Oil & Fuel What type of trans/hyd fluid for Iseki TS1910
/ What type of trans/hyd fluid for Iseki TS1910 #1
tucker2
Member
Hickory,NC
Kubota L1500, Iseki TS1910,Trak King dozer
Looking at the dipstick the oil looks like a heavy transmission type, not the thin hydraulic fluid type most newer tractors use. Does anyone know the
correct fluid for the Trans/hyd.
Also does anyone know if any other brand tractor rims will bolt up to the Iseki rears?
/ What type of trans/hyd fluid for Iseki TS1910 #2
I owned a 1910 years ago, you will be just fine with any of the "universal" trans/ hydraulic fluids available at Tractor Supply, Wal Mart, etc. I generally buy the Xtreme brand available at Rural King for $25/ 5 gal.
As far as rims, I can't tell you off hand what other brand will bolt up. I would simply suggest that you measure your bolt pattern and go from there. Curious why you are looking for different rims?
FYI: A buddy of mine used HEY WHEEL PRODUCTS products to build a set of rims to mount R4 tires to his Iseki
Im not looking for different rims, on the used market a set of tires usually will come on some type of rims, Kubota, Chinese or other. Would be nice if
a set would bolt up, if not I will try to find new tires.
/ What type of trans/hyd fluid for Iseki TS1910 #4
I found the manual today for the TS series, as I just got something like a TS3510.
Here is a screenshot from the fluids page:
Thanks, my tractor looks like the transmission/rearend/hydraulic are all the same fluid area. It's always though when you don't have a manual.
/ What type of trans/hyd fluid for Iseki TS1910 #6
Инструкции к японским тракторам."Japan tractor manual" | Fermer.Ru - Фермер.Ру - Главный фермерский портал - все о бизнесе в сельском хозяйстве. Форум фермеров.
Look on here. It is a DJVU file, so you may need a special reader for it.
Hydraulic is separate from transmission. The transmission gets filled from the plug next to the shifting levers, the hydraulic from a screw off cap next to the lift arms.
/ What type of trans/hyd fluid for Iseki TS1910 #7
This should help you:
Thanks Andrew,
The diagram and website are great, lots of information. I can see the hydraulic has a seperate filler cap transmission so now I know to use modern hydraulic fluid, before I thought both transmission and hydraulics were the same.
/ What type of trans/hyd fluid for Iseki TS1910 #9
Is yours 4wd? I think there is also gear oil needed up front in that case, but I am still exploring my new tractor and haven't quite figured out where to fill there.
/ What type of trans/hyd fluid for Iseki TS1910 #10
Look for a pipe plug on the top side of the front differential and/or axle. That will be the fill for the front drive components. On Agco Parts diagrams for the 2-35 Field Boss, the plug is on the top left ( sitting on the tractor) side of the axle assembly. There probably isn't a dipstick but gear oil should be about half way up on the axle shafts. 80-90W gear oil is pretty standard for front end drive components.
/ What type of trans/hyd fluid for Iseki TS1910 #11
I ended up filling it all the way. Didn't really see much inside, and specs are for 8 liters. About 5 liters went in, leading me to believe that there was some still in the middle.
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
American Flag Decorative Metal Sign (A61569)
American Flag...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2017 Ford F-150...
2013 FORD F-350 SERVICE TRUCK(INOPERABLE) (A60736)
2013 FORD F-350...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
