Battery Tender Connections
/ Battery Tender Connections #1
nybirdman
Super Member
north of upstate ny
Kubota L4240 HSTC,L3000DT
My tractor starts well with the block heater plugged in but I would like to connect
a battery tender.Tractor sits out-side and calling for "more"-20*F temps.
My tractor battery only has the top round post;doesn't have the side connectors or
1/4" stud on top like my boat batteries.
I have been unable to find an "adapter" to connect the 1/4" rings to my battery.
I do have the clamps by that is not fun when cold/snowing.
I am sure someone makes one but I have had no luck finding it..
thanks
/ Battery Tender Connections #2
I just removed the nut put on the ring terminal and a washer
/ Battery Tender Connections #3
I connect the ring terminals to the post clamp bolts.
/ Battery Tender Connections #5
I use the clips that came with mine. thanks ;sonny
/ Battery Tender Connections #6
You could drill pilot hole in the lead top post about 1/2" deep and run a short self tapping screw in from the top to hold the ring connectors that came with the BT.
/ Battery Tender Connections #7
It's lead; a self-tapping screw wouldn't need a pilot hole :drink:
/ Battery Tender Connections #8
It's not necessary to connect at battery terminals. I connected 12 ga wire at terminal blocks to install cigarette lighters on my riding mower and tractors. Salvaged lighter plugs connect into the 2 prong plug on tenders. The lighter is handy for phone charger,work light and port for charging test.
/ Battery Tender Connections #9
I put a pig tail about 18" long off of the battery. Remove the nut(s) on the post terminals - put the ring ends on the bolt plus a washer - put the nut back on and tighten down. The pig tail is long enough to bring the battery tender connection out from under the engine compartment.
Makes connecting the battery tender super easy.
/ Battery Tender Connections #10
What type of connectors you using? I know the ones that come with them but say if I wanted to snip the alligator clips off and add my own. Something like a flat 2 pin ? Any recommendations?
/ Battery Tender Connections #11
All my tenders came with a flat 2 pin connector that alow's going back and forth between included clamps and rings. The same configuration plug is available where auto parts are sold. No snip or clip of tender wires required.
/ Battery Tender Connections #12
True, but you ain't got a lot of room for error in the top of a post. I like a small pilot hole when it needs to be 'just so'.
/ Battery Tender Connections #14
That's perfect. But I'd need the other side as well. Call it the male end? Depending how you look at it. My battery maintainers have the alligator clips that I'd have to cut off and put new ends on.
/ Battery Tender Connections #15
This is what I did. Permanently connected leads to the battery that came with the battery tender and installed a quick disconnect panel on my dash.
/ Battery Tender Connections #16
/ Battery Tender Connections #18
/ Battery Tender Connections #20
I also put a 12v male plug on my trickle charger and a 12v socket on my tractor. I can move the charger to anything that has a 12v hot socket and charge away.
2013 VOLVO ECR88 (A65643)
2013 VOLVO ECR88...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
CLUB CAR  CARRYALL 6 (A65643)
CLUB CAR CARRYALL...
JCB  270T SKID STEER (A65643)
JCB 270T SKID...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
