Grapple width. Same as bucket or narrower?
/ Grapple width. Same as bucket or narrower? #1
screamin400
Lee Center NY
2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
I have a grapple ordered from EA. Talked to Travis about width. I ordered a 72" dual lid as that is the width of my loader. We talked about a 66" and I thought I want the same width as my loader. I think I made the right choice but not sure I made the right choice. I have never used one. Weight is not an issue. We are talking 3 inches on each side. I do not want to get into a debate of dual or single lid just wondering if you went narrower than your tractor. I will be hiring out doing storm cleanups. Thanks.
/ Grapple width. Same as bucket or narrower? #2
I guess it depends on what you are going to use it for the most. I wouldn't go any narrower than your front tire spread for sure. If you are going to be picking up trashcan sized boulders I'd go same as your tire width, if mostly lightweight but bulky brush then I'd go wider.
Tractor is 71 inches wide. I felt I wanted to cover the tracks. I have a hard time bringing myself to not covering the width of the tractor
/ Grapple width. Same as bucket or narrower? #4
One advantage to a narrower grapple would be to let you access tighter areas. Ken Sweet
/ Grapple width. Same as bucket or narrower? #6
To me it depends on how open the area is that you operate in. I am always in the woods. I had a 6' bucket and it takes a lot of room, sweeping wide in turns. I got a narrow grapple - 42". What a huge increase in maneuverability - huge. And the grapple picks up anything just fine. I realize this is a different type work than most do.
gg
/ Grapple width. Same as bucket or narrower? #8
It depends on what you're doing with the grapple. If you are cutting a path through brush & debris, it can be handy to have one the same width as your bucket. On some grapples, an extra 6" or so in width can make a big difference in weight. Check your specs.
FWIW, the dealer recommended the grapple be the same width as the bucket when I bought mine.
/ Grapple width. Same as bucket or narrower? #9
I have a 72" bucket, 66" grapple. Would have liked to gone to 60" grapple, but couldn't find one heavy enough while still being affordable to me.
In my case, width isn't so important for clean up. A 66 inch grapple will grab an 8 foot brush pile as well as a 72 inch grapple. I wanted narrower for getting into tight spots.
Honestly, there's times I wish I had smaller; I've never wished for bigger.
/ Grapple width. Same as bucket or narrower? #10
<snip>
gg
Definitely
Yup
<snip>
That reads like a safe answer.
IF I was operating in open fields grappling cut down mesquite I'd want a wide grapple.
But in the woods
attachment.php
swinging my 6' bucket around is a pain, like Gordon says.
/ Grapple width. Same as bucket or narrower? #11
Are you running narrower than your tractor? How much?
I've been investigating purchasing a grapple and have come to the conclusion that most people buy grapples way too big! Who really needs a 60+" grapple to pick up rocks or logs? If you only need it to pick up brush piles my question is how many brush piles are you picking up? Maybe it would make more sense to have bought a chipper. Where are the 24" to 48" grapple manufactures? Stump grapples come close but most are way too long for my application, but I understand they are designed for stumps. Instead of reducing the weight of 55 to 60" grapples maybe they should manufacture narrower grapples that would work great with sub and compact tractors. Maybe some of the manufacturers can pipe in and explain why they don't offer narrower grapples.
Maybe I should back off to a 66". I am only looking to do storm cleanups and not sure what I will run into. I am sure there will be an occasional run into the woods to clear them also.
/ Grapple width. Same as bucket or narrower? #13
I would get the 66'' Its not like a dirt bucket ,Your picking up brush and trees ,You dont want to be running over the brush anyways, 66'' will work fine:thumbsup:
/ Grapple width. Same as bucket or narrower? #14
My tractor has a 72" bucket, but I went with a 54" grapple. Extra manuverability in the woods is nice, but not my primary reason for going narrow. The primary reason I purchased my grapple was to grub out some of the larger stones that are poking up in my fields. If I went digging around with a 72" grapple, I'd be tearing up lots of extra ground. 54" is pretty much ideal.
/ Grapple width. Same as bucket or narrower? #15
Any grapple beats no grapple.
Do you need the narrow grapple for maneuvering in tight spaces and how often are you in such spaces.
Are you trying to clean up wide areas and do not want your tractor running over brush, thorns, trash, etc. then a wide grapple works well.
Since weight is not a issue. If your not working a lot in tight spaces then it would seem a wide grapple would be more versatile.
If after using it a while you find that you made a horrible mistake in getting a wide grapple, keep in mind its not usually that difficult or expensive to make them more narrow. Snip snip and your done. Making it wider is a lot more difficult.
/ Grapple width. Same as bucket or narrower? #16
When I get chance that’s what I’m going to do. I’m going to cut my 66” grapple down to 48”. To many times I need narrow and never had a need for wider. I do some storm clearing and work in the woods also doing clearing. Everyone has different needs and need different size grapple that’s why so many choices but any grapple is better than no grapple.
/ Grapple width. Same as bucket or narrower? #17
IMG_0414.JPGi love my grapple. I use it almost every day my job allows me to be home to be on my tractor.
/ Grapple width. Same as bucket or narrower? #18
That's my point... why don't the companies building them make them narrower! I hope some of the ones lurking around here come up with something that is more suitable than a skeletonized unit! Decreasing the size of a stump grapple would also be nice!
I am thinking maybe I will back it down to a 66. 3" on each side does not sound like much but with the length of tractor with grapple and rear weight it could make a difference in getting around I guess.
/ Grapple width. Same as bucket or narrower? #20
My bucket is 72". I bought a 72" grapple to "cover tire width". The only problem I had with it was transporting to job sites. I sold the 72", bought a 60" and the 60 fits inside bucket for said transporting. Also, I believe the 60 provides more torque when digging rocks/roots out. Not to mention less strain on loader arms. As far as amount of material in each bite, I see no difference. Thats my story and I'm sticking to it.
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
1998 STOLL 35' GOOSENECK LIVESTOCK TRAILER (A63291)
1998 STOLL 35'...
2008 23ft. Zodiac Hurricane Inflatable RIB with 2007 25ft Myco T/A Aluminum Boat Trailer (A61574)
2008 23ft. Zodiac...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
