Snow Equipment Owning/Operating Cutting / Groving / Siping R-4 for snow
/ Cutting / Groving / Siping R-4 for snow #561
I have a PORTER-CABLE PCE605K 3-Amp Corded Oscillating Multi-Tool. I think I may try it on one of my lug's tomorrow. It is a great tool for cutting trim and removing grout. It has a built in depth gauge also.
So how did the oscillating tool work?
/ Cutting / Groving / Siping R-4 for snow #562
Don't they use something like a oscillating tool to remove broken arm casts. I doubt it will work:2cents:
/ Cutting / Groving / Siping R-4 for snow #563
No clue. Either oscillating or die grinder I.D assume.
I’d never use an oscillating tool on a tire but I’m still curious to see how it worked. I have a groover that works awesome and has done several sets of tires. Mine and others.
I would assume the oscillating tool would jump around a little and be inconsistent with depth. I could be wrong and that’s why I’m curious.
/ Cutting / Groving / Siping R-4 for snow #564
We use an oscillating saw with fine teeth- it gets pretty warm, but won't cut skin.
I doubt an oscillating tool would work well in this application.
/ Cutting / Groving / Siping R-4 for snow #565
I agree. I've used an oscillating tool, and it's great for certain applications, but having cut rubber with a knife I don't think it would work well for grooving tires.
Get the right tool for the job and it will go 100x better.
/ Cutting / Groving / Siping R-4 for snow #566
Talked to the local Tire dealer. When the tires are new, they could put in screw-in studs. They work well on ice, but can be hard on pavement. We don稚 have any pavement so it would have been a better choice, though the grooves certainly help.
/ Cutting / Groving / Siping R-4 for snow #567
Those are packing nicely with snow- and mine look just about identical, so I won't post 'em.
/ Cutting / Groving / Siping R-4 for snow #568
I absolutely need to prioritize this next year. I've had the cutter for 2 years now. I've been sliding up and down my driveway the whole time.
/ Cutting / Groving / Siping R-4 for snow #569
You could also put some metal screws into the lugs.
Ralph
Thats what I did as a kid in order to ride my dirt bike on ice. I put s short sheet metal screw in each lug of a knobby tire. Worked great! I left them in all year.
/ Cutting / Groving / Siping R-4 for snow #570
I did this in the tracks on my fourwheeler; I found that they wore fast and were backing out. Only left them in the one season... but traction was amazing!
/ Cutting / Groving / Siping R-4 for snow #571
They did wear fast, but I never had any back out.
/ Cutting / Groving / Siping R-4 for snow #572
I may have posted this upthread, but since I see more comments about screws/studs I'll post again.
We bought screw-in carbide tipped studs for our forklift. We got the #1200 because we do use it inside on concrete. The only protrude about 1/32" but make an incredible difference in the snow.
Traction | Chinook Fork Plow
/ Cutting / Groving / Siping R-4 for snow #573
I wish we had those in the 80's! A icy sloped parking lot with a fork truck is real fun. We did use the plain ice race screws that helped alot.
/ Cutting / Groving / Siping R-4 for snow #574
I saw a video on You Tube where he was using an oscillating saw to remove whole lugs. Not sure how it could be used to groove a tire.
The cheepest I've seen the tire grooving irons is About $80.
/ Cutting / Groving / Siping R-4 for snow #577
I grooved all four of my tires. I have nothing to compare it to - I didn't see the point of struggling for a winter and then adding the grooves to see how much better it would be.
The grooving itself went OK. It was near freezing and a bit windy. I can imagine it being quite a bit easier on a warm summer day, but it wasn't too bad. I did it in a total of three sessions. The first was a trial run - I did maybe a half dozen front lugs. Then I did most of the rest; I was getting physically worn out pushing that tool... Finished up with 26 rear lugs a couple days later.
Only used it three times in snow so far, but no problems whatsoever with traction. Thought I'd share a few pics that (I think) demonstrate why it works.
/ Cutting / Groving / Siping R-4 for snow #578
A lot of work but you won’t be sorry when you need the traction in snow or mud,nice job thanks for sharing.
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
2015 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
UNUSED ATSPOWER GASLESS WELDING MACHINE (A64281)
UNUSED ATSPOWER...
2016 Hyundai Sonata Sedan (A61574)
2016 Hyundai...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
