F series vs BX series
/ F series vs BX series #1
corl
West Grove, Pa
2013 Kubota MX5100 HST, 1989 Kubota F2100
As I have had an F2100 for the last 28 years and loved it I am debating about a new F series or a BX series machine. The $10,000 difference makes me wonder if I could do almost everything with the less expensive tractor. My mower deck is getting holes in it and it can not be replaced. Kubota has nothing to attach to the F2100 to mow. I can only use a 60 inch deck as I need to get around and through some tighter areas. I am older and don't worry about the stamped deck of the BX doing the same thing that my stamped R60F24 deck has done. I should be gone before it rusts or gets holes in it.
What has prompted those of you that have the F series to buy it? My guess is that it isn't as tough as my old F2100 but again I won't need it for another 28 years. What does your machine do that the BX series can't do?
/ F series vs BX series #2
..........What has prompted those of you that have the F series to buy it?.............
We already had a Grasshopper 61" front deck rear discharge mower (hers) but I wanted a larger used mower with 4x4 and larger wheels - BX or any other mid-mower tractor was not considered.
1. Commercial grade mower with fairly large wheels
2. Easily able to see the front mount deck
3. Able to mow underneath hedges & low hanging tree limbs.
4. 4 x 4 & differential lock with turf tires
5. Able to lift up the deck quickly for more traction if needed.
6. 4 cylinder Diesel
7. Rear discharge 72" deck
:cool:
/ F series vs BX series #3
I love my Grasshopper, but would prefer a 4x4 Kubota F for traction. If I knew how to rig a small FEL for it (like Xfaxman did with his Groundmaster) I'd get a Kubota F asap. I'd have what seems to be the best front mount mower there is, combined with 4x4 traction, and a small FEL for use in tight spots and on nice turf.
/ F series vs BX series #4
:cool:
Ditto plus I also have a BX and an L with the FEL on hand. Choosing to only have one would probably take me to another B or utility L with FEL and 72" RFM (Had this set up in the past) instead of a F or BX. I've owned two F3080s 4wd and a F2680e 2wd plus almost all sizes of BXs at least once and many different Bs and a couple of Ls. :2cents: And I to am not as young as I was.
/ F series vs BX series #5
I have a bx2680 and the f2690. If I could only have one it would be the bx2680, since I can do multiple things with it. But with that said I would probably kick and scream if I had to give up the F. The bx has a great cut and the fel is okay for what I need. I don't need to explain about the F since you have one. I replaced my zd326 zero turn with the F late last year. Very glad that I finally listened to everyone about how good the F's are.
So bottom line I am glad I don't have to choose between the bx and the F, you have a larger Kubota tractor listed on your profile so the F would be for me if I had the other tractor.
/ F series vs BX series #6
Slopes. My sole reason for my purchase. I tried zero turns and they went sliding down the hill and about into my creek.
I also needed the 4wd. A BX would not handle the slopes I mow with my F3990.
Well I started talking to some Kubota dealers around me. I found out there is a kit to adapt a newer deck to my F2100 (some leftovers). The BX will mow inclines as steep as an F series since it has 4WD and good weight distribution. My steepest slope is about 30%. The BX will also do some good things for me as it has a 3 point hitch and a live PTO. The real work gets done with my MX5100 but I could do with a smaller frame for some jobs. So now I need to decide which it will be. My wife says 30 years on a tractor is enough and I should buy a new one. If I do I will keep the F2100. My wife is a keeper too!
/ F series vs BX series #8
F series will mow circles around the BX. With you having an MX5100 already I vote F series.
/ F series vs BX series #10
I would not mow the same inclines with the bx that I do with the F. What I am talking about is mowing the banks of ditches sideways, up and down the bank no problem with either machine. But I feel more secure on the F when mowing ditches, that might just be me though.
/ F series vs BX series #11
............... I found out there is a kit to adapt a newer deck to my F2100 (some leftovers)................
I replaced the deck shell on my F3060 last summer and would do that if the rest of your F2100 is still in good shape.
If you bought a conversion kit would you be able to reuse any of the old parts like the deck drive shaft, 90 degree gearbox, spindle assemblies etc. like I was able to reuse all of them?
If not, maybe you could sell them online to other F2100 users.
By the way, it looks like RC60-FZ21 deck shell (76578-41160) is still available for F2100 - not sure if that would work for you or not?
Kubota RC6-FZ21 Parts Diagrams
I know it's expensive but you can not buy equal mower or tractor for that price, so it depends on condition of the rest of your F2100!
:2cents:
I turned the front tires around on my F2100 when I got it to increase the width and it made the machine lots more stable. Still love that machine. I too feel comfortable mowing sideways on it.
The new deck would be complete with the adaptors to hitch it up to my F2100. The deck would be about $3500.00
/ F series vs BX series #14
Ouch!
$2200 for a new 76578-41160 deck shell sounds more reasonable!
I have decided to keep my F2100 and rehab the mower deck using composites to repair the holes in the deck and using Rust Grip (TM) to coat the underside of the deck. (Its interesting stuff) The repair will be just a few hundred dollars as opposed to thousands. In addition I will add the Kubota BX series tractor to also cut some grass and use it as a smaller tractor in my commercial produce garden. I use the "Bayou Gardner" technique of plant a row skip a row in my garden and the 48 inch rototiller will give me about 1/3 more rows than my 74 inch tiller, thus increasing the produce rows without enlarging the garden. Nunamaker Farms - Home
/ F series vs BX series #16
Wished we lived close by, you put a lot of work into your gardens. My wife would love it.
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
(APPROX. 29) ASSORTED ROUGH SAWN PINE (A64276)
(APPROX. 29)...
2022 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2022 GMC Sierra...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
(2) SUPER SAVER HEATERS & PARTS (A64278)
(2) SUPER SAVER...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
