If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #491
on the bobcat 590 the auxiliary hydraulic switch is press once for standard and twice for high flow
   / If you have Toolcat questions, ask them here... #492
Thanks ill give that a shot and see what happens.
   / If you have Toolcat questions, ask them here... #493
Hi I was wondering if you guys would be able to help figure out if my toolcat has hi flow or not. I have a 2010 toolcat 5600 d series. Doesnt say hi flow on the ram up front buy i believe the previous owner re painted it at one point. How am i able to determine if its hi flow or not.
Mine has a switch on the console near the armredt that lights up when you switch to high flow. 2011 f series. Just a Google switch
   / If you have Toolcat questions, ask them here... #494
looking at a 2004 with just under 700 hours. are there any special procedures that i need to know to test the drive motors or anything else before i go look at this machine?
   / If you have Toolcat questions, ask them here... #495
Good Afternoon, I am new to the forum. I will ask my question and give what information I think may helpful in diagnosing my problem. I have a 2008 Toolcat which I pruchased used last fall. I have never owned a Toolcat before but I had it throughly inspected before I purchased it. My main reason for buying the Toolcat was to use it clearing snow from our 1 mile driveway. At the beginning of last fall all function were operational. During the winter I believe that I lots use of the high flow hydraulics. When I try to switch to high flow the indicator light does not illuminate, I do not feel any change in rpm's or see that the toolcat throws further than in standard flow. I am not a mechanic, I do not know much about hydraulics but I have tried to diagnose my issues which I see as: Is the high flow actually working and I am unaware of it. Why does the high flow indicator light not illuminate when I try to engage the high flow option when using my snowblower. How can I best determine if I have an electrical issue or a mechanical issue? Actions I have taken: I have checked all the fuses in the two cab fuse boxes. I have removed the cowling so that I can get at the electrical connections inside the cab and have tested those using a test light and they seem to work properly (except for the switch light not illuminating.) Prior to this I purchased a new High flow switch and installed that and it did not make any difference (no light, no change in flow.) I still have the cowling removed but would like to put it back together in the next couple of days unless someone has a suggestion. Feel free to ask me any questions and thank you for the help. Steve
   / If you have Toolcat questions, ask them here... #496
Is it a Series A or Series B?
Here is some info from an old thread: http://www.tractorbynet.com/forums/toolcat/67393-vs-b-vs-c-series.html
And the SN breakdown:
   / If you have Toolcat questions, ask them here... #497
If you are going to troubleshoot it yourself, you need a good multimeter and the service manual.
My guess is that there is a electric solenoid operated valve that activates high flow. Make sure the wires didn't get pulled off of it.
   / If you have Toolcat questions, ask them here... #498
If your snow thrower is a Bobcat is it a high flow attachment?? Controller will not allow you to turn on high flow if it is not. Disconnect ACD cable and see if light comes on when activated.
   / If you have Toolcat questions, ask them here... #500
as mentioned if its a bobcat blower and set up for high flow when you plug in the 7pin connector it automatically lights up.. so understanding the blower you are using is a big component of troubleshooting if there is even an issue..
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2007 Ford E350 (A55973)
2007 Ford E350...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
378721 (A54865)
378721 (A54865)
Towable Dewatering Pump (A59228)
Towable Dewatering...
