Oil & Fuel Micron Size For Primary Fuel Filter, BX24
   / Micron Size For Primary Fuel Filter, BX24
Thanks for all the good information. My BX24 is such a great tool I am going to do whatever it takes to keep it running.
   / Micron Size For Primary Fuel Filter, BX24 #22
All diesel in Oregon by state mandate is 5% BIODIESEL, many stations are selling the 20% BIODIESEL because they are not charging the 30 plus cents of state tax and are only charging the Federal Tax.
Uncle lives out on Oregon Coast and was having fuel problems before he got rid of the Dodge Cummins and was only buying fuel at Fred Meyer.
David
David
Wow, good to know. I had no idea. Would I be better off buying diesel fuel in Washington?
   / Micron Size For Primary Fuel Filter, BX24 #24
Have no Idea where they add it, if it is coming out of Portland or Vancouver it could already be in it. Look at the pump it should say what the bio diesel content percentage is.
Stopped using the metal drums and tank and just using 5 gallon jugs and never empty them all the way into the fuel tank, sometime you can see a little water in the bottom of the jug.
Put the Kubota B series plastic type water trap filters on everything, the BX, RTV and diesel lawn mower, the inline filters stop the water until overloaded and then the water just gets forced through, the filters with the metal end caps rust on my L3130.
David
David
Thanks David. Good advice.
   / Micron Size For Primary Fuel Filter, BX24 #26
Update, took the BX out yesterday to spread some gravel and after half an hour started running rough, got it back and up on the tilt trailer, shut it down and took the cowl off to check the water separator. Unscrewed housing and the end cap of the filter came off the filter and it picked up some of the water in the bottom of the bowl, still have the inline filter before the lift pump so never get any sediment that far by.
Had to run back home to get a replacement, so new procedure is to always carry spare fuel filters with tools for replacing, you never know when they will fail.
David
2015 Haulotte 5533A (A53316)
2015 Haulotte...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
Hustler super Z zero turn (A56859)
Hustler super Z...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
Case 2390 Tractor (A59814)
Case 2390 Tractor...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
