what size trailer
/ what size trailer #1
Stomper
Gold Member
Saskatchewan, Canada
2017 Kubota L2501
What size trailer would I need to haul around a Kubota L2501 with FEL. Weight of the tractor and FEL is just over 3400 lbs according to the manuals. I have a 22 foot snowmobile trailer with 2 3500 lbs axles. According to the numbers it should haul it but I don't think I would want to attemp it. I would be much more comfortable with a car hauler type trailer. Whats your thoughts.
/ what size trailer #2
Are you going to be hauling this tractor around a lot, or just trying to get it home? Are you planning on hauling it with any large 3pt attachments on it, like say a rotary mower? I have an 18' tandem axle car trailer, and with my rotary mower hitched to my tractor, it overhangs my trailer by a couple of feet. That's with the bucket on the FEL, and the bucket sitting flat on the deck.
If you're only moving it home and done, consider renting a trailer. If you're going to haul it around frequently, get enough trailer to clear the length of the biggest attachment you ever think you may buy for that. Same goes for tractor size. If you ever think you may go bigger on the tractor, get a larger trailer now, instead of having to rebuy the trailer when you buy bigger tractors.
My next flatbed trailer is going to be a gooseneck, deckover, probably 28'-ish, so I can haul my tractor, plus a couple of implements at the same time. I want the deckover to make it easier to load/unload pallets, hay, lumber, or whatever with just forklift forks and less manual stacking to clear the fenders on a standard deck car trailer.
/ what size trailer #3
Yep, need more info. How often and how the tractor is configured are all important factors.
So far you said just tractor and FEL and 3400#.......thats no problem for a trailer with a pair of 3500k axles.....
But since you are asking the question.....I am assuming there is more to this story
/ what size trailer #4
Since your L2501 is just over 3400 lb you should easily be able to use your 22' 7K trailer providing the trailer floor is strong enough and you can tie it down.
What concerns do you have that would make you not want to attempt it?
/ what size trailer #5
22ft with 3500lb axles, I'm thinking enclosed trailer?
I use an 18ft car hauler type trailer to move my B2620 around, with an implement on the back it can get tight quick.
If you do have an enclosed trailer it should do fine but can be a pain if you're planning on trailering it alot.
/ what size trailer
The trailer is not an enclosed and floor is 2x6 planking and is supported every 4 feet. For tie downs, the side of the deck has stake pockets made from 1/4" material and a rub rail made from 1.5 x 1/4 flat bar around the whole perimeter. The deck is above the tires putting the center of gravity up a bit higher. Thats my main concern. It would be used maybe 4 or 5 times a year for approximately a 100km round trip. It would just be the the tractor and grapple with no implements being hauled. Right now we use it to put the quads on to get them to the areas that a buddy and I harvest firewood. He has a similar trailer that we also use. We harvest the firewood, put it on his trailer, Him and his son haul the trailer load of firewood home and unload it. My son and I stay and continue to cut wood, they comes back we load his trailer again with wood, load up the quads on my trailer and head home. I want to do the same process with my tractor. I have someone wanting to by the trailer from me, so I'm just checking if it would be worth it to sell it and just bite the bullet and get a car hauler type trailer which would be more suited for it. With a heavier trailer I am hoping that I could possibly haul my tractor and also some firewood with any left over deck space.
/ what size trailer #7
Just my opinion but if you have someone ready to buy your existing trailer and you are concerned about hauling your tractor on it with its high center of gravity then sell it and buy a lower decked car hauler.
The car hauler will be able to haul anything you haul on your current trailer. On the plus side, a car hauler will have better support for the flooring and the lower center of gravity. Usually 12-16" spacing instead of your current trailers 4' spacing. I'd stay with a similar length 20-24'.
/ what size trailer #8
Tractor with loader and grapple puts alot of weight on the smaller front tires.
That in combination with a 4' span for the 2x6.....I'd be afraid of putting a wheel through a deck board.
Go to Lowe's and buy a $5 2x6.....support it on a couple of cement blocks or pieces of firewood....48" apart.....not to high though. Drive over it and draw your own conclusion
/ what size trailer #9
You may need to bolt each end of the 2x6 to something, if it's so on the trailer. In any case, I'd just weld some more supports, to make it 24" centers.
/ what size trailer
I figured the same about all the above comments. I just wanted to confirm. I will sell it and get the proper one. Thanks
/ what size trailer #11
I have comparable-sized tractor (3700lbs) and went with this trailer: Big Tex Trailers 7TV Tandem Axle Vanguard | Big Tex Trailers in a 16' bed size.
I added two more ribs to the tailgate and a couple of substantial D-rings in the bed. I haul my tractor up and down a long 7% grade with no issues. It'll handle the FEL and box blade or flail, but the 5' rotary is too long with the FEL. It also works great for hauling tree trimmings, sand, brick, even two cords of firewood.
It's the only trailer I own that has brakes. It weighs right at 2000lbs empty, which leaves me 5000lbs for cargo. I tow it with a 5.7L Tundra 4x4, which pulls and stops it with authority.
/ what size trailer
Now thats a sweet trailer. Would be even better if it was a dump trailer
/ what size trailer #14
Your axles are adequate, but how’s the rest of the trailer? All the snowmobile trailers I’ve seen are pretty light. I wouldn’t have that big Tex pictured above unless the sides come off. Even then the sides are a waste of money unless you’re a landscaper wanting to haul mulch. Chaining down would be way harder than necessary and loading other things with the loader would be difficult. Here’s my grandpas trailer he uses to haul his L3800. It does the job but I’d like a little heavier trailer because you’ll overload it pretty quick with firewood or logs. I’d like a 14k trailer to use in place of my 22k duel tandem goose neck that pulls like a battle ship. IMG_0909.JPG
/ what size trailer #15
Your axles are adequate, but how’s the rest of the trailer? All the snowmobile trailers I’ve seen are pretty light. I wouldn’t have that big Tex pictured above unless the sides come off. Even then the sides are a waste of money unless you’re a landscaper wanting to haul mulch. Chaining down would be way harder than necessary and loading other things with the loader would be difficult. Here’s my grandpas trailer he uses to haul his L3800. It does the job but I’d like a little heavier trailer because you’ll overload it pretty quick with firewood or logs. I’d like a 14k trailer to use in place of my 22k duel tandem goose neck that pulls like a battle ship. View attachment 537937
While I'd prefer a full-sized dump truck pulling a 14k+ trailer, my needs don't justify the expense. I can't justify the expense of replacing my tried-and-true Tundra with a 1+ton tow vehicle, as I don't do work for others with my equipment and haul less than 10 trailer loads a year for myself. While the Tundra is a very capable half-ton, and is rated to tow 10,700lbs IIRC, I've had about 10k in equipment trailer and 3/4 ton Chevy crew cab behind it on a steep grade, and did not enjoy that experience. I decided to buy a trailer that would carry tree trimmings and brush well, and would carry the tractor as needed - not the other way around. It was relatively simple to add some stout D-rings in the bed of the trailer, bolted through the crossmembers. It's as big as I want to maneuver through the trees on my property, is plenty wide for the tractor, and keeps me from overloading my tow vehicle. It makes a very capable rig for transporting my CUT, which is very similar to the OP's needs.
Now when I need to haul a serious piece of equipment, like a frontloader, road grader or excavator, I call my wife's uncle. He's happy to loan me any of those, a lowboy, and a Kenworth (at least the last one was). Waaay too much rig to transport 4k of CUT, though, and rather limited in the woods around my house. :)
/ what size trailer #16
I never recommend a heavier truck or 14k trailer because I understand it would be ridiculous for your needs. A 7-10k car hauler trailer will be plenty.
/ what size trailer #17
I debated getting a car hauler and adding sides. That's very common in my area. For my use, the trailer with sides works better than a car trailer, especially after adding a couple of ribs to the tailgate. It's the same size deck. It has spoiled me a bit, as I can contain a load better. I've hauled pallets of bricks and retaining wall blocks, as well as gravel, rock, fill dirt, fertilizer, firewood, and 16' lumber. For trimmings and brush. I was using bucket forks - but I just bought a EA Wicked Root Grapple. Either way, load it and throw a few ratchet straps on it, cinch it down and go. Unloading is more time-consuming, but a large enough dump trailer to haul the tractor would weigh too much. My neighbor is happy to trade me tractor work for use of his 5x12 hydraulic dump trailer if I need it.
If I'd had the funds, I would have bought a car hauler and a smaller hydraulic dump trailer. That would have been close to triple the cost, though.
/ what size trailer #18
Better oversized than undersized. A member here posted about his experience a few years ago; he suddenly found himself trying to control his truck at highway speed after his front straps snapped and the tractor rolled back. He later determined that although the trailer and tie downs were rated heavy enough for his tractor the former had flexed on a bump, causing his straps to fail.
/ what size trailer #19
I have 20' flat 10K equipment trailer and would not recommend anything less for a class 2 CUT. One thing that is frequently omitted when talking about trailer length is axle location and available space to place the tractor on the trailer and achieve the correct tongue weight.
most 20' are 18' flat 2' dove. Im not a fan of this as i frequently haul hay or other flat goods that would be problematic on the last 2' of non-flat trailer. If you were in a location that has good trailer fabrication you might be able to order a movable dovetail but again the extra cost over just a flat deck would be something you would have to justify.
I have strongly considered a 24' - 18' tilt 6' stationary version. I think the tilt decks are a good option if your going to moving drive up equipment on it frequently. If your not using it more than once a month i don't think it would be worth the extra cost.
I do like removable ramps that store below as opposed to attached fold up ramps. fold ups can interfere with the ability to hang mowers etc off the rear of the trailer.
/ what size trailer #20
Here's my 22 ft 10k tilt. I'm pretty satisfied with it as is.
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
Connect CH65 Hydraulic Breaker Excavator Attachment (A64194)
Connect CH65...
2016 P.J. Deck Over Trailer, VIN # 4P5F82028G1250354 (A65563)
2016 P.J. Deck...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2008 International 8600 Day Cab (A62613)
2008 International...
2017 International 4300 Box Truck (A62613)
2017 International...
