Welded table base for concrete dining table
/ Welded table base for concrete dining table #1
joeu235
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
I was hired to make a concrete dining table with a hedgehog shaped base. It's made out of 2 x 3 x 3/16 tubing. Hopefully you enjoy the video.
/ Welded table base for concrete dining table #3
OOPS - - click equals - "This video is unavailable".
sorry, should work now
/ Welded table base for concrete dining table #5
How do you get it in the house?
Then can the homeowner ever move it?
/ Welded table base for concrete dining table #6
I really like the design, How much does the top weigh?
The bottom fits in a a 30 inch door opening barely when turned sideways and weighs probably 120 pounds. The top is 400 pounds. I paid two young men to help me move it into the customer's house and set it up. The next time it needs to be moved is the customer's problem. They were made fully aware of how much it was going to weigh before I started.
Not exactly welding but part II of the the dining room table, making the top.
/ Welded table base for concrete dining table #9
Cool job, very well done.
/ Welded table base for concrete dining table #10
That is very nice and you did an excellent job on it. Kind of a strange project though. I can’t see why anyone would want something like that so heavy in their house. Will be a pain for them to move around.
/ Welded table base for concrete dining table #11
I'll bet it doesn't shake when it gets bumped though.
/ Welded table base for concrete dining table #12
Very nicely done joeu235!
I'm not convinced I'd like the concrete finish myself, however I have seen some beautiful concrete floors where the contractor has been paid to grind the surface with a diamond faced disk. They cut a lot of the surface away so that you can see individual stones in the aggregate sliced through in cross section. Very cool, but very expensive when I asked for a quote!
I took a beating on the table top part of the job. I had to make two of them because the first was a failure. I probably ended up making $10 / hour and put me way behind on the next job. When I delivered it, the customer said they wanted me to make them similar concrete counter tops. I replied this the first and last time I'm doing something like this. At least the customer is happy.
That is very nice and you did an excellent job on it. Kind of a strange project though. I can稚 see why anyone would want something like that so heavy in their house. Will be a pain for them to move around.
I attached black UHMW pads to the bottom of the base. It slides relatively easy without scratching the floor but getting it out of house next time is thankfully not my problem.
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
2016 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 VOLVO VNL 6X4...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
ROGERS 19' DOVETAIL TRAILER (A63291)
ROGERS 19'...
