30x50 Pole Barn
/ 30x50 Pole Barn #1
audsp98
Birmingham, AL
Mahindra 3550 HST
Pole barn "kit" arrives
Took a few weeks to get the poles in the ground because of rain. The crew that's building it only builds on Saturdays.
The concrete is a 5k PSI mix. It was supposed to a 4" slab but because of reasons, it averages about 6".
Steel trusses going up.
Roof metal about done
Wall metal is progressing.
Last few pieces of wall metal.
Finished!
Tractor finally has it's home.
/ 30x50 Pole Barn #2
Good looking barn ! Always nice to be able to put equipment under roof! We will be having a 30x50x16 barn put up in June. I have to many other projects going to build it myself...plus I don't like going up on roofs anymore if I can help it. How many yards of concrete did it take ?
/ 30x50 Pole Barn
We'd planned on 21 yards but it took 31.
/ 30x50 Pole Barn #5
Congrats on your barn. I've gone back and forth on getting those trusses, but the added cost and travel time means I probably wont.
Why did you go with wire instead of rebar in your slab? Did they pretend to lift it while spreading it at first, or did they just keep it on the dirt the entire pour?
/ 30x50 Pole Barn #7
Too late now for you but anyone else pouring concrete around 6" X 6" posts if you put 2x 4/6 around bottom of post if you ever have to replace post it can be changed easier.
I did that on my last pole building and it let me pour insecticide down around the posts.
The metal trusses are way better than wood!
Just don't try to pull an engine from them!! :) (who hasn't seen the swing set/engine hoist?)
/ 30x50 Pole Barn
31 yards for a 30 x 50 , how thick is your floor?
Well...the barn pad was graded level and marked by our excavator. He marked the 4 corners and leveled the inside. When the guys showed up to start setting posts, they got off those marks. They rotated it around one of the corners by a few degrees. Well it was enough to throw off the grade by some amount. So that accounted for some of the extra concrete.
When they dug the holes for the posts, they had some equipment issues so what started as 12" holes 4 feet deep ended up being probably 18" holes about 4 feet deep. So when they poured the floor, concrete filled in the rest of the holes around the poles. I'd guess an average of 18-24" of concrete in each hole. So there's some of the extra concrete.
And finally, we were playing beat the rain to get it done in the first place, so we had a few days between rain showers. What started out as a nice hard dirt barn pad that was cut from a small hill turned into good bit of mud when you drive full cement trucks on it. So as one truck would leave, they would shovel out the ruts, making the floor thicker in the process. So there's the rest of it.
So as far as thickness...the front half of the building the floor is 6-8". The rear half is 4-6".
/ 30x50 Pole Barn
I went with wire based on recommendations from other professionals in the area. And the wire was much cheaper than the rebar.
They pulled it up as they went. I spent the whole day watching them prep, pour, and finish the floor.
/ 30x50 Pole Barn #10
That would do it, I wondered if the post holes were filled too I couldn’t tell from the pics. Looks good thought.
/ 30x50 Pole Barn #11
Sorry to hear this. As a contractor, one of the biggest red flags that I encounter is a concrete guy saying that they can pull up the wire, or rebar as they go. As you can see in your pics, it doesn't happen. Wire is 100% impossible to pull up and then walk on and keep inside the concrete. Rebar has a chance, but in every slab that I have cut open, it's laying on the dirt or plastic, not doing anything.
Wire is OK for walkways where you can keep it in the middle of the concrete and not walk on it. Rebar on chairs is the only way to do a big pad.
What's done is done. Cracking is mostly from too much water and the rebar, or wire is mostly there to hold the cracks together so you don't see them. When it's in the middle of the pad, it does a great job. When it's at the bottom, it doesn't accomplish this. If your pad was poured with as little water as possible, you shouldn't have any issues. You will know for sure in about a month. If there isn't any cracking by then, you're fine.
/ 30x50 Pole Barn
That would do it, I wondered if the post holes were filled too I couldn稚 tell from the pics. Looks good thought.
The post holes were partially filled with 2 80lb bags of concrete then topped off when the floor was poured.
/ 30x50 Pole Barn
While I'm sure it's not perfect they did get some of it pulled up.
The floor was poured on Feb 5th and there's been no cracking so far.
/ 30x50 Pole Barn #14
Great looking barn. I poured my pad last November and still haven't gotten he building up. The wire will be fine and even if you get a crack it happens sometimes. I poured a 42x50 (30x50 barn and a 12 leanto) and i used no wire nor rebar but mixed in the fiber at the plant. I have a 5" pad on 3-6" of stone and we did put three keyways across it and two saw cuts down the length. Two buckets of $150 sealer and I haven't had a crack anywhere. BUT, still no building. Anyways, great looking building... where did you order it from? Everything I have been pricing is well over $30k...
/ 30x50 Pole Barn
It was a local metal roofing place. They sell the "kits" minus doors and windows. They order the trusses from somewhere, supply the metal for siding/roofing themselves, and get the wood from a local lumber mill.
I'd priced the internet places as well. One of those roadside storage building places quoted me about $22k installed for the same barn without concrete. I'll have about $20k in mine when all is said and done, including concrete.
/ 30x50 Pole Barn #16
Getting ready to pour my floor in the next few days weather permitting. Contractor has bid to put plastic and wire in floor. The fiber mix was mentioned and is is a recommended option even with the wire and does fiber add much cost?
/ 30x50 Pole Barn #17
When I used the 1 yard pre mixed trailer, the fiber cost 3 or 5 dollars.
/ 30x50 Pole Barn #18
Nice looking building.
$20k installed and including concrete? Sounds like a great price.
/ 30x50 Pole Barn #19
Truss tails are supporting eve overhangs? Sealing the floor with a high solids product pays dividends. Not a fan of silicone or water based sealers, High VOC's, solvent based will always be superior in performance. Could not tell if you cut control joints in slab?
/ 30x50 Pole Barn
The truss tails are the eve overhangs. I'll look into the floor coating. Only having my tractor in there right now I can already see that keeping the dirt out is going to be an issue until I get water run to the barn.
I did not have control joints cut into the slab. I thought about it but never really made a decision so I guess I'm still undecided.
SHAVER HD-8 HYD POST DRIVER (A64277)
SHAVER HD-8 HYD...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
2017 Lincoln MKC Multipurpose Vehicle (MPV), VIN # 5LMCJ2C95HUL50284 (A65563)
2017 Lincoln MKC...
2005 International 4300 55' Bucket Truck (A62613)
2005 International...
2023 Bobcat T76 (A64126)
2023 Bobcat T76...
