet of the house, is thicker there, and in no danger of toppling at that point.
   / Rebuilding a retaining wall #14
Are there no drain lines coming out the end ? Or at least indications of drain hole every so often in the rock wall ?
50 years is not that long. It’s a sad situation to see all of that rock, effort, and money wasted. Not to mention you getting to tear it out and haul it off and repeating the material, effort, and cost to replace it. A bit of gravel and drain pipe would have made a large difference.
Keep in mind in many areas a very large drop off requires handrails. No idea if its a issue for your situation.
There are a couple of 4" pipes coming through on the inside, but they are stopped up with dirt. The previous owner likely compromised the wall by re-doing the sewer line that passes under it, (backhoe pads right by the wall) and by allowing a 6" holly tree (I removed stump four years ago) to grow about two feet from the wall along the middle of the span. Handrails are not an issue. I'll put a 36 inch welded wire fence above it if necessary. I think it will be one of those walls that steps backward with each tier.
Yes, It's a shame. The wall on the other side of the walk out is still almost perfect, and it's taller, with a fence to prevent falls.
The one that is failing is actually a concrete block wall with a rock veneer face.
   / Rebuilding a retaining wall #16
Just in case its been overlooked. There are various cloths and materials used to allow water into the gravel and drainage pipes but they keep the water out.
   / Rebuilding a retaining wall #17
What ever you do, don't try and do it cheaply. Invest the time and money to do it right. Soil pressure is a funny thing and unless you are going to place a moment slab and tie into a wall, pure mass and back batter are neccessary. 2nd is proper drainage. Over excavate about a foot behind the back of the wall and plan for geo fabric and stone as we as perforated pipe to handle the water. Water not only adds weight but it lubricates and reduces the shear strength of the soils. If you want to try and do it cheaper you can over excavate more and use geofabric to tie back into the slope and use geo cells/cellular confinement to create either a clean stone wall or filling the outside cells with topsoil and make a living wall. The sky is the limit really.
The first ten feet or so out from the house is more substantial and only barely leaning, not in any danger at all. I am hoping to somehow tie into that and not have to mess with that part, which is the trickiest, since it involves a deck support. Maybe take the veneer off that part and match it with a new wall on out from there. It's a concrete block wall with native rock veneer about six inches thick.
   / Rebuilding a retaining wall #20
Have you considered just excavating, straightening and then reinforcing the wall and adding some "tie backs"
I learned about tie backs at an early age. My dad told me to go get an old truck axle by the barn and dig a hole in the upper yard to match the outline of the axle and to put the axle in the hole. I thought he was crazy but the way I grew up I did not have any choice but to comply. Later I learned that he (I) was replacing the retaining wall between the upper and lower lawn and that axle was the tie back.
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
2019 CATERPILLAR 299D2 SKID STEER (A51242)
2019 CATERPILLAR...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A51039)
NEW 2024 LOAD...
