If you have Toolcat questions, ask them here...
/ If you have Toolcat questions, ask them here... #501
If your snow thrower is a Bobcat is it a high flow attachment?? Controller will not allow you to turn on high flow if it is not. Disconnect ACD cable and see if light comes on when activated.
Good Morning Jabonee,
I think you have part of my problem figured out. I did not know that the snowblowers came in the standard model and a high flow model and the best I can tell is that the one I have is the standard model. My snowblower is S/N 713100878 and is the SB240 x 72 model. Now with that said, I did as you suggested and disconnected all of the lines that go to the snowblower (hydraulic and electrical) and started the toolcat up. The High Flow switch did not illuminate and I have checked all of the connections on that switch and they test fine, I have checked all of the fuses and they are all ok. I rocked the switch back and forth and it did not activate. Do you have any further suggestions. As you can tell I am not the Toolcat expert, but I am willing to learn. Thank you for your help.
/ If you have Toolcat questions, ask them here... #502
Seems a little strange but I was just looking at the operators manual for the SB 240 and it don't list the 5600 as an approved carrier for the SB240. Anyway can you post the Toolcat sn#?:confused3:
/ If you have Toolcat questions, ask them here... #503
Thank you for the help, I have reviewed my notes and here is a complete summary of what I think I know.
I have a Bobcat SB240 x 72 blower S/N 713100878 and has a 9.6 hydraulic pump motor. I am running that on a High Flow Toolcat 5600. I have questioned two different Bobcat department about wheater this is a High Flow snowblower and have both assured me that it is. Now it that is true then I still trying to diagnose why I cannot get the high flow system to activiate. To the best of my recollection at the start of the snowblowing season I believe it did work normally. I also believe that I hit a concrete abuptment that was covered in snow in December, I was going pretty slow, probably under 5 mph. I do not remember the High Flow system working after that incident. I examined the Toolcat and the blower after that happened but could not see any damage and I continued to blow snow after that. I cannot remember if I was using the high flow system when I impacted that piece of cement. Later on in the season I realized the high flow light in the Toolcat was not longer illuminating when I tried to engage high flow. I though there may be an electrical problem so I checked all of the fuses and they were fine. I tried to check the relays by rotating identical relays in the cab fuse box and that still did not allow me to use the high flow. I checked high flow switch on the console between the seats with a test light and it seems to test correctly although the switch light did not illuminate. I did purchased a new high flow switch and changed that out and that did not change anything so I am pretty sure the original switch is good. I checked all of the electrical wiring that I could access on the toolcat and the snowblower and did not find and cracks or breaks. I have tried to get the high flow switch to illuminate both with the snowblower attached and with it detached and it does not light up either way. At one point I noticed that the hydraulic fluid was low so I filled at to the appropriate amount, but that did not make any difference.
As I stated earlier, this is my first year using each piece of equipment so in addition to giving me ideas of what to check next on the Toolcat/snowblower please answer these questions for me. If I have the snowblower attached, the aux hydraulic running and the snowblower running and I engage the high flow system will I see a decrease in Toolcat RPM's, will I hear a difference in the toolcat or snowblower, or would I feel any difference in the operators seat when the high flow system is engaged or disengaged? In other words, is it possible that the system is running in high flow (with the light not illuminated) and me not know it? Would hitting that piece of cement shut down the high flow system but allow both the Toolcat and the snowblower to operate in the non-high flow without me knowing it.
I hope this is enough information to allow you to help me, please feel free to ask any questions. Please know that I appreciate your help. Toolcat S/N A0W111788
/ If you have Toolcat questions, ask them here... #504
No you will not hear any change with HF. You might see your blower run faster. Yes a jolt could have loosened a plug or wire. Next step. Remove HF switch. Unplug from harness. Locate orange power wire #1790 in plug. use black wire in same plug for ground. Test is performed with KEY ON. Power is supplied by fuse#10. If you have power you next need to check continuity in the signal wire between HF switch plug wire#4230 light green and the display controller. you will need to remove the display to do this. At this point you need to confirm that the controller is being signaled to turn on HF.:thumbsup:
/ If you have Toolcat questions, ask them here... #505
Have you checked the pins in the connector on the boom arm from the SB240? Also check the wiring harness from the boom arm into the box on the SB240, make sure it's not damaged by snow or ice.
Once you plug in the SB240 into the Boom Arm connector and push the Hyd. Aux. buttom on the dash, and pull the trigger on the joystick, the HF light should automatically light up on the switch.
DEWFPO
/ If you have Toolcat questions, ask them here... #506
DEWFPO
Thank You Jabonee and DEWFPO, I really appreciate your help. Here is where I stand.
DEWFPO - I have tried exactly what you suggested and I cannot get the light to illuminate. The 7 pin connector seems to be pretty loose and the connection so I had my wife watch the light on the high flow while I moved the connector up/down/sideways when the blower was operating and the light did not come on.
Jabonee - Thanks for your suggestion, I will try that in a couple of days when it warms up just a little. I do have a question about checking the wire continunity to the display panel. I understand I need to remove that panel in order to complete that test. I wish I didn't need to ask, but I need to. How do I remove that display panel without doing any damage to it. Have faith in me, I have learned a lot, just keep me on the right track.
Now my next question is totally unrelated to the high flow issue. I cleared snow all winter with a set of tire chains that just did not do the job. My toolcat has a tire size of 27x10.5x15. I need to purchase chains for the four wheels that do not fall into the tread pattern of the Toolcat. They need to have either a chain pattern or a link diameter that keeps the chains on top of the tire instead of slipping inbetween the tire lugs. If you have a suggestion of what to get and where to get them and of the size I need to order, I would appreciate that help.
Thanks for all the help. Steve
/ If you have Toolcat questions, ask them here... #507
I have the same issue. The tire chains I have don't work well with the ag style tires on the toolcat.
I'm considering the diamond patterned "net-style" tractor chains or "duo-ladder" combination farm tractor tire chains.
I tried posting pics but couldn't capture the images. You can see them on tractor-tire chains-tractor chains
DEWFPO
/ If you have Toolcat questions, ask them here... #508
Have you tried it with the 7 pin connector not connected?
It should work just like my brush hog. Plug in the hoses, push the Aux Hydraulics button on the dash, the dash light comes on, at idle, start the blades spinning, push the High Flow switch, the light comes on and you can hear the blower turning faster.
/ If you have Toolcat questions, ask them here... #509
my toolcat does not have high flow but I have a S590 that does, I have a SB240 blower that s high flow, the blower works not bad on the toolcat, if attached to the S590 it will run both in standard and high flow, definitely runs faster in high flow.
on the S590 it will not turn on high flow if the attachment is not high flow rated but it will turn on without any attachment plug not connected
/ If you have Toolcat questions, ask them here... #510
DEWFPO
Thanks for the info. I have looked up this website before and found that for my tire size they only have like light truck cross chains
and that is what I have now. Thanks for the suggestion. Steve
/ If you have Toolcat questions, ask them here... #511
7 pin connector not connected. I detached the 7 pin connector and just let it hang, I started the toolcat at low rpm's and and pushed the aux hydraulics button on the dash board. I pushed the hight flow switch (the light did not come on) I gradually increased to full rpm's and pushed the high flow switch again, I did not get a light and nor did I hear a difference in the blower sound. Is there a procedure to check and see if I am getting power to the 7 pin connector? Can I do that with a test light and if so what is the proper procedure to check those 7 pins? Thanks, Steve
/ If you have Toolcat questions, ask them here... #512
It should go to high flow with the 7 pin disconnected. My F Series did and the G Series does. I think your D Series would also.
You need to find the solenoid valve that turns on high flow. There is a test procedure in the service manual.
/ If you have Toolcat questions, ask them here... #513
If your chute rotation and deflector are working the issue is not your 7 pin connector (ACD cable) FYI the system is CAN BUS not binary. Depending on the model and software version in the toolcat not all units will turn on when plugged into a HF attachment. Your issue is in the toolcat. You should be able to turn on HF with the ACD cable unplugged. The issue is simply. The controller is not being signaled to turn on HF or the controller is not signaling the valve to turn on hence no indicator light on HF switch. Did you check fuse # 10 yet?:confused2:
/ If you have Toolcat questions, ask them here... #514
HI Jabonee,
Yes I have checked fuse number 10 several times and it is intact. I will try to follow up on the controller. I have the service manual and I will wade through that. Thanks, Steve from Punxsutawney.
/ If you have Toolcat questions, ask them here... #515
HI Jabonee,
Two weeks ago I replaced a fuse (on another vehicle) that looked perfectly fine but when I changed it out, the accessory now worked. It's worth a shot to swap in another fuse before you go any further.
DEWFPO
/ If you have Toolcat questions, ask them here... #516
HI Jabonee,
I now have another question and that is about removing the instrument panel on the dashboard. I want to check the continuity of the wire you suggested. I read through the service manual on how to remove the panel but I do not want to damage anything. The service manual says to pry up the bottom corners until you can get a finger under it and then press the two connectors that are located along the right and left side of the panel. I tried this and put a lot of pressure on the bottom and pried it out a distance but not far enough to be able to release the side fasteners. I do not want to break that panel or damage the components behind it. I did have a metal clip fall out from behind that panel already. Have you removed this panel and if so how did you do it. What type of fastener hold the sides in place? Do you need to push one direction or another to release it?
Again, thanks for the help
/ If you have Toolcat questions, ask them here... #517
Removing the display is a real pain !! Its held in by tabs similar to the ones on the HF switch. Once you have the edge pulled up use screw driver at a downward angle to push the tab in.
/ If you have Toolcat questions, ask them here... #518
Have a 2010 Tool cat 5600 I have no power going to radio and can't find fuse box location for radio. Found the two fuse box location on drivers side but no blown fuses. Thanks in advance.
/ If you have Toolcat questions, ask them here... #519
Did it ever work?
Do you know if it is a factory (dealer installed) radio?
My 2013 service manual shows cab fuse 10 feeds #65 of C220, switched battery, radio option.
Don't know about the Toolcat, but car radios usually have a fuse at the back of the radio.
/ If you have Toolcat questions, ask them here... #520
Did it ever work?
I bought the unit two weeks ago pulled radio out and wired it to a batty and it fired up tested factory harness no power. I ordered service manual but has not showed up yet figured I post here for location till that arrives. Dealer is slow at calling with parts. On a good note if you need service they are slow to bill as well.
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2017 INTERNATIONAL LF687 DAYCAB (A60736)
2017 INTERNATIONAL...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
1997 LUFKIN 48X102 FLATBED TRAILER (A60736)
1997 LUFKIN 48X102...
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
