The B2650 count down has begun!
/ The B2650 count down has begun!
I don't use the 911, I was just making the statement because I'd seen recently where folks who are freezing are saying that the 911 is cleaned from the shelves this winter. I've been (and my father as well) using Muscle Products FT-10 for about 20 years now and I've never seen a freeze/jell issue with full. This winter I'm actually using my tried and true FT-10 and also adding the Power Service winter blend. We are seeing usually cold weather here in Western Pa. So I decided to hit the Diesel with both barrels blazing. No issues in our diesels, we made it without any drama.
I'll bet that RC is angling to get a free Kubota hat from his dealer.:D
/ The B2650 count down has begun! #103
Got a call from my dealer today. He was just on the phone with the factory and said everything was in stock and ready to go except for the loader... the factory said there is supposed to be a group rolling off the assembly line next week. I can稚 wait for it to get here. Of all things to
Not be available I would expect the loader to be last. But it
Is what it is.
/ The B2650 count down has begun! #104
Geeze Dan,
I don't think you can go for another week without some sleep. :laughing:
I was so sleep deprived that well that the dealer got the unit and was assembling that it effected my work....
I had my salesman sending me pictures during the day to let me see what was getting accomplished. Ask your to text you every 3 or 4 hours while it's getting built. You'll appreciate it, and you can upload to us so we can share in it!
/ The B2650 count down has begun! #106
Do you work at beaver valley? Saw the tld and looks like fenoc in the picture?
Yes sir. Technical Service Engineering, SOSB-7. I'm the NDE Level III.
So, someone kindly pointed out that my backhoe joysticks were invited and were actually for the B26 that gets a dedicated seat for the rear that is back further and also lower. So I called up Sean at M&R and he went back to the mechanic and told him I had the wrong ones... And they appeared! I drive up this morning and grabbed the correct ones and I'm installing them now.View attachment 536578IMG_20180120_133616693_HDR.jpgIMG_20180120_134050515.jpg
The correct ones are much higher and reach forward to get closer to you with the chair bring higher and more towards the front even when flipped backwards. Much better.
Use your compressor to expand the black joystick knobs (there is a small hole in the top center) and they slip tight off.IMG_20180120_135937859_HDR.jpgIMG_20180120_135954782_HDR.jpgIMG_20180120_140958465_HDR.jpgIMG_20180120_141006375.jpg
I’ve been there a couple times between outages but have yet to make an outage. I do refueling.
It's a 2 outage year, so get some of you want it
The new B2650 backhoe joystick levers are on, you use the air compressor to install the black rubber knobs again. IMG_20180120_142614188_HDR.jpgIMG_20180120_142619740_HDR.jpgIMG_20180120_142625406_HDR.jpg
/ The B2650 count down has begun! #112
LARRY...!!!! STOP teasing us, we BX guys will be running to the dealer to get one like yours, now just stop it will ya....lol. Thats awesome, i`m very happy for you with your new tractor... i wish i had bought a B series now, instead of the BX, but its all good, maybe next time.
No....Noooo...... My BX is fine, my BX is fine, my BX is fine.....
OK, I fell better now. A little bit. 😜
/ The B2650 count down has begun! #114
Wow. I had forgot about TLDS. I was an operating engineer and worked at the Fenoc plant in Perry. I worked for Holtec doing their first dry cask storage putting the spent fuel rods into cask and moving the casks out to the pad. I ran the VCT moving the 351000lb casks from the spent fuel pool to the pad. I stayed on an then worked for Westinghouse for a refuel outage. I ran the Polar crane in the reactor disassembling and assembling the reactor. On my shift I actually got to set the reactor head, a 125 ton lift. I was new to nuclear when I started and would never believe I would do something like that. I really enjoyed my experience with both projects and got to meet alot of new people from all over the country on both projects.
/ The B2650 count down has begun! #116
So , can anybody show me how this bucket indicator thing works? What does it look like when in use. I can't figure out how to set the darn thing. And what's with the zip tie holding up the attached lever? That (zip tie) looks awful fragile for a FEL that is in operation.
Cheers,
Mike
/ The B2650 count down has begun! #117
BUCKET LEVEL4.JPG Maybe like this?
/ The B2650 count down has begun! #119
Good video Larry. I can稚 wait till
Mine gets here. I like watching your videos to really get a good look at the tractor and the bigger tires. Better than any picture.
/ The B2650 count down has begun! #120
Thanks Gents,
I just got home from watching the Eagles stomp the crap out of the Vikings. Congratulations Eagle fans.
Your picture and videos gave me the answer. My indicator does nothing because I have the standard bucket...i.e. there is no place to install that lower lever to the bucket. Why would the dealer deliver such a feature which is inoperable on this model? The mechanic simply zip tied the lower lever to get it out of the way
Cheers,
Mike
2012 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61572)
2012 Gehl DL11-55...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63118)
2006 Cadillac GM...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59910)
2016 FREIGHTLINER...
JOHN DEERE RM 4R CULTIVATOR (A63290)
JOHN DEERE RM 4R...
300 GALLON NITROGEN APPLICATOR (A63290)
300 GALLON...
Adams Weight Hopper (A63118)
Adams Weight...
