New Bee
/ New Bee #12
Beautiful machine!!!!
Not lecturing, just passing on a hint in regards to using the HVT. When you push on the go pedal you do two things, you increase engine rpms and you cause the hydraulic drive to gear itself up. So if I am climbing a steep hill or pulling an extremely heavy load I can sometimes make better progress by coming off the pedal just a little.
It's because of this quirk that I added a hand throttle. It only increases engine rpm. You still use the foot pedal to move. So in extreme conditions I pull the hand throttle to wide open engine speed. Then I use the foot pedal to apply movement. This lets the engine operate at it's maximum torque range. It also lets the HVT operate at it's maximum torque range. Result, high engine rpm and very slow ground speed.
Maybe your machine came with a hand throttle?? Mine is a 2008 model and it did not.
/ New Bee
I won't take it as lecturing at all. You have the experience I don't have with the HVT.
I do not have the hand throttle but have wondered what people use it for. I can see that is a good case for one. I am very hilly here and can see a very positive need for it.
I think I've seen one at Messics(sp) for around $80. It remind me of a vernier throttle/prop control off an airplane. lol
Thank you for sharing...
/ New Bee #14
I think I paid close to $100 by the time it shipped. Yes, very similar in design. Push the button on top of the knob and pull, releasing button when you are close to what you want. Then turn the knob clockwise to increase, counterclockwise to decrease engine speed.
I don't use mine a lot. But I've been in situations in the steep timber that required it to get out of.
Black knob up and to the left of the small orange knob. Your location might be different. Very easy kit to install.
/ New Bee
Cool. Thank you for the pic. I have a blank in the same spot yours is installed. I'll order one today.
BAM!!!
I haven't even been on here 24 hours and I've learned something important.
Thank you very very much..
/ New Bee #16
/ New Bee #18
That throttle kit even comes with a cute little sticker telling you what the knob does. :D
/ New Bee
I saw a label on a snow blower that said it was NOT to be used on a roof. What the heck?!? I think is someone's God given right to use a snow blower on their roof! What I have a problem with is if they use it on their roof and don't video it for our entertainment, that's down right selfish! lol
/ New Bee #20
Definitely!!!!! :D
Freightliner Columbia (A61307)
Freightliner...
2019 FREIGHTLINER M2 4X2 26FT CDL REQUIRED BOX TRUCK (A59906)
2019 FREIGHTLINER...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
2024 Linx UT708318T (A60463)
2024 Linx...
Classic 1969 Massey Ferguson 135, newly rebuilt engine, refurb front end, 3-pt blade.
Classic 1969...
