Oil & Fuel What type of trans/hyd fluid for Iseki TS1910
/ What type of trans/hyd fluid for Iseki TS1910 #1
tucker2
Member
Hickory,NC
Kubota L1500, Iseki TS1910,Trak King dozer
Looking at the dipstick the oil looks like a heavy transmission type, not the thin hydraulic fluid type most newer tractors use. Does anyone know the
correct fluid for the Trans/hyd.
Also does anyone know if any other brand tractor rims will bolt up to the Iseki rears?
/ What type of trans/hyd fluid for Iseki TS1910 #2
I owned a 1910 years ago, you will be just fine with any of the "universal" trans/ hydraulic fluids available at Tractor Supply, Wal Mart, etc. I generally buy the Xtreme brand available at Rural King for $25/ 5 gal.
As far as rims, I can't tell you off hand what other brand will bolt up. I would simply suggest that you measure your bolt pattern and go from there. Curious why you are looking for different rims?
FYI: A buddy of mine used HEY WHEEL PRODUCTS products to build a set of rims to mount R4 tires to his Iseki
Im not looking for different rims, on the used market a set of tires usually will come on some type of rims, Kubota, Chinese or other. Would be nice if
a set would bolt up, if not I will try to find new tires.
/ What type of trans/hyd fluid for Iseki TS1910 #4
I found the manual today for the TS series, as I just got something like a TS3510.
Here is a screenshot from the fluids page:
Thanks, my tractor looks like the transmission/rearend/hydraulic are all the same fluid area. It's always though when you don't have a manual.
/ What type of trans/hyd fluid for Iseki TS1910 #6
Инструкции к японским тракторам."Japan tractor manual" | Fermer.Ru - Фермер.Ру - Главный фермерский портал - все о бизнесе в сельском хозяйстве. Форум фермеров.
Look on here. It is a DJVU file, so you may need a special reader for it.
Hydraulic is separate from transmission. The transmission gets filled from the plug next to the shifting levers, the hydraulic from a screw off cap next to the lift arms.
/ What type of trans/hyd fluid for Iseki TS1910 #7
This should help you:
Thanks Andrew,
The diagram and website are great, lots of information. I can see the hydraulic has a seperate filler cap transmission so now I know to use modern hydraulic fluid, before I thought both transmission and hydraulics were the same.
/ What type of trans/hyd fluid for Iseki TS1910 #9
Is yours 4wd? I think there is also gear oil needed up front in that case, but I am still exploring my new tractor and haven't quite figured out where to fill there.
/ What type of trans/hyd fluid for Iseki TS1910 #10
Look for a pipe plug on the top side of the front differential and/or axle. That will be the fill for the front drive components. On Agco Parts diagrams for the 2-35 Field Boss, the plug is on the top left ( sitting on the tractor) side of the axle assembly. There probably isn't a dipstick but gear oil should be about half way up on the axle shafts. 80-90W gear oil is pretty standard for front end drive components.
10' Container w/ Side Door (A60463)
10' Container w/...
2011 WESTERN STAR  4900 SB (A60736)
2011 WESTERN STAR...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
CASE SV280 SKID STEER (A62129)
CASE SV280 SKID...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
iDrive TDS-2010H...
